Strega51 Samba Member
Posted: Fri Nov 06, 2020 6:29 pm Post subject: Just bought my 1st VW Bug 1965 |
Just brought this home today. All original and from the original owner. Now the fun begins. I have a lot to learn.
Posted: Fri Nov 06, 2020 6:32 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Strega51 wrote: |
Fontana Gray. Brick red interior. |
rcroane  Samba Member
Joined: January 03, 2013 Posts: 2015 Location: Springfield, Virginia
Posted: Fri Nov 06, 2020 7:57 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Welcome to The Samba and the '65 club!
What are your plans for your bug?
As a starter, get yourself a copy of John Muir's Idiots Guide to Keeping Your VW Alive. You'll eventually want to get a Bentley workshop manual. _________________ '65 Sunroof Bug
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Fri Nov 06, 2020 8:11 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
very nice! _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
Gr0unded Samba Member
Joined: October 02, 2018 Posts: 266 Location: North Carolina
Posted: Fri Nov 06, 2020 8:42 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Strega51 wrote: |
That looks like a great starting point, the body looks to be in good condition. Enjoy the experience it brings.
Cheers! _________________ B r i a n
1976 VW Type 1 Beetle - Standard
Stop Dead Photo Links! Post your VW photos to the Samba Gallery! |
TheRide Samba Member
Joined: May 06, 2019 Posts: 293 Location: North Carolina
Posted: Fri Nov 06, 2020 10:26 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Thats a very solid looking foundation! |
Posted: Sat Nov 07, 2020 5:11 am Post subject: Re: Just bought my 1st VW Bug 1965 |
There are some body issues. Both lower rear quarters are shot covered with filler. Passenger lower hinge point gone. I did find lower replacement quarters from JBugs. Has anyone had experienced changing the quarters? Thanks |
Posted: Sat Nov 07, 2020 5:12 am Post subject: Re: Just bought my 1st VW Bug 1965 |
Gr0unded wrote: |
Strega51 wrote: |
Cheers! |
Thanks  |
Posted: Sat Nov 07, 2020 5:16 am Post subject: Re: Just bought my 1st VW Bug 1965 |
rcroane wrote: |
As a starter, get yourself a copy of John Muir's Idiots Guide to Keeping Your VW Alive. You'll eventually want to get a Bentley workshop manual. |
Just a good go thru. Correcting any issues. Leaving it stock. It still
is 6V. and needs a battery. Should I leave it 6 for know or convert. Thanks |
Posted: Sat Nov 07, 2020 6:42 am Post subject: Re: Just bought my 1st VW Bug 1965 |
Strega51 wrote: |
rcroane wrote: |
I would vote for keeping it 6v. A well maintained 6v system is perfectly adequate. That being said, I'll admit that I've added a few "helpers" to my 6v system......LED brake light bulbs/rear turn signal bulbs, electronic turn signal flasher, and a horn relay. You have a very original car....those are getting harder and harder to find. _________________ '65 Sunroof Bug |
pantone149 Samba Member
Joined: August 19, 2004 Posts: 1031 Location: Mt. Shasta
Posted: Sat Nov 07, 2020 11:22 am Post subject: Re: Just bought my 1st VW Bug 1965 |
Point #1: Bear in mind that it took a few dozen (maybe a few hundred) really smart German engineers to design that car. Everything they did had a purpose. In other words, I suggest sticking with what they did as much as possible.
Point #2: A used German part is oftentimes better than a brand new Chinese part.
Point #3: Have fun. What a great vehicle to own!! |
Posted: Sat Nov 07, 2020 11:43 am Post subject: Re: Just bought my 1st VW Bug 1965 |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
I would vote for keeping it 6v. A well maintained 6v system is perfectly adequate. That being said, I'll admit that I've added a few "helpers" to my 6v system......LED brake light bulbs/rear turn signal bulbs, electronic turn signal flasher, and a horn relay. You have a very original car....those are getting harder and harder to find. |
I agree on the 6v. |
Posted: Sat Nov 07, 2020 3:31 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Strega51 wrote: |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
Do a search on here for 6v battery recommendations. How's the battery tray in your car? _________________ '65 Sunroof Bug |
Posted: Sat Nov 07, 2020 4:11 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
Do a search on here for 6v battery recommendations. How's the battery tray in your car? |
Battery tray not bad. Bought a NAPA 6v battery today. Neg cable just barley makes it going to order a longer one. I bought this from a older gent. the motor wasn't stuck and it rolled on the trailer for $950 that was good enough for me. |
Posted: Sat Nov 07, 2020 4:17 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Strega51 wrote: |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
Strega51 wrote: |
rcroane wrote: |
So when I turned the key for the first time with power nothing. Then after a few tries the starter started turning. So now starts process of elimination. I have 6v to the coil but no spark. Thats as far as I got today. |
Posted: Sat Nov 07, 2020 4:26 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Before you try to start it, have you checked/changed the oil? When was the last time the car was started and driven? No doubt the wiring is dirty and/or corroded, including the grounds. Did you pull and inspect the plugs? What about the points and condenser? _________________ '65 Sunroof Bug |
Rome Samba Member
Joined: June 02, 2004 Posts: 10554 Location: Pearl River, NY
Posted: Sat Nov 07, 2020 5:55 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Welcome to Beetle ownership.
Suggestions:
1. For the engine, there is a very clever and resourceful man named "Mustie1" on YouTube who has many videos on getting old VW engines to start. Most of his pre-start preparations are similar. I recommend watching a few; they are usually named "Will it run?". This also helps you to locate the same components on your Beetle.
2. Remove the battery ground strap where it attaches to the body. Usually an M8 bolt (13 mm socket size). Clean the body metal with 80 grit sandpaper, and also the end of the strap. Reattach. Do same with the big + cable that goes to the starter. Another M8 nut (again, 13 mm socket). Clean off the lug on the starter/solenoid with a toothbrush-sized wire brush, and clean off the cable lug eye with that same 80 grit sandpaper. You're eliminating voltage drops due to long-term corrosion at those major connections.
3. There's an excellent VW club based in CT, the CT VW Association. https://www.ctvwa.org/index1.php?center=center/home.html
4. Bug City in Berlin, CT (between Hartford and Meriden) has a huge selection of used parts, and new parts.
Other:
I was in CT today to visit a long-time VW friend; lives slightly south of Hartford.
Are your door panels and seats as nice overall as the small portions we see in that one photo? If so, lucky you. I also had a Fontana Grey '65 Beetle about 30 years ago; was a just-painted rolling shell. I never put it together, but sold it to a coworker who did finish and drive it. |
Posted: Sat Nov 07, 2020 8:20 pm Post subject: Re: Just bought my 1st VW Bug 1965 |
Rome wrote: |
Suggestions:
Other:
Thanks for all that great info.Yes panels and seats are in great shape. I was surprised. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3344 Location: Memphis
Posted: Sun Nov 08, 2020 12:37 am Post subject: Re: Just bought my 1st VW Bug 1965 |
Looks great, I would say it seems to be a pretty decent car especially considering what you paid for it! Congratulations!
I highly recommend keeping everything that you find in the car, and everything that you replace. It's easy to accidentally throw away a part that is NLA or has bad aftermarket repros. Heck, I had never been in a metal sunroof beetle in my life until I bought my 1967 car last year... I almost threw away some of the sunroof hardware stuffed in the door pocket, not knowing what it was!
There are tons of things to do to make an old car roadworthy. The most important are brakes and steering, followed by suspension at some point. The engine is a matter of reliability... if you don't mind troubleshooting on the road, just get the engine running and drive it. If you want to make it reliable, spend a little time going over the engine.. take it out and clean out under the cylinder tins and the fan shroud, they usually have years of squirrels and mice acorns and bedding stuffed in there. You don't have to go whole hog on a rebuild. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2338 Location: Cleveland, OH
Posted: Sun Nov 08, 2020 5:29 am Post subject: Re: Just bought my 1st VW Bug 1965 |
What a great foundation.
Enjoy the ride. _________________ 1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile |
