bouncing speedo needle
space
space is offline
PostPosted: Sun Jan 03, 2021 6:24 am    Post subject: bouncing speedo needle Reply with quote
While under the van I saw the speedo box was not mounted (fixed)
While driving I noticed the needle jump from 65-85 mph
Using my tach as reference I was travelling approx 70mph
Any ideas or fixes for this?
T
DuncanS
DuncanS is offline
PostPosted: Sun Jan 03, 2021 6:36 am    Post subject: Re: bouncing speedo needle Reply with quote
Your speedo cable is failing. Replace it.
MarkWard
MarkWard is offline
PostPosted: Sun Jan 03, 2021 7:07 am    Post subject: Re: bouncing speedo needle Reply with quote
There is a longer cable that bypasses the counter box if you decide to replace it. Available from all 3 vendors.
You can connect the cable to a drill to simulate moving. Also verify the cable is not in a bind or pinched by the spare.
wesitarz
wesitarz is offline
PostPosted: Sun Jan 03, 2021 8:52 am    Post subject: Re: bouncing speedo needle Reply with quote
The cable is greased inside the counter box. I would try cleaning it out and regreasing it. Maybe can test how the lower cable spins with the wheel off the ground.I've put lube down the cable from the speedo end for small bouncing.
Steve M.
Steve M. is offline
PostPosted: Sun Jan 03, 2021 9:39 am    Post subject: Re: bouncing speedo needle Reply with quote
Find a tune on the radio that matches the bouncing needle drive on.
