King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1386 Location: Southern California
Posted: Sun Nov 29, 2020 9:19 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
My 61 tank had the vent on the filler neck. We made it a -6 when the tank was new. I did a stainless pig tail and vented it down to the ground _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
RickS Samba Member
Posted: Mon Nov 30, 2020 5:10 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
If any fuel sloshes into that vent it will get trapped at the bottom of the pigtail. It will not take much to block off the air from passing, just like a plumbing p-trap. |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1268 Location: Lancashire UK
Posted: Mon Nov 30, 2020 6:19 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
When I fit a tank, I don't fit those in tank screens on the end of the pipe. Let a good filter do the job.
I fitted a CB return to tank fitting as an outlet. Granted, mine is a return to tank system but you could block one of the ports and just use it as an out let. It enables me to use a 13mm barb fitting and 13mm pipe to feed the pump. There is a filter before the pump so very little restriction before the pump takes over. Fuel cap is vented 13mm too.
Last edited by GARRICK.CLARK on Mon Nov 30, 2020 10:10 am; edited 1 time in total |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Mon Nov 30, 2020 10:08 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
I welded a -8 fitting to the filler neck similar to King, but used a Jaz roll over valve.
https://www.jegs.com/i/JAZ-Products/547/834-208-06/10002/-1
Jeff, what size vents are you running? _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3649 Location: Paradise, Ca
Posted: Mon Nov 30, 2020 9:19 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
GARRICK.CLARK wrote: |
Hey Jp what's the fuel ratio with WOT at the end of the track. Running out of fuel at the end will show it go super lean on the gauge. |
I made a mistake when I only answered your question with just the 1 answer. I should have also mentioned that its not just at the end of the track in 4th gear, its in every other gear also starting at 4k like clockwork as its a carb tuning issue, not fuel supply to carbs or venting. But it was cool never the less to get some ideas from you, ivkings and Hotstreet
Every gear goes like this:
idles 13:1 to 2500rpms then 11-12:1 mains(170 with F2) to 4k and airs 13.8-14:1(1.7) from 4k and up.
My 4k up is lean, but it started at 15.8 when I first put the wideband on and I worked the airs down from 2.0 to 1.7 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Mon Nov 30, 2020 9:37 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
try some F-11 tubes. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jpaull Samba Member
Posted: Mon Nov 30, 2020 10:03 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
Thanks David, I will give those F11s a try.
Hotstreet, I had 36 vents in before, and went to 38s and it really liked those. Has the same bottom end as the 36s but pulls even harder above 4500 with the 38s. I have notwanted to try 40s unless i get more cam, and something larger then my current 1 5/8 exhaust. Worried I might lose some streetability. what say you? |
jpaull Samba Member
Posted: Mon Nov 30, 2020 10:10 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
Had our #3 Child just a few hours ago. Esther Paull is healthy and doing well. When we found out she was gonna be a girl, we thought of one of the most inspiring books in the bible for women(while also hoping she will someday inspire others), and also thought maybe, just maybe, she might join the ranks of wonderful women that have contributed to High Performance VWs in some capacity. |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 2072 Location: North Carolina
Posted: Mon Nov 30, 2020 10:13 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congratulations to you, your wife and new daughter Jeff. All the best to you all! |
Wreck Samba Member
Posted: Mon Nov 30, 2020 10:31 pm Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congratulations , happy to hear all went well and Mum and daughter are healthy and well . |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2392 Location: DEEK - U.S.A.
Posted: Tue Dec 01, 2020 12:28 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congratulations to one cool daddy!!!  _________________ Jesucristo es mi Señor y Salvador! |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3591 Location: 802 The Pointless Forrest
Posted: Tue Dec 01, 2020 4:33 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Let us know when you get Esther on the dyno.
Congrats, three kids are the best.
"Will you stop touching me!" _________________ "Albatross"! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Tue Dec 01, 2020 5:02 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congrates , I have a 1 3/4 header collecting dust  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
jpaull Samba Member
Posted: Tue Dec 01, 2020 5:08 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Thank you Mark, Calvinator, fl59, Wreck, and MadMike I will PM you on that header  |
Bigjacksauto Samba Member
Joined: June 18, 2018 Posts: 225 Location: Syracuse NY
Posted: Tue Dec 01, 2020 5:42 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congratulations Jeff! _________________ https://www.facebook.com/groups/2778888602388847/?ref=share
1968 Beetle "Herbie" replica Father Son Project
1960 Beetle deluxe / Flint/Pebble Grey og 1200cc 36hp
1975 Westfalia bus sold
1967 SO 42 Westfalia Bus
(o\_!_/o) |
Posted: Tue Dec 01, 2020 6:12 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congrats Jeff and family |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Tue Dec 01, 2020 6:56 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
jpaull wrote: |
This is where a lot fall short of not using any type of a/f gauge. If you don’t know, you don’t know. You can’t tune what you don’t know.
Glad all is well with the baby. Congratulations! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Tue Dec 01, 2020 7:23 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
congrajimitations sir! _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP
c77owen Samba Member
Joined: July 07, 2017 Posts: 455 Location: Kansas City, MO
Posted: Tue Dec 01, 2020 8:12 am Post subject: Re: 1/4 Mile Results with Mild Stroker |
Congrats Jeff! Great choice in name and I love the reasoning! |
