Slider door difference between power locks and non power?
4mymalamute
4mymalamute is offline
PostPosted: Wed Dec 09, 2020 7:57 am    Post subject: Slider door difference between power locks and non power? Reply with quote
I am about to purchase a slider door off another late model van (my syncro is a 1989)...question though...I have factory power locks and not sure the donor door had them (all items are stripped off the door). Is there a way I can see if it did OR if it did not, can I just switch over all my components from original door to donor door? Thanks for the clarification.
1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
1969 Bucky the Bug Convertible...red, rusted, work in progress....LOTS of work.
Timwhy
Timwhy is offline
PostPosted: Wed Dec 09, 2020 8:28 am    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
Looking at my 87 w/o power locks and my 91 with power locks. The 91 would have mounting holes under the door light switch plunger for the power contact panel and the 87 w/o has no additional holes.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Timwhy
Timwhy is offline
PostPosted: Wed Dec 09, 2020 8:34 am    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Dec 09, 2020 8:43 am    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
Tim(why?)
I've purchased a contactor pad you show in the door for a project, not for power locks. I still need to find the pin/spring plate for the frame, I suspect it may be similar to another VW/Audi part... Could i beg you to take a picture of the frame side, please?
Thanks,
-bobby
ZsZ
ZsZ is offline
sliding doors with power lock have a cutout for the contact plate and a welded in bracket to hold the actuator
You can cut out the hole measured from the old door and you can buy a bracket:
https://www.brickwerks.co.uk/cdl-bracket-kit-t3-sliding-door.html
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
kiltedhiker
kiltedhiker is offline
PostPosted: Wed Dec 09, 2020 10:42 am    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
Bobby,
Is this what you are looking for?
Steven
1989 Syncro Westfalia (bought new) sold
1990 Syncro Westfalia sold
1990 Syncro TinTop
PostPosted: Wed Dec 09, 2020 12:56 pm    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
Steven, yes perfect!! Thanks! (now I need to see if there is a hole already in that spot on my frame, or if the holes/threads need to be cut)
-bobby
4mymalamute
PostPosted: Wed Dec 09, 2020 2:55 pm    Post subject: Re: Slider door difference between power locks and non power? Reply with quote
Thank you for the pictures and clarification. I will check the slider and see if it has it cut out already...I hope so.
Thanks again everyone.
