1915 Build Suggestions
Page: 1, 2, 3, 4  Next
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 12:36 pm    Post subject: 1915 Build Suggestions Reply with quote
I've scored a good deal on a case/crank/rods/P&C all set for 94mm. I already have a Vintage Speed 1.5" sport exhaust and dual Kads. I need to decide on what cam to use and whether to stick with the Kads or try different carbs. For heads, I'm pretty set on Steve Tims ported super stock, but also open to suggestions. Sorta thinking Web 218 for the cam, but interested in what everyone has to say.
74 Super
84 Westy
UK Luke 72
UK Luke 72 is offline
PostPosted: Fri Dec 11, 2020 12:58 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Scat c45 with 1.25?
I'm gonna build a 1915 for a mate with Mofoco Rasser heads, looks like it'll be getting the c45.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 1:46 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
c45 may be a little too hot.
74 Super
84 Westy
UK Luke 72
PostPosted: Fri Dec 11, 2020 2:02 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Sorry just re read and saw the super stock heads.
I think Brian E will have some nice suggestions, and would likely be able to supply some very good heads too.
Brian_e Premium Member
Brian_e is offline
PostPosted: Fri Dec 11, 2020 2:32 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Haha. Thanks Luke.
I have posted this before, but one of my favorite engines was a 1915cc with Kads. I drove it for about 5000 miles before I sold the car to a buddy in Denver. He beats the snot out of it frequently.
Here is my combo.
Used case, fully machined.
CW 69mm crank
stock rods
AA 94mm P&C's, with my cylinder prep.
My 37x32 heads, [email protected]" and 28", 63cc port volume.
web 218/119, advanced 2deg.
aluminum push rods, solid shafts
9.0cr., .040" deck
AA 1 1/2" sidewinder and muffler
40mm kads, 32mm vents, welded and ported aluminum manifolds, scat linkage
Super simple, and people don't suspect much from the Kads, but it works good.
I want to do the next version of it, and it will be about the same, but it will have a web 163 w/1.3 rockers, 9.2cr, china 40 IDF's with 32mm vents, and a VS muffler. It should make it pull a bit higher RPM, and hopefully be just about as strong down low.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 2:40 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Brian_e wrote:
Haha. Thanks Luke.
Which heads are yours?
74 Super
84 Westy
jimmyhoffa
jimmyhoffa is offline
PostPosted: Fri Dec 11, 2020 2:41 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Brian,
That is EXACTLY my engine, but replace the Kads with a single 44mm IDF with 30mm venturis. I currently have 40x35 heads, but am exchanging them for heads nearly identical to what you describe. Even down to the degrees of cam advance, that is my setup.
I have been very happy with it, it sees the 5800RPM limiter pretty often. I have stock rockers with Porsche 911 adjusters and it is a very quiet engine. I am the type that likes to play around so I don't build the same thing twice, but I could almost be convinced to build another one of these.
Based on our intakes, I'm probably making a little under 100hp and you're probably making a bit over 100.
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
mcdragracer
mcdragracer is offline
PostPosted: Fri Dec 11, 2020 2:44 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
I'd recommend dual Weber IDF or better yet dual dellorto 36 mm or 40 mm dual carbs
Alstrup
Alstrup is offline
PostPosted: Fri Dec 11, 2020 3:09 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
CW 69mm crank
stock rods
9.0cr., .040" deck
Brian
X2.
However, the ubiquitous panchito´s would also be a good choice due to the nice fast ports.
Also, I fully agree on the work needed in/on the manifolds. Most of the Kad manifolds on the market are awfull out of the box. I once picked up 17 hp and 20 Nm torque on a customer´s 2007 Kadron fed engine just by welding, porting and correcting his Empi manifolds. He said that if he did not know better he would think I had built him another engine.
Dual 40 Idf or Dell will definitely give you a smoother lower rpm band, but Kads work too, and are simpler.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Dan the workingstiff
Dan the workingstiff is offline
PostPosted: Fri Dec 11, 2020 3:27 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
I don't feel this will hijack the thread. If 45's were sitting on the shelf screaming out to be used what jetting and venturi's? Or would these be too large?
'69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 3:39 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Ok so sounds like the kads with web 218/119 split duration would be a good fit with this 1915.
For heads, should I stay with stock size or go with 40x35.5?
74 Super
84 Westy
Alstrup
Alstrup is offline
PostPosted: Fri Dec 11, 2020 4:14 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Depends on which 40 x 35´s. Like I wrote above, the Panchito´s were a good option. At 9-1 it will rip.
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 5:39 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Looks like they can be ordered with port matched manifolds for IDFs. Nice.
74 Super
84 Westy
sled
sled is offline
PostPosted: Fri Dec 11, 2020 6:12 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
yes, and this will be an awesome combo...but of course no kadrons then (which I would suggest getting rid of anyway Very Happy )
drive your split.
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 6:16 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
That was probably inevitable anyways.
74 Super
84 Westy
Alstrup
Alstrup is offline
PostPosted: Fri Dec 11, 2020 6:17 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Sure, Kadrons can work well too. Don´t be so affraid of those. They just need to be trtimmed properly like (almost) everything else
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 6:19 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
So panchitos 044 vs mofoco 042 vs tims stage 1... what wins?
74 Super
84 Westy
Alstrup
Alstrup is offline
PostPosted: Fri Dec 11, 2020 6:35 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
For all round driveability and overall performance, the Panchito´s
For all out power, the Tims stage I (These also work well on larger displacement engines)
For best cooling (after some work put into them for correcting the air bypass and deflector) the 042.
And btw. ALL aftermarket heads need to get the deflector plate installed. I don´t know why they have left it out (?) - Price most likely.
boxer74
boxer74 is offline
PostPosted: Fri Dec 11, 2020 6:36 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
Good to know. Or cool tins?
74 Super
84 Westy
Alstrup
Alstrup is offline
PostPosted: Fri Dec 11, 2020 6:40 pm    Post subject: Re: 1915 Build Suggestions Reply with quote
No. Two different things
Page 1 of 4
