Beetle beam and Thing spindles
porkchop-rob
porkchop-rob is offline
PostPosted: Fri Nov 13, 2020 9:15 am    Post subject: Beetle beam and Thing spindles Reply with quote
I have a 68 beetle that we are building into a Baja for my son.
I have purchased a set of Thing spindles and Lower arms.
Can I use the beetle upper arms?
Can I use thing ball joints in the beetle upper arms?
Are the brakes and bearings different for the thing spindle?
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
tripicana
tripicana is offline
PostPosted: Fri Nov 13, 2020 5:42 pm    Post subject: Re: Beetle beam and Thing spindles Reply with quote
Yes, yes, no
foam cowboy hats aren't good helmets.
Bajadude
Bajadude is offline
PostPosted: Sun Nov 15, 2020 1:06 pm    Post subject: Re: Beetle beam and Thing spindles Reply with quote
tripicana wrote:
Yes, yes, no
No offence but the answer is actually: yes, yes, no, yes
what I mean is: bearings are not exactly the same as bug, they differ
dustymojave
dustymojave is offline
PostPosted: Fri Nov 20, 2020 11:40 am    Post subject: Re: Beetle beam and Thing spindles Reply with quote
Drums are different too, IIRC. They MAY be the same as 66-67 Bug 5-lug ball joint drums. I'm not sure how similar American Market and European Market Type 181s are. Wheel cylinders, backing plates and shoes should all be the same between Bug and Thing.
Richard
SoCalBajas Member
impaleale
impaleale is offline
PostPosted: Sun Dec 06, 2020 8:01 pm    Post subject: Re: Beetle beam and Thing spindles Reply with quote
You can put big drums on the Thing spindle just fine. The thing drum is just thicker. I used a thing chassis when I built my dune buggy. Thing ball joints and arms are way better than bug. Worth it.
