lakeracer69 Samba Member
Posted: Sat Dec 05, 2020 7:33 pm Post subject: Type 1 case hardware sizes and quantity and torque values? |
I've looked around and haven't found a good resource for these. Maybe my Google Fu is weak.
Can anyone help me out. I don't want to buy a crappy hardware kit with a lot of stuff I don't need. I have a great fastener source nearby.
Thanks |
modok Samba Member
Joined: October 30, 2009 Posts: 27721 Location: Colorado Springs
Posted: Sat Dec 05, 2020 7:41 pm Post subject: Re: Type 1 case hardware sizes and quantity and torque values? |
I think the torque and thread sizes are in the manual, but you will have to count to get the quantity.
instead of the ancient 8mm nut and washers, I like to use JIS flanged nuts, no washers needed. Also does not "fall" into the socket. Or maybe should say works with all sockets...for those of you out there with five different kinds of sockets.
But if it is an OLD case where the washers have sunk into the metal, maybe it is better if you just get the same size washers that it had before, and stick them right back where they were. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Sat Dec 05, 2020 8:57 pm Post subject: Re: Type 1 case hardware sizes and quantity and torque values? |
PM me so i dont forget OP, i have a list of most the hardware sizes, grades, etc _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Posted: Sun Dec 06, 2020 9:56 am Post subject: Re: Type 1 case hardware sizes and quantity and torque values? |
'66 RIP |
