T2 78 Multiple relay installation - Hot start and petrol pump
peagreenbus
peagreenbus is offline
PostPosted: Fri Oct 30, 2020 10:59 am    Post subject: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
I want to fit a hot start relay, 2 petrol pump relays and an aux battery relay in the engine bay and a fog light relay up front. Petrol pump is off the coil at the moment.
If there are any electrically minded out there who could have a glace at this installation sketch I would be most grateful.
I have some questions -
I think I need 10gg cable from relay to terminal 50 on the solenoid?
Also 10gg from starter relay to earth pin 30?
Also 10gg from starter relay to solenoid terminal 30?
Is it ok to daisy-chain lives and earths? (Within reason as in the diagram - no heavy loads on the daisy chains)
The Alternator blue (same as the Voltage regulator blue) will activate both the petrol pump relay and the split charge relay
which both depend on whether the engine is charging itself or not - correct? OR should I take the live off the VR blue.
Unsure of where to take the live for the fog lamps from. Or maybe better route a new 2.5 from the battery directly.
I’d be very grateful if any errors could be pointed out or improvements given.
Many thanks
Driving - Cooper 1275, VW Bay '78, 110 Defender
Gone - Herald (topless), Minor MM, Minor 1275, Traveller, Saab 96, P1800, ½ Ton Lightweight
Riding 1150 GSA
Sailing 1962 Fireball
KentABQ
KentABQ is offline
PostPosted: Fri Oct 30, 2020 11:14 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Nice job with the schematic! That's impressive.
The person you'll want to chat with is Telford Dorr. He's online often, and should comment on your questions soon.
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
Wildthings
Wildthings is offline
PostPosted: Fri Oct 30, 2020 8:46 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
A fuel pump specific relay has a diode in it so it can be activated by two different triggers, your system would also work.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Oct 30, 2020 10:46 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
FWIW because of the way VW buses need massive amounts of air to cool, in wet season there is a lot of humidity in the engine bay - it isn't like an American car where the air is deflected down and under the car. The air has to get out thru the engine which means it circulates in a larger area. Were it me, I would visit PickNPull or something like that were you can find a relay box out of a junk car that is weather tight, and use that for your relays. If you expose them to the elements, they will last a while but not as long as those sealed up. You can also mount them to the firewall up high near the double relay to avoid some of the wetness.
George Carlin:
Skills@EuroCarsPlus:
telford dorr
telford dorr is offline
PostPosted: Sat Oct 31, 2020 12:50 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
A few minor (and one major) changes (as noted in red):
1 - need two wires to the ignition switch to separate the start and run functions.
2 - swap relay terminals 85 and 86 for relay compatibility.
3 - eliminate redundant fuses.
4 - minor rework of start driven relay wiring.
5 - increase main power fuse from 15 amps to a 30 amp slow blow type (starter solenoid initially draws 25 amps).
Other than that, looks good.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
peagreenbus
PostPosted: Sat Oct 31, 2020 3:29 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Thank you Telford dorr
That’s really clear and I see and understand my mistakes!
Will report back when it’s working. Fingers crossed.
Riding 1150 GSA
telford dorr
PostPosted: Sat Oct 31, 2020 5:25 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Not mistakes - more of a lack of optimization. But that's OK: in the software business we like to say, "beware of premature optimization". After the third prototype (or so), a design gets pretty close. You're only on the first pass (but the direction is correct)...
ratwell
ratwell is offline
PostPosted: Sun Nov 01, 2020 9:00 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Has anyone noticed that the Bosch WR1 kits have forever had the polarity backwards? It works as designed but just something I've always wondered about.
Here's what Bosch recommends for polarity (see note at bottom):
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
peagreenbus
PostPosted: Mon Nov 02, 2020 7:16 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Ah ok so that's where I got 85 and 86 the wrong way round.
On the WR1 relay kit it specifies 86 to ground and 85 to trigger.
This one!
https://www.thesamba.com/vw/gallery/pix/897887.jpg
which is a Bosch. So is that a wrong sketch from the reseller?
My relays aren't Bosch, but "made in EU" other ones, and I've changed earths to 85.
However, it would still work the other way round, wouldn't it as its an electromagnet and I presume no diode...? 4 pin relay.
And is 30A ok for the hot start? Maybe 40A better?
Riding 1150 GSA
telford dorr
PostPosted: Mon Nov 02, 2020 11:03 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
No, it's fine, as the seller supplied the relay.
Yes, non-diode relays work either way. The point is: if you wire it terminal 85 as negative/earth/ground, then someday if someone were to plug in a diode-equipped relay, it would work fine. Think of it as "future-proofing".
Same thing with wire colors: brown is always used for ground, but if you used a brown wire to supply power from your fuse block to, say, your radio, it would work fine. It would just confuse the next person to work on it.
Definitely better! One should always run electrical components well below their maximum ratings, for best reliability. [For example: your type 1 engine has a 4600 rev/min redline, but you wouldn't drive it for eight hours at that speed, would you?]
ratwell
ratwell is offline
PostPosted: Mon Nov 02, 2020 1:27 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
This is a really good webpage on Bosch relays from several years ago that's thanksfully still around:
http://www.bcae1.com/relays.htm
You'll need to enable Flash in Chrome (Preferences->Privacy and security->Site Settings->Content->Flash Always Ask to [ON]) to get the most from it, although there doesn't seem to be any animations that take advantage of Flash.
peagreenbus wrote:
This one!
That's the right diagram and it came with all the WR1 kits. In fact, that photo is from the kit I personally purchased and posted on my website long ago:
https://ratwell.com/technical/EssentialUpgrades.html#hotstart
Here's the comment on polarity from the website I mentioned:
Remember that the relay coil has to have a difference of potential between terminals 85 and 86 in order for the coil to pull the armature in/down. This means that you may apply battery voltage to either terminal 85 OR 86 and then ground the OTHER terminal.
To answer your other question:
The Bosch relay that came in the original kit was 0 332 019 150 which is a 12V/30A relay. As for the current drawn and what relay you'll need:
The Bosch starter needs at least 7.2V for the starter solenoid to engage. 12V leaves the battery but by the time it goes through the ignition switch and comes back the voltage has dropped due to the current required to engage the starter solenoid (8.25A).
My advice is to get the Bosch WR1 relay kit from BD. This kit essentially consists on a simple Bosch relay (0 332 019 150) that will send more current to the solenoid because now only the relay trigger current (123mA) needs to travel through the ignition switch wiring.
So any common 30A automotive relay should have no trouble engaging the start solenoid.
Reference: https://www.ratwell.com/technical/FAQ/FAQContent.html#0901
'78 Westfalia CDN
peagreenbus
PostPosted: Mon Feb 22, 2021 4:22 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Just a short follow-up to this.
I know most of you will get through this little relay installation before breakfast, but in between leaking fuel pumps, porous pipes (now replaced with R14 barricade) all breather pipes replaced, and a firewall respray, it took me a little longer!
Now all done, it works very well.
If I was doing it again. I'd look at a single 5 pin relay rather than two 4 pin for the safety cutout.
Starting with empty carbs was made a lot easier with a little jump lead from battery to relay just to fill them up.
New pump installed on the chassis rail and a petrol king regulator running at 2.1 psi. into FRDA's
Thank you for the help again and I'm afraid my wiring isn't quite as neat as yours. That 10gg can be a devil!
Good to be back on the road! Just a balance pipe / vacuum question now but I'll do that on another post topic.
Riding 1150 GSA
Wildthings
PostPosted: Mon Feb 22, 2021 10:03 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
You can get fuel pump relays with a built in timers so that the pump will run for a second or two when you first turn the ignition switch on like what happens on newer FI'd cars and trucks. This would allow you to prime the carbs just using the key and would also shut the pump down automatically whenever the engine quit for some reason like being in a wreck or if you had an engine fire.
ToolBox
ToolBox is offline
PostPosted: Mon Feb 22, 2021 11:51 am    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
A common Rabbit/Golf pump relay will work.
raygreenwood
raygreenwood is offline
PostPosted: Mon Feb 22, 2021 8:32 pm    Post subject: Re: T2 78 Multiple relay installation - Hot start and petrol pump Reply with quote
Yes...but just get the newer ones. More precisely...dont use a used one that you dont know the age of...if it has the built in 16amp piggyback fuse. It took two years for the dealers to figure that one out....and thousands of cars spent forever in the shop.
The relay was burning up without the fuse blowing. Ray
