glennj3cub Samba Member
Joined: August 05, 2020 Posts: 262 Location: South Carolina
Posted: Mon Sep 14, 2020 12:13 pm Post subject: Left trans axel! |
I attempted to loosen some of the bolts but had no wheels on yet. I know have brake drums in place so I can lock them down. Any advice on how to get them off? Will it require heat?
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2425 Location: Colorado
Posted: Mon Sep 14, 2020 1:19 pm Post subject: Re: Left trans axel! |
You probably need a 12pt "triple square" tool to loosen the CV bolts. These should be torqued to 25 ft-lbs. You *should* be able to loosen them by holding the the brake drum with one hand. Be sure to scrape and clean out all the bolt socket heads first. _________________ 1972 Standard Beetle
1969 Baja Beetle |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Mon Sep 14, 2020 1:37 pm Post subject: Re: Left trans axel! |
Do make sure yo clean out the 12 point holes other wise you will be a stripping. So when i replaced mine I used the local FLAPS with lifetime warranty. That was several years ago and they are working fine. When fail will not have to purchase another cause of lifetime warranty.
https://www.oreillyauto.com/detail/b/masterpro-cv-...&pos=1 _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Sep 14, 2020 3:18 pm Post subject: Re: Left trans axel! |
Yes I cleaned them out and ordered the 12 pt but felt like it might strip so I stopped, besides I couldn’t hold them from turning without the drum. Maybe next time.
Those are pretty cheap at O’REILLY! |
gt1953 Samba Member
Posted: Tue Sep 15, 2020 6:49 am Post subject: Re: Left trans axel! |
I have those on a couple of my cars. Some will tell you those half shafts are not good well they are fine for me. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 487 Location: Rhode Island
Posted: Tue Sep 15, 2020 8:43 am Post subject: Re: Left trans axel! |
The CV bolts thread into hubs at the transmission and at the wheel. The bolt threads extend through the hub and protrude by an eighth inch or more on the back side. Spray WD-40 or your preferred penetrating oil on these threads. Spray the heads of the bolts too. Do this for two or three days, let it work it there.
And when you get a bolt to turn, stop at 1/4 turn. Apply more penetrating oil. And work the bolt back and forth 1/4 turn, CCW and CW, until it frees up more. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Posted: Tue Sep 15, 2020 7:54 pm Post subject: Re: Left trans axel! |
Thank you, working it now! |
Posted: Tue Sep 22, 2020 4:52 pm Post subject: Re: Left trans axel! |
73 Super Beetle.
The bolts came out relatively easy. One bolt on each side had a broken head leaving just the stud inside of the threads. I turned them out by hand!
I assume I can’t buy those bolts anyplace local??
The new axels came with 2 tubes of grease. I cleaned out the old grease. I assume I just pack the bearings with this fresh grease & bolt back up to transmission & wheel? 25 ft lbs?? |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Tue Sep 22, 2020 6:27 pm Post subject: Re: Left trans axel! |
You might be able to find them locally if you have a good hardware store nearby that stocks a variety of 10.9 grade metric Allen bolts.
Nothing VW specific about them, 8mm x 1.25 x 50mm shouldered socket head bolt.
Here also is the first hit on a Goggle search, plenty out there by mail order...
https://www.jbugs.com/product/113501229D.html?gcli...l0QAvD_BwE
Note most replacements will not have the original 12 point square drive recess but instead a 6mm or 8mm Allen head so you may need to buy a new driver as well.
Yeah, 24-25 ft lbs sounds about right. You need to lock the wheels some way so you can use both hands to hold the socket firmly and 90 degrees into the recess without it slipping out. One good way is have a helper hold the brake pedal down for each one as you rotate the wheel to access the next.
Start by tightening the screw on the bottom then rotate wheel 180 degrees then tighten opposite one, then alternate in a star pattern same way you would a clutch pressure plate or 6 bolt wheel.
Not uncommon for them to come loose and/or snap off so best practice is to check them for tightness every time you change oil or adjust brakes. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Tue Sep 22, 2020 7:54 pm Post subject: Re: Left trans axel! |
Thank you 61. I ordered a dozen! I usually work alone so I’m up & down, pulling& releasing the parking brake between turning the wheels! |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Wed Sep 23, 2020 3:26 am Post subject: Re: Left trans axel! |
When you put the tool in the bolt head tap it with a hammer to make sure its in.
Easy to strip the tool if not. _________________ '72 Beetle |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11143 Location: Huntington Beach, CA
Posted: Wed Sep 23, 2020 8:41 am Post subject: Re: Left trans axel! |
grandpa red wrote: |
Easy to strip the tool if not. |
And use the tire as the other wrench! I actually have always stuck the tool in the bolt and turned the tire, while holding onto the tool, of course. Super easy! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Wed Sep 23, 2020 4:56 pm Post subject: Re: Left trans axel! |
I know these large roller bearings can do OK with a little scoring but I think these need replacing?
73 Super Beetle outside bearing.
The grease was pretty dry on both outside ones. I haven’t gotten the Px bearing out yet..
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 625 Location: South of Raleigh
Posted: Wed Sep 23, 2020 6:41 pm Post subject: Re: Left trans axel! |
Those are the CV joints...and they're badly worn. Replace them...probably easier and not any more expensive to just get assembled axles |
Posted: Thu Sep 24, 2020 5:01 am Post subject: Re: Left trans axel! |
glennj3cub wrote: |
I agree replace! _________________ '72 Beetle |
