ejon Samba Member
Joined: September 21, 2012 Posts: 128 Location: oregon
Posted: Fri Oct 30, 2020 12:57 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Ben, you have a fancy trans and motor now. get one of these starters. you'll never regret it. Your engine will start in a 1/2 a crank and sound like a modern engine doing that.
when these are in a Bus body you might have to extend the wiring a few inches. I had to in my 70.
most every vw vendor sells these, inculding CSP
https://www.cbperformance.com/product-p/2143.htm |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Manfred58sc Samba Member
Posted: Fri Oct 30, 2020 8:47 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Just get one from the states, its can ship to you for $33 plus the cost of the part. Cracks like that can happen for many reasons. _________________ Fat chick owner/operator |
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1443 Location: Off Grid
Posted: Tue Nov 10, 2020 11:17 am Post subject: Re: Overlanding a VW Bus Around The World?! |
New Bosch solenoid arrived from Italy - now starts right up. No idea how much longer this OG starter will last but for now it's working great.
Thanks again for your help _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Latest Adventure Series - https://bit.ly/LifeDoneDifferently |
Fish Samba Member
Joined: December 05, 2000 Posts: 5925 Location: OB. It's beside the point.
Posted: Sun Nov 22, 2020 2:46 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
So I just watched the Venice episode where you were talking about bump starting the bus. I thought I should mention (I'm sure you already know this, but others may not) that when bump starting on a slight hill or flat ground put the bus in second or third gear. This will keep the wheels from skidding you to a stop and let the motor turn over easier. _________________ Prosit!
# 303 and #156
Fairmounter Samba Member
Joined: August 20, 2017 Posts: 173 Location: Guatemala
Posted: Sun Nov 22, 2020 5:11 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
HastaAlaska wrote: |
The only other time I did this was in Guatemala and the guy insisted I purchase both solenoid and starter, go figure! I'm not sure if it is common/possible to replace each component individually. Or do you think the starter is having issues too based on the whirring?
Did you find a decent starter in Guatemala? The only one I was able to find here was Quality brand from Mexico. It was about half the weight of the one it replaced. It often takes a few tries to get it to crank, but eventually it always cranks.
By the way, do you have any camping suggestions in Guatemala? When I look online, I find nothing. Volksfest was held at Hotel Bahia in Panajachel last weekend, I ended up staying the entire week--camping in a field with 4 horses and 4 dogs. In your videos it looked like you stayed somewhere in San Marcos. _________________ 1973 Westy Tintop |
Posted: Mon Nov 23, 2020 4:02 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Fairmounter wrote: |
By the way, do you have any camping suggestions in Guatemala? |
I think all VW parts in Guatemala come from Mexico, perhaps some even from Brazil. The starter I installed was Mexican and worked perfectly.
Sorry I can't really remember where I camped in Guate - it was a long time ago now. I do remember that there wasn't any shortage of great places to stay. Look up the hot waterfall in the north, that was very memorable. _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Tue Nov 24, 2020 12:06 am Post subject: Re: Overlanding a VW Bus Around The World?! |
A bit late to this starter solenoid repair party, but:
Very likely you can buy JUST the high amp repair end that will need to be soldered onto the fine solenoid wire. But the parts are available separately. And for a small amount of money, I'd think.
You very likely broke this yourself trying to tighten the battery cable nut. I always use plenty of grease on the stud so it doesn't corrode and freeze in a less than tight position.
The nut may have loosened somewhat on its own after many heating cycles. There are peak loads of perhaps 200 amps going thru this stud and it may have needed tightening.
Use care when checking the tightness OR remove the negative battery cable to avoid welding with your wrench.
I've changed a LOT of these on WBXer vanagons and without the cooling tin it is pretty easy to do from above and I just wrench carefully and do it hot. (electrically) (don't do as I do, do as I say!) _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Tue Nov 24, 2020 2:44 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Alan Brase wrote: |
You very likely broke this yourself trying to tighten the battery cable nut. I always use plenty of grease on the stud so it doesn't corrode and freeze in a less than tight position. |
I first noticed it broken when trying to undo the nut to clean the cables. Grease would have helped that situation and I would normally like to use anti seize there, it seems non was applied when it was installed.
I now see that anti seize IS conductive, so perhaps I should take off the nut and put some on there. _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Clementine79 Samba Member
Posted: Tue Nov 24, 2020 8:49 am Post subject: Re: Overlanding a VW Bus Around The World?! |
ejon wrote: |
Anyone else have experience with these? Does the 2149 fit without modifying the wiring? I see the 2143 shows for a type 1 and the 2149 shows for a 091 bus transmission which is what we have in ours. |
Posted: Sun Nov 29, 2020 11:45 am Post subject: Lithium Battery Upgrade |
A quick note as I know some of you following this thread were considering upgrading to Lithium batteries, if you are not - you can disregard this message.
ENDING MONDAY 30th NOV (I think)
I noticed that Battle Born Batteries (the ones we installed in our build) have a really good deal on right now $150 off plus free shipping and 10 YEAR warranty. Also, our discount code seems to still be working even in the sale which gets an additional $50 per battery
Use Code: kombi5off for as long as it lasts until they turn it off, which they were supposed to do but I guess forgot.
https://kombilife.com/li-ion-batteries/
Also as a heads up, they just released a self-heating battery for people in colder climates.
Normal Lithium batteries don't like the below-freezing temps. Wish this had existed when we installed ours. (it's a bit more expensive though)
https://kombilife.com/HeatedBattery/
Thought some of you would appreciate that. _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
nemobuscaptain Samba Member
Posted: Sun Nov 29, 2020 2:31 pm Post subject: Re: Lithium Battery Upgrade |
Normal Lithium batteries don't like the below-freezing temps. Wish this had existed when we installed ours. (it's a bit more expensive though). |
I notice some people toss around upgrade pretty loosely. For instance they say they are UPGRADING to 16' wheels so they can added UPGRADED passenger tires with a low load rating,
Personally, I don't see a battery that doesn't like below freezing temps or that is terrifically expensive an upgrade. Essentially if it doesn't provide twice the performance of a flooded AGM for twice the price, it isn't an upgrade, just an upcharge. If it costs 9-10 times more, it better give 9-10 times the performance. And of course the battery has to burn power in order to keep itself warm on cold nights, huh?
I know that spending as much money as possible is an important part of #VanAndTitsAndAssLife though, at least if you have a sponsorship. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Last edited by nemobuscaptain on Sun Nov 29, 2020 2:38 pm; edited 1 time in total |
Posted: Sun Nov 29, 2020 2:38 pm Post subject: Re: Lithium Battery Upgrade |
nemobuscaptain wrote: |
I notice some people toss around upgrade pretty loosely. For instance they say they are UPGRADING to 16 wheels so they can added UPGRADED passenger tires with a low load rating.
Personally, I don't see a battery that doesn't like below freezing temps or that is terrifically expensive an upgrade. Essentially if it doesn't provide twice the performance of a flooded AGM for twice the price, it isn't an upgrade, just an upcharge. If it costs 9-10 times more, it better give 9-10 times the performance. |
Haha. Agreed. Pretty hard to improve on the stuff it came with from Hannover 30-50 years ago. Tires and oil would be the exceptions.
I see Porsche Motorsports has an improved battery for racing modern 911 type cars. Lithium, about 1" tall. A cool $1000.
Not for me. I need a starting battery more like a boat anchor. Both for my type2 and my 911.
Upgrade indeed. _________________ Al Brase
Vanagons:
Posted: Sun Nov 29, 2020 2:51 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
It depends on how much time you spend off-grid. We've been hard on these batteries for 2 years and they are such a game-changer. Unless you have experienced it, it's hard to say.
We wouldn't be able to work remotely from our Bus if it wasn't for these batteries. The fast recharge time and more usable energy is like night and day difference compared to other deep cycle batteries
That said, we totally understand that this isn't the right fit for everyone.  _________________ Around The World in a VW - Follow the Docuseries
2011 - 20Something
Posted: Sun Nov 29, 2020 3:44 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
I rarely travel off grid, unless Uncle Sam made me. When in my VW busses, I always have an alternator with me. |
Whats a nater? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
