Chubber Samba Member
Joined: November 12, 2003 Posts: 351 Location: Clermont, Central Florida
Posted: Fri Sep 23, 2016 7:05 pm Post subject: Re: Another Bus Resto picture book |
| jtauxe wrote: |
Great stuff! I like all the details, since I have a project bus in the queue that is going to need about 80% of the same work you have done, plus a nose panel replacement.
I am currently taking a class in welding, have got a MIG setup, and hope to be able to screw up the courage to get into it. Seeing some of the details you have shown here is very instructive, and I hope to learn from it. So... Keep it coming! I've bookmarked this one.
Keep going at it and don't be afraid to invest a few feet of wire in your education. The best teacher is practice and your second thousand feet of weld will be much better than your first thousand feet.
I just pulled the motor tonight and the heater boxes were patched with some of my very first welds, probably done even before I got gas. They are ugly, slaggy, zig zaggy and more than a few burn throughs. But they are still 99% solid 15 years later and are still giving good service. Nobody I know cares how smooth my heater boxes are, but I care if they work, so I just put on my big girl panties and did it. I learned a lot and I don't even think I'll redo them now that they are out on the workbench. _________________ Chubber
'71 Deluxe 7 Passenger Bus (Resto thread)
'72 Fastback
'74 Super Beetle Convertible (Sold) |
Posted: Fri Sep 23, 2016 7:14 pm Post subject: Re: Another Bus Resto picture book |
| cek347 wrote: |
| This is some hard work! Keep at it. I see threads like this is as very motivational. Thanks for taking the time to post and share. Keep it coming. |
Thanks. I still have some older work to post before I'm caught up, but tonight I just pulled the motor, next will be the first time the transmission has ever been out of the car. Then, while I contemplate transmission rebuild and replacement costs to my horror I'll be pulling the whole rear suspension for sandblast and paint. I still have some rear wheel arch rust outs to replace and some lower corner holes that I'm going to have to look at critically.
The good news is that the motor is fresh, less than 2000 miles on a new rebuild, and when I rebuilt it I also painted the whole engine compartment and gas tank area inside, so very little body work or paint will need to be done in there, though it does need a ton of cleaning. I'll probably repaint the exhaust, tidy up some engine stuff, but not much more there than I have to do.
So don't worry, there will be something to read about for a good while yet... _________________ Chubber
'72 Fastback
Posted: Mon Jan 30, 2017 2:39 pm Post subject: Re: Another Bus Resto picture book |
Playing catch-up on this thread, posting a bunch of work from the fall and winter.
Pulled the motor
and transmission. No troubles in either part. I'm evaluating the nose cone to see if I should press in new bushings. The trans has always worked well, just getting sloppy with old age and I suspect a lot of that is in the nosecone.
Ill probably press in a new main seal and clutch shaft bushing while I'm at it. Cheap parts, no better time to do them.
I pulled the whole rear suspension for sandblasting, priming and painting.
The rear apron wasn't in "bad" shape, but it was rusty with a few holes and a lot of surface bubbling.
I wire wheeled it down to see what the paint hid.
Just two little holes like this
Welded those up, ground them down and moved on to the rear engine hatch. _________________ Chubber
'72 Fastback
Posted: Mon Jan 30, 2017 2:48 pm Post subject: Re: Another Bus Resto picture book |
The rear engine hatch had a few rusty bits along the bottom, so I fabbed a new patch piece.
When I was done acid washing it, I didn't want to wait a week for the seam to dry out, so I torched it. Better than having water under your primer.
New piece templated with cardboard, cut and welded in place.
Did a first coat of epoxy primer, filled a bunch of pinholes and waves, then primed two more coats.
I had pulled the gas tank out in about 2000 after I had an engine fire. I cleaned up the tank and painted with Rustoleum paint.
Still looks great.
A coat of Dupont Centari inside the gas tank shelf still looks perfect.
I've got your typical small rust in the filler neck, what a painful place to sand...
The inside of the gas tank cover still has the carpet underlayment I glued on it 16 years ago.
PSA: Do yourself a huge favor and get one of this kind of face mask if working under the bus. It kept metric buttloads of grit, rust and paint out of my face and fits easily over the respirator. Not expensive either.
'72 Fastback
Posted: Thu Feb 02, 2017 8:05 am Post subject: Re: Another Bus Resto picture book |
After all that work I had to prime and then paint the bottom. I think there are more nooks and crannies in the rear end than the rest of the car combined. Every time I thought I had it all done I would shift 6" to the side and see a bunch of places I had missed. Paint, move, paint, rotate 180%, paint, move, paint, rotate 90 degrees, paint, move, etc.
The first thing I repainted was the fuel pipe. Just primer inside, it's impervious to gasoline but the black paint is only resistant, so I don't use it on the inside of anything.
Getting started with the painting:
I didn't spray this time because the weather was terrible and I didn't have the time to clear out the garage and put up the shower curtains. The brush worked well, at the expense of a disposable thrift store shirt.
Continue around
Corrugations, stringers, pipes, wires, struts, braces, they all hide spots to be overlooked and missed
Hangers too
My next welding job is to rebuild the wheel arch on the right rear. It's really not too bad, except for the forward edge under the C pillar, but it's curved in strange ways, so locating the seam won't be trivial. I might install the rear brake lines at the same time.
Off the body I'm going to drain the transmission, pull the nosecone and order the parts I need to refresh the bushings throughout. I've picked up a few parts along the way and I need to inventory my spares to find all the parts I'll need. _________________ Chubber
'72 Fastback
Posted: Tue Dec 01, 2020 8:55 am Post subject: Re: Another Bus Resto picture book |
Wow, I can't believe it's been 3 years since I updated this thread. I've made a lot of progress in the mean time and moved 2 years ago into a house much better suited for the work. But I'll go ahead and post some of the highlights here for the work I've been doing along the way.
'72 Fastback
Posted: Tue Dec 01, 2020 9:01 am Post subject: Re: Another Bus Resto picture book |
Once most of the body work was done on the outside, I cleaned it up and sprayed everything with white epoxy primer. You can see the big shower curtains I made to be able to spray inside my 2 car garage/workshop. Cup hooks and clothesline allow me to open and close it.
'72 Fastback
Posted: Tue Dec 01, 2020 9:07 am Post subject: Re: Another Bus Resto picture book |
While the paint dried and when I couldn't take sanding any more, I worked on "rebuilding" the transmission by replacing the bushings and gaskets in the nosecone and throwout bearing.
'72 Fastback
Posted: Tue Dec 01, 2020 9:15 am Post subject: Re: Another Bus Resto picture book |
I also "cleaned" the inside by filling with ATF that I had laying around, spinning the input shaft fast with a drill while tipping all around, then draining out. I think I did that 2 or 3 times until the ATF came out schpic-und-schpan. I also added magnets to both tranny plugs to help catch any metal dust.
I also removed the liners and insulation from the flexible air hoses, cleaned them up and painted them and removed any traces of asbestos gaskets or insulation.
'72 Fastback
Posted: Tue Dec 01, 2020 9:27 am Post subject: Re: Another Bus Resto picture book |
I found some more pics of metal replacement along the rear wheel arches.
'72 Fastback
Posted: Tue Dec 01, 2020 9:32 am Post subject: Re: Another Bus Resto picture book |
Now, on to the front of the right rear wheel arch. This was more complicated to fix on the inside than it was on the outside.
'72 Fastback
Posted: Tue Dec 01, 2020 9:36 am Post subject: Re: Another Bus Resto picture book |
I dipped everything in Masterseries primer, then moved on to work on dings, rust pits, etc on the rest of the rear end.
'72 Fastback
Posted: Tue Dec 01, 2020 9:43 am Post subject: Re: Another Bus Resto picture book |
I also took this opportunity to rebuild the shift rod. I replaced the bushings. I actually just take the old bushings, carve off the little button that sits inside the hole in the rod to keep it in place and push them back on the rod to help hold it centered in the tube near the middle. I feel like it supports it better so there is less flex near either end.
I also cleaned up the axle hubs and stubs and tapped the paint out of the mounting holes.
'72 Fastback
Posted: Tue Dec 01, 2020 9:53 am Post subject: Re: Another Bus Resto picture book |
More back brake work
Starting to come together underneath!
'72 Fastback
Posted: Tue Dec 01, 2020 10:04 am Post subject: Re: Another Bus Resto picture book |
Lubed the accel and E-brake cables before putting them back in
I picked up a used small oil sump to add, but the mounting flange was scratched, corroded and otherwise unsuitable for sealing to the engine. How to make flat again? Drill press + DA sander pad + 400 grit wet dry + oil.
I was trying t0 combine black and gray to get the off-black for detail parts. This looked good, but still not what I was hoping for.
'72 Fastback
Posted: Tue Dec 01, 2020 12:00 pm Post subject: Re: Another Bus Resto picture book |
Santa brought a surprise for 2017, a new house! Wife was flipping through Zillow one day and saw a house come up close by that had a unique feature that made my spidey sense tingle: Room to park 7 cars inside!
My garage hasn't been this empty since I moved in! The bus was the last thing to move. It took me more than 12 trips in my little HF trailer to empty the shop and attic of parts and supplies.
Fred is strapped in and ready to drive over to the new place!
The tow truck driver wouldn't back down the hill to the bottom driveway, so I "drove" while he ran off his recovery rope. Easy sailing.
Some pics of how much room is in the new "underground" garage. It's 2 cars wide and 49 feet deep. I cut off the end by the garage door with a plastic curtain to make a paint booth on that end.
First thing I did in the new place was pull the windshield and see how bad the rust was. I had rebuilt this with my first real welding on the bus back around 2004 or 2005, and I was curious how it had held up.
It looks worse than it really was. _________________ Chubber
'72 Fastback
Posted: Tue Dec 01, 2020 12:10 pm Post subject: Re: Another Bus Resto picture book |
More windshield work. Where I had fixed it last time was mostly still solid, some new rust holes had started to develop. Some was only solid on the top, but as soon as the welder it it, it burned through, rusted on the back. I cut back to thick metal again and then closed it up. Lots of grinding, flap sanding, welding, repeat, repeat, repeat. Finally did phosphoric acid etch top and bottom, brushed on a couple of coats of epoxy, metal-2-metal filler, more epoxy, then blocked and filled and epoxy primer again.
'72 Fastback
Posted: Tue Dec 01, 2020 12:27 pm Post subject: Re: Another Bus Resto picture book |
More windshield pics
'72 Fastback
Posted: Tue Dec 01, 2020 1:29 pm Post subject: Re: Another Bus Resto picture book |
The next big job to work on was fixing up the front seats. They were all original, broken foam and springs and crushed horsehair and everything.
As you can see, one of the foam bolsters on the back of the seat had disintegrated. As far as I know, this is a NLA part. So I made one out of Great Stuff.
'72 Fastback
Posted: Tue Dec 01, 2020 1:33 pm Post subject: Re: Another Bus Resto picture book |
Some more seat pics. I made a couple of cutting mistakes and had some bubbles on the corners when I trimmed, so I re-filled some parts with foam and trimmed again.
'72 Fastback
