Rear Brake drive hub outside diameter?
MarkWard
MarkWard is offline
PostPosted: Tue Dec 01, 2020 3:35 pm    Post subject: Rear Brake drive hub outside diameter? Reply with quote
I could use a favor please. Could someone measure the OD of a vanagon rear brake hub for me? Only if you have one handy. An owner has brought us a rear brake disc conversion kit and the supplied discs are not centering at all. This van had a Ford rear brake conversion and I'm betting the original hubs have been cut down some. I'm measuring 5.498" Thank you in advance.
edit: asking about the outside diameter of the "splined drive" hub that the drum seats on.
DanHoug
DanHoug is offline
PostPosted: Tue Dec 01, 2020 5:09 pm    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
i've got an OEM drum out in the shed... would measuring the ID of the hole that goes over the hub help? it's a pretty dang tight fit.
EDIT: nevermind... i misunderstood. carry on.
-dan
www.thefixitworkshop.com
Franklinstower
Franklinstower is offline
PostPosted: Tue Dec 01, 2020 5:18 pm    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
I have ones that have been cut down to center Eurovan rear rotors, they measure about 5.7"
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Dec 01, 2020 8:14 pm    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
MarkWard wrote:
I could use a favor please. Could someone measure the OD of a vanagon rear brake hub for me? ......
Mark. I have a pair of hubs in a box, pretty easy to find, so if you need another set of measurements I'm more than happy to find and measure them tomorrow.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
MarkWard
MarkWard is offline
PostPosted: Wed Dec 02, 2020 5:43 am    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
Embarassed The owner saw this post. I should have reached out to him first. It didn't occur to me that he might know. He contacted me and sure enough these hubs have been machined down for the old Ford discs to work. If someone still has the stock measurement handy, that would be helpful. The directions specify a hub dimension of 5.728-5.708"
Vanagon Nut
PostPosted: Wed Dec 02, 2020 7:25 pm    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
My regular callipers are too small. Don't know how accurate a measurement you need so I posted pics.
Callipers "tight" to hub, (shown resting on housing and supporting themselves at hub flange):
6 - 21/32"
Neil.
(VW Gas I4)
VE7TBN
MarkWard
MarkWard is offline
PostPosted: Thu Dec 03, 2020 5:39 am    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
Neil, thank you. That answered my question. Based on your measurement the stock hubs would need to be machined down to fit the eurovan disks. Mark
Steve M.
Steve M. is offline
PostPosted: Thu Dec 03, 2020 8:24 am    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
What year Eurovan discs?
Rock Auto has the original Brembo drawing visible for the Eurovan discs on some of them to give inside diameters, but you probably have the diameter from measuring the disc.
Vanagon Nut
PostPosted: Thu Dec 03, 2020 10:41 am    Post subject: Re: Rear Brake drive hub outside diameter? Reply with quote
Glad it helps Mark and it sounds like even if my measurement was off by 1/16" or so, it doesn't matter. Those callipers were stiff to adjust hence the "tight" measurement.
I was surprised to see so few replies with measurements. Figured *everyone* must have a spare hub assembly lying around. Wink
Neil.
(VW Gas I4)
VE7TBN
