Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
canadianeh Samba Member
Joined: August 31, 2020 Posts: 15 Location: Perth, Ontario
Posted: Thu Sep 10, 2020 9:46 am Post subject: Re: What's this Ghia part and Where does it go? |
I have that same assembly under my 70 Ghia, 4 speed.
Were there gas heaters that came tunnel mounted? This device hooks up to a "box" that intercepts the hot air from the heater pipes before heading into the cabin. My car does have a heater light on the dash but no switch to activate the heater. |
Propdriver Samba Member
Joined: September 28, 2018 Posts: 2 Location: Winnipeg
Posted: Thu Sep 10, 2020 4:05 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks canadianeh for the insight,
I do believe I have the same heater as the pic on pg 24 on this thread.
The hose going into the engine bay has been cut so I’m not sure where it is supposed to connect up on the engine side but at least I have an idea on narrowing the search.
I also have a light on the dash that I have no idea what it’s function is so I’ll assume it’s heater related.
Thanks again eh, |
Posted: Fri Sep 11, 2020 6:57 am Post subject: Re: What's this Ghia part and Where does it go? |
No problem eh.
I will likely remove the heater from the car. The "exhaust" pipe is missing and it looks pretty rough overall. |
69 GVert Samba Member
Joined: October 20, 2014 Posts: 61 Location: San Jose, CA
Posted: Fri Sep 11, 2020 9:25 pm Post subject: Re: What's this Ghia part and Where does it go? |
xzener wrote: |
I resemble that. 😆
I was able to drill/tap one of these PC rack anchor nuts for M6X1. This should work nicely. Thanks again Rick.
I just found a bag of 5 of these in my 6mm hardware drawer. Came with some rack mount something or other years back. Yep 6X1.0 metric... Have several drawers dedicated to the 10-32 ones as well. _________________ Aircooled? Drive one a day, that's all I ask! |
pkbghia Samba Member
Joined: February 22, 2017 Posts: 64 Location: Wyomissing Pennsylvania
Posted: Sat Oct 10, 2020 10:16 am Post subject: Re: What's this Ghia part and Where does it go? |
Any idea what the silver button is to right of steering column.
Posted: Sat Oct 10, 2020 10:58 am Post subject: Re: What's this Ghia part and Where does it go? |
pkbghia wrote: |
Any idea what the silver button is to right of steering column. |
Dunno, but I've seen both horn buttons and cigar lighters that look like that. _________________ Aircooled? Drive one a day, that's all I ask! |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Oct 10, 2020 11:07 am Post subject: Re: What's this Ghia part and Where does it go? |
Did you look under the dash to see if it is connected to anything? That might give you some indication what it's connected to. I have the same empty slot on mine, just deciding what I want to place there.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Sat Oct 10, 2020 12:59 pm Post subject: Re: What's this Ghia part and Where does it go? |
The picture is some thing I saw online. I had found one of those buttons loose in the glove box of my 1970 ghia, wasn’t sure what it was or where it went. Saw it in this picture and wondered if someone knew. |
Marcdeb Samba Member
Posted: Wed Nov 18, 2020 11:53 am Post subject: Re: What's this Ghia part and Where does it go? |
These rubber seals came with my car - with all the parts necessary to install the new convertible top. In all the research I've done, I have yet to see what these seals are for and where they go? There is 2 and both are 25 inches long. Can someone tell me these are used with the convertible installation?
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Wed Nov 18, 2020 12:46 pm Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
... I have yet to see what these seals are for and where they go? |
they bear a striking resemblance to the fresh air grill seals
Posted: Wed Nov 18, 2020 1:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
crocteau wrote: |
Marcdeb wrote: |
I think you are correct. I just tried one and the length fits just right. I thought it was strange that I had not seen
these in any of the convertible top related threads. I didn't even consider that they didn't belong in the bag of top parts!
Thank you. You're a big help. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Wed Nov 18, 2020 2:37 pm Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
...Thank you. |
You're entirely welcome, Marc.
The memory of spending some real quality time installing those devil's shoestrings is branded on my psyche. I trust with your patience and skill you'll breeze through it. |
Posted: Wed Nov 18, 2020 3:05 pm Post subject: Re: What's this Ghia part and Where does it go? |
crocteau wrote: |
Marcdeb wrote: |
...Thank you. |
We shall see when the time comes! I assume these rubber seals are not glued on? Now that I look at these, I think they were either slightly used or possibly someone tried to put them on already? They are in excellent shape but I can see tiny holes on each end like someone tried to staple or pin them together. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Wed Nov 18, 2020 3:24 pm Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
They are in excellent shape but I can see tiny holes on each end like someone tried to staple or pin them together. |
Yes, the replacements I got from KGPR came as loops, each held closed with a very small staple. No glue for me. |
Posted: Wed Nov 18, 2020 4:12 pm Post subject: Re: What's this Ghia part and Where does it go? |
crocteau wrote: |
Marcdeb wrote: |
That makes sense. Glad to have this information. What would we do without all the helpful members on TheSamba?
Again, thank you. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue Dec 01, 2020 8:05 pm Post subject: Re: What's this Ghia part and Where does it go? |
crocteau wrote: |
pkbghia wrote: |
Any ideas on which were original holes and which seem to be aftermarket? |
Here's a "before" look at the unmodified stock engine compartment of my '71 taken back in 2004 for comparison. IIRC only two of the three holes in the lower left were used, one as the pass-through for the battery cable to the starter (shown) and the other for the wire from the reverse switch to the fuse holder. The original purpose of those oblong holes on either side remains a mystery to me |
Was there ever a grommet for those 2 oblong holes? The 2 are diff sized. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Wed Dec 02, 2020 5:49 am Post subject: Re: What's this Ghia part and Where does it go? |
bnam wrote: |
Was there ever a grommet for those 2 oblong holes? The 2 are diff sized. |
I know of no specific grommet, but a rubber or neoprene edge trim/guard (Google: trim-lok) can be cut to fit.
Posted: Wed Dec 02, 2020 7:12 am Post subject: Re: What's this Ghia part and Where does it go? |
bnam wrote: |
crocteau wrote: |
pkbghia wrote: |
The one on the right is for the transmission hoses on an Autostick. There is a grommet for that, Seems like I had a grommet for the left one as well.
d _________________ 1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe |
Appw Samba Member
Posted: Sun Dec 13, 2020 7:50 pm Post subject: Re: What's this Ghia part and Where does it go? |
What are these chrome and round parts that look like they should attach to drum brakes?
Also, I have found that the black wooden grip fits perfectly onto the e-brake. Has anyone ever seen something like this before? |
