sun-bug74 Samba Member
Joined: July 14, 2020 Posts: 302 Location: Gloucester, MA
Posted: Wed Sep 23, 2020 2:54 pm Post subject: Remove Steering Wheel Horn cover and pad, Sunbug |
Is there an old post or does someone know how to get the top off of the steering wheel in a 74 sunbug SB? It is a special wheel that year.
Thanks.
BZ |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79581 Location: Sneaking up behind you
Posted: Wed Sep 23, 2020 2:59 pm Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug |
Isn't the same as the steering wheel as other Beetles of the same year? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Sep 23, 2020 3:30 pm Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug |
My understanding is that it is a special wheel for the sunbug. It has the castle on it in the center and is padded.
BZ |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Wed Sep 23, 2020 3:35 pm Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug |
Assuming you mean the horn button, you simply dig your fingers (don’t use a tool) between the horn button and the front body of the housing. Dig in and pull one corner until it comes up, then do the same for the other three corners.
However, with the 1974, you have only done half the job. Once the four corners are up, you must turn the horn button about 90 degrees counterclockwise. This will allow you to pull the horn button off completely. Remember to unhook the horn wire before pulling off completely.
I always put a little dielectric grease on the edges of the four round tabs that hold the button on. This makes it easier to remove it—without breaking one of the tab edges.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Wed Sep 23, 2020 4:22 pm Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug |
Thanks. Do I go under the silver trim or between the silver trim and the upper black part? I assume you are familiar with the sunbug wheel? I can send a pic if needed.
BZ |
