86 2.1 idle issue searched & worked - please lend me your ear
fortheloveofvdub
fortheloveofvdub is offline
PostPosted: Mon Aug 24, 2020 9:27 am    Post subject: 86 2.1 idle issue searched & worked - please lend me your ear Reply with quote
‘86 2.1, I have an idle issue I’ve chased for a very long time. Ive searched, I’ve worked, I’ve swapped.
When cold starting it revs up (don’t have a tack’ but enough to make you worry on cold startup) and dies. It does this over and over until it warms up just a tad. The transition period between cold and warm is the only time it half ass idles correctly. Then, once warm it drives well but once at a stop sign in neutral or with the clutch actuated, the idle ramps way up and stays there until you pop the throttle with your foot. At that point it dies way down and hunts right back up and would stay ramped way up until you pop the throttle again.
The only things left in question are the ECU and fuel pressure regulator.
New or re-built parts were:
-new power steering switch
-new distributor (I broke the plug on the old one)/ plugs/ wires
-new fuel lines
-New fuel filter
-new aluminum fuel “rails”
-injectors professionally cleaned re-sleeved and flow checked
-rebuilt idle control module (module master) with each terminal cleaned and dielectric greased
-AFM swapped out with another running van to no avail,
-new air cleaner
-new oxygen sensor
-new “temp 2” sensor
-new breather tower
-go-westy rebuilt throttle body
-idle control valve checked for operation per searched info
-grounds cleaned and dielectric’ed: under dash, in battery box, by ECU, on engine bay wall, on block, on nose of tranny AND an 8ga. wire ran from ground at battery, to ground to battery box, to nose of tranny, to block to ground and to the ground on the engine bay to ensure a strong ground.
-new vacuum hoses with clamps on all
-AFM clamped well with no cracks
I’ve been wrestling with this for years.
Any smoking guns left to check for please? Where should I “go” next?
Last edited by fortheloveofvdub on Mon Aug 24, 2020 7:33 pm; edited 2 times in total
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Aug 24, 2020 10:01 am    Post subject: Re: 86,2.1 idle issue searched and worked please lend me your ear Reply with quote
I'd start off with a smoke test for vacuum leaks.
Igeo
Igeo is offline
PostPosted: Mon Aug 24, 2020 10:11 am    Post subject: Re: 86,2.1 idle issue searched and worked please lend me your ear Reply with quote
Idle control switch on the throttle body adjusted correctly?
1987 Westfalia 2.1 WBX Manual
fortheloveofvdub
Thank you, I’ll search that "smoke test" procedure next.
(later edit to reply: I forgot about that, good call!)
Last edited by fortheloveofvdub on Mon Aug 24, 2020 7:35 pm; edited 3 times in total
fortheloveofvdub
PostPosted: Mon Aug 24, 2020 10:12 am    Post subject: Re: 86,2.1 idle issue searched and worked please lend me your ear Reply with quote
Idle control switch adjusted. I will double check it however. I put it on about 3 years ago.
DanHoug
DanHoug is offline
PostPosted: Mon Aug 24, 2020 10:35 am    Post subject: Re: 86 2.1 idle issue searched & worked - please lend me your ear Reply with quote
how does it act with the plug to the idle stabilizer valve unplugged?
-dan
www.thefixitworkshop.com
fortheloveofvdub
PostPosted: Mon Aug 24, 2020 11:03 am    Post subject: Re: 86 2.1 idle issue searched & worked - please lend me your ear Reply with quote
Huh, I have not tried that recently. Will research tonight also, thank you!
Last edited by fortheloveofvdub on Mon Aug 24, 2020 7:37 pm; edited 1 time in total
shadetreemech
shadetreemech is offline
PostPosted: Mon Aug 24, 2020 3:24 pm    Post subject: Re: 86 2.1 idle issue searched & worked - please lend me your ear Reply with quote
I was having to pop the accelerator after coming to a stop. Turns out, I pulled the Throttle Position Switch out, cleaned it up, gapped it per 117 in the Bentley, no more pop the pedal no mo'.
https://www.thesamba.com/vw/forum/viewtopic.php?t=268356&highlight=throttle+position+switch
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY"
SyncroHead
SyncroHead is offline
PostPosted: Mon Aug 24, 2020 5:14 pm    Post subject: Re: 86,2.1 idle issue searched and worked please lend me your ear Reply with quote
When you check this switch be sure to check it for electric circuit closure. Sometimes you can hear the switch engage, but it's still not actually closing the circuit.
Jim Davis
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
fortheloveofvdub
PostPosted: Mon Aug 24, 2020 7:27 pm    Post subject: Re: 86 2.1 idle issue searched & worked - please lend me your ear Reply with quote
I read back again about unplugging the idle stabilization valve. I forgot all about that as a diagnostic indicator.
I also read back through several write-ups on the TPS. I need to check the conduction of the switch and make sure it's gapped correctly also. When I put the new one in there it didn't change the idle for the better at all. At that time I did not check the switch too closely except for the "click" at the right time. It was supposed to be all ready to go and thought not to fix what might not be broken. That new throttle body only has probably 1,000 miles on it.
I think I will "start" again there.
During this re-do all new stainless steel coolant lines and hoses were put in. Also a new distributor so it's not in time perfectly yet. It had that same old pattern of idle, however.
I think I will check the rubber hoses and paper gaskets on the intake also. I put them there 12 years ago and they're the only part of that system undisturbed. I forgot about the "smoke test"! BINGO
If this is a vacuum problem I will stand on my head and fart sparks!
Thank you for your input. I first started searching for this problem here 10 years ago.
One new one I found was that not only the PS switch (I replaced) provide input on the idle so does the AC. My AC is not functioning. I wonder what connector the signal comes from and what happens in that signal when there isn't one.
I was so disheartened that after 3 years of multisystem overhaul the same damn idle popped up. You folks of all people know what I mean.
