Horn button wiring?
ghiafreek
ghiafreek is offline
PostPosted: Mon Aug 01, 2005 12:07 pm    Post subject: Horn button wiring? Reply with quote
Now how does this wire up again?
I have one wire coming up the steering column and I've connected that to the underside of the horn button with that little screw.
Where does that wire go and what else needs to be done?
Right now I have a a button on the dash that activates the horn.
Thanks for your help,
ghiafreek
3Bugs
3Bugs is offline
PostPosted: Mon Aug 01, 2005 12:14 pm    Post subject: Reply with quote
A lot depends on what year you are working on. This link spells it all out for every year.
http://www.wolfsburgwest.com/wired/wired_12_00/wired_12_00.htm
Hope this helps
3Bugs
Well, actually a 67 Bug, 72 Super, 61 Ghia and a 2004 Beetle Vert (sorry)
ghiafreek
PostPosted: Mon Aug 01, 2005 12:21 pm    Post subject: Reply with quote
Its a '65 bus.
PostPosted: Mon Aug 01, 2005 1:57 pm    Post subject: Reply with quote
The horn wire goes straight from the horn button to the horn (or vice versa). It's a ground wire.
Live power goes to the other terminal on the horn.
DINK
DINK is offline
PostPosted: Mon Aug 01, 2005 3:32 pm    Post subject: Reply with quote
The wire just "fell out" of my horn button today. I swear. How does it fasten in there? Worked fine before. Crying or Very sad
66 Panel < 40,000 mi.
73 Std. Sedan
GBNF: 64 21 Window, 64 Deluxe, 73 Westy, 79 Bay, 84 GLI, 91 GL, 04 GLI, 87 Syncro Westy
60/15windows
60/15windows is offline
PostPosted: Mon Aug 01, 2005 3:36 pm    Post subject: Reply with quote
If you look real close you will see a tiny grub screw that holds it in there.
Dave SBS#UKI.
1960.15 Window Deluxe
1962. Crew cab
1962. 356 BT6
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Mon Aug 01, 2005 4:57 pm    Post subject: Reply with quote
mine works one time every once in a while... it will let out a short burst and thats it... no loose wires just wacky....
Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
campingbox Premium Member
campingbox is offline
PostPosted: Mon Aug 01, 2005 5:56 pm    Post subject: Reply with quote
Grease the connections with dielectric grease and grease where the horn push grounds out against the steering wheel. Make sure there ain't too much dirt inside the horn push.
dstefun
dstefun is offline
PostPosted: Mon Aug 01, 2005 10:59 pm    Post subject: Reply with quote
Sounds like the vibrator in the horn itself is getting stuck. Take the horn apart and clean it up. Easy to do and it will probably work for another 40 years. Wink
NorCalWeekender
NorCalWeekender is offline
PostPosted: Tue Aug 02, 2005 6:27 am    Post subject: Reply with quote
Where does the actual hot wire for the horn come down from? I think mine came apart some time ago and I'd like to get it working again. And yes, I know I can run a hot wire down from just about anywhere, I'm just wondering about the "factory" answer. Smile
-Taylor
9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Aug 02, 2005 6:48 am    Post subject: Reply with quote
True that! Unless it is one of them sealed newer units. I got me an old, bolted together horn for $5, ages ago. Didn't work, took it apart, cleaned up the contact points, and it's been working since! Razz
-Taylor
Check your proper wiring diagram, available from type2.com(?), to see the color code of the wire that comes off the loom. As EB points out, that would be the "live" wire, with the "grounding" wire completing the loop at the horn button. Wink
BTW, this wire comes down there along with the brake light sending unit ones. Cool
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Tue Aug 02, 2005 7:10 am    Post subject: Reply with quote
I'll pull it off tonight if it is not raining. and try and clean it out... it would be nice to have working. I have everything else working as of right now... thanks for the tip..
Chris
The SBS #62
timmaah
timmaah is offline
PostPosted: Tue Aug 02, 2005 8:11 am    Post subject: Reply with quote
and something i learned when trying to get mine to work... it has to be sitting sideways... not laying flat down to work... atleast mine did... it drove me made trying to figure what was wrong and the second i turned it on its side.. it started going off like mad...
dstefun
dstefun is offline
PostPosted: Tue Aug 02, 2005 10:50 am    Post subject: Reply with quote
Type2.com does provide a link to the vintagebus.com diagrams, but wiring diagrams are also available right here on theSamba... thanks Everett!
http://www.thesamba.com/vw/archives/info/wiringt2.php
and direct from vintagebus.com .... thanks Thom!
http://www.vintagebus.com/wiring/index.html
In Taylor's case (and for all splits 62 & later), the horn wire is a 1.0 mm2 (#16) black/yellow wire off the bottom of the #8 fuse. 56-61 bus horns connect to the bottom of the #1 fuse.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Aug 03, 2005 6:24 am    Post subject: Reply with quote
Thanks dstefun! With all that homework done, these guys should be "horning" soon! Laughing
davebuckholts
davebuckholts is offline
PostPosted: Wed Aug 03, 2005 7:12 am    Post subject: Reply with quote
I've got two 6V horns wired to 12V............you hear me now????!!!!!
I solder the tip of the wire where the grub screw connection is to give the screw something a little more solid to grab.
My '66 RHD Japanese bug build..which has stalled!
http://www.thesamba.com/vw/forum/viewtopic.php?t=471759&postdays=0&postorder=asc&start=0
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Wed Aug 03, 2005 8:14 pm    Post subject: Reply with quote
ok pulled the horn tonight and took it apart... everything is clean and I think I put it back together correctly. I hear the contacts close when I push the hornbutton but it just makes a sound like I am dropping marbels in a tin can... maybe I reversed something when I took it apart? I saw an adjustment screw on the back that touches a bent peice of metal coming off the 12v side. any help would be great thanks... is there a tutorial on rebuilding or fixing a horn?
Chris
The SBS #62
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Fri Aug 05, 2005 6:58 pm    Post subject: Reply with quote
I took the horn apart again.. made sure everything was tight and dry... still all I get is the cluck when I hit the button. I know how the horn wires up... but how does it make the noise? what part causes the noise itself? Im sure it is but is it possible for the hore to just be plan old burned up? thanks again
Chris
The SBS #62
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue Jun 30, 2009 9:33 pm    Post subject: Reply with quote
Pulled the steering box out of the 67 today to clean it and noticed that the insulation is cracked on the horn wire where it exits the box. I'd like to replace that wire and I don't have access to my Bentley as it is in the bus, and the bus is up on a lift at my friend's house. I haven't taken the box apart and I don't want to only has 58k on it and is nice and tight--just clean, paint, adjust, re-lube and replace the wire. What is involved in replacing the horn wire?
Thanks all!
Kelly
Kelly is offline
PostPosted: Tue Jun 30, 2009 9:40 pm    Post subject: Reply with quote
is the old wire still in the steeringbox?
either way, you just run a wire through the steeringbox up to the steeringwheel. If the old wire is still in the shaft, splice the new wire to the old and pull the new wire up through the shaft, then cut the splice off. Another way is to use .32 safety wire (or similar) and run it down the shaft and attach the wire to the wire and pull it up through the shaft. No need to take the box apart.
easy money.
It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky
