William Crowell Samba Member
Joined: February 15, 2011 Posts: 71 Location: Placerville, CA
Posted: Sat Jan 16, 2021 9:47 am Post subject: T5 resto back on track; now I know where all that grease went |
After some delay, I am removing the final parts from my T5 in order to take it to the abrasive blaster.
My references are the Charlie White (RIP) FSM reprints, Henry Elfrink, Harry Pellow, Floyd Clymer and Autopress LTD.
When I used to grease the front end, I always wondered where all that grease went. Now I know: into the axle tubes. I managed to get the torsion bars out, and the needle bearings out of the ends of the tubes, but so far the plastic bushings don't seem to want to come out. There's still too much grease in there to see what's going on right now. I need to clean all the grease out so I can see the plastic bushings and whatever else is still inside, and because otherwise the abrasive blast will stick to the grease. This has to be one of the worst parts of a Porsche or VW resto.
So while I continue to clean the grease out, can anybody give me any suggestions about how to remove the plastic bushings? Also, are there any other parts inside the axle tube that I haven't discovered yet? Thanks a lot.
P.S.: After I removed more of the old grease, I discovered that you can't get the fiber bushings out until you remove the 4 grease nipples that protrude a little bit into the axle tubes. The center clamping piece is also still in there, and I guess you use that to drive out the fiber bushings(?)
Last edited by William Crowell on Wed Mar 10, 2021 7:13 am; edited 1 time in total |
Starbucket Samba Member
Posted: Sat Jan 16, 2021 3:51 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
Can't you put expanding rubber plugs in the end of the tubes to keep the grit out? I don't think the inner bushings see that much wear as there is little weight on them that's why Porsche didn't put needle bearings there I think. |
Posted: Sun Jan 17, 2021 8:53 am Post subject: How do you spell "relief"?: off to the blaster and body shop! |
I used a long pipe to drive against the front axle tube center locking pieces in order to remove the fiber bushings.
Rear torsion bars are out now, too.
I've owned this car since 1973, when I was 26 years old. In the '80s I replaced the longitudinals, but I remember that the heat/defrost pipes and their supports inside were all rusted out. I didn't fix them at that time, and of course the heater and defroster never worked right. I'm going to fix them now.
I'm going to cut the longitudinals off today. I'll bet it will be Rust City inside.
Thanks starbucket for the tip on capping off the axle tubes before blasting. Will do.
Posted: Thu Jan 28, 2021 7:42 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
The floor pans and unibody really weren't too rusty under the longitudinals, although the heater tube supports will need to be replaced.
I finally got every last thing off the body. That certainly was time-consuming and a lot of work. Wait, there is actually one more small doohickey that I wanted to ask you guys about before I remove it: what is that small, square electrical connector(?) at the top of the firewall (behind the dash) on the extreme left of the driver's side? I can post a picture if you need me to.
Now I'm just waiting for a break in the rain before taking the body, doors, hood, deck lid and bumpers over to the sandblaster.
After inspecting several cars they are working on, I am very impressed with metal finishing skills of Lance and Josh Lighthall of Lighthall Classics in Shingle Springs, CA. They are obviously able to bang and shrink that metal to make it go just where they want it to, and their painting skills are top-notch. They do like that base/clear paint, though, because it is so danged much more shiny than single stage, and all the other resto shops seem to be using it. What think you on that issue?
They have just about convinced me to shoot the underbody with PPG Delfleet One over DP90 epoxy primer, which is normally shiny and very, very un-stock-looking. Have you ever seen any 356s whose undersides were painted this way? The argument is that it preserves the car better, since the original factory undercoat didn't work very well; viz., so many of them rusted out. Any suggestions about how I should tint the Delfleet to make it look just a little bit more stock, so it won't be quite so glaringly glossy? |
Posted: Thu Jan 28, 2021 8:10 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
William Crowell wrote: |
[/quote] I would use Woolwax undercoat on the underbody. |
Posted: Thu Jan 28, 2021 8:30 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
starbucket, if I understand the argument in favor of Delfleet correctly, it is that Delfleet prevents rust more or less permanently; while products like Woolwax will provide good protection for quite awhile, they don't last forever.
Now it is quite possible that I don't know WTH I am talking about, so if I need to be corrected, please let the lashes commence at this time.
I would like to hear everybody's comments about correctness vs. preservation, too. |
Posted: Thu Jan 28, 2021 9:54 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
Woolwax is a rust invertor and preventer so it will change any rust that was missed into a primer and it seals out oxygen to prevent future rust. Woolwax was designed for out door industrial equipment that gets banged around while epoxy based finishes will tend to chip if a rock hits it letting in moisture. |
ensys Samba Member
Joined: March 11, 2009 Posts: 322 Location: America's Automobile Heartland
Posted: Fri Feb 12, 2021 10:43 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
Mr.Crowell:
While I am not familiar with Delfleet, I should imagine that something could be added to its mix to flatten it some.
Of course, there is that rock-chip thing, and a paint-only finish is not the way they came from the Factory.
Why not do the "kill two birds" thing and thoroughly undercoat the bottom after the paint?
I don't know that I would use the stuff the Factory used (unless this is to be a Concours restoration). I went with a rubberized product. It sticks well to hard-shell paint and if applied correctly, its resilient nature will provide enough cushion to protect the integrity of the paint.
Just $.02 from the cheap seats... _________________ Keep 'em flying...
S.J.Szabo |
Posted: Sat Feb 20, 2021 7:18 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
After abrasive blasting, I discovered that the body had several problems that were covered with Bondo, and of which I was therefore previously unaware. And it does need floor pans after all. But having seen several examples of their work, I am confident that Lance and Josh Lighthall can make it like new again.
Last edited by William Crowell on Tue Feb 23, 2021 8:07 am; edited 1 time in total |
Posted: Sat Feb 20, 2021 7:35 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
S.J. Szabo said: "Why not do the "kill two birds" thing and thoroughly undercoat the bottom after the paint?"
Mr. Szabo, thank you very kindly for your reply. Your knowledge of 356s never ceases to amaze me.
I think the argument goes like this: Delfleet is so strong and hard that it doesn't chip when hit by rocks like ordinary paint does, so you don't need to apply any undercoating material over it. I'm not sure if this is entirely true or not, but I think it must be true to some extent if the big trucking companies are going to all the trouble of painting the undersides of their trucks and trailers with it.
In the past I have had undercoating (even bed liner) start to detach from the paint after a long time. Then water starts collecting in the space between the undercoating and the paint. At this point, I feel like I want to eliminate that water-collecting interface. However, as I pointed out above, I am still learning about this and am open to suggestions as to what brand of undercoating would continue to adhere, rather than starting to fall off after awhile. |
Posted: Wed Mar 03, 2021 12:56 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
Did you ever wonder exactly what the underside of the transmission tunnel looks like with the floor, the shift rod and all the cables removed?
Posted: Sun Mar 07, 2021 1:45 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
The floor pans are in, and a perimeter kit was installed.
Posted: Wed Mar 24, 2021 6:38 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
Lance and Josh are installing the longitudinals.
Posted: Wed Mar 24, 2021 11:50 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
Repairs were necessary in the longitudinal area.
Sebastian Gaeta Samba Member
Joined: December 25, 2003 Posts: 293 Location: Ann Arbor, MI
Posted: Wed Mar 24, 2021 2:50 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
William,
Very tidy work indeed, you have some real craftsmen on it!
Also a very nice touch with the German tubing in the longitudinals. _________________ Sebastian Gaeta
'63 Beetle Turkis
‘64 Karmann Ghia Coupe Manilagelb/Black Roof
'64 356C cabriolet Signalrot
'65 356C coupe Rubinrot
'66 Single Cab Velvet Green
'67 Karmann Ghia convertible Heliosblau |
Posted: Wed Mar 24, 2021 6:58 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
Just think if you had a Faro Arm and recorded all those joints, stiffeners, and all the other bits and pieces you could 3 D Print a 356. |
Posted: Thu Mar 25, 2021 4:21 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
"Very tidy work indeed, you have some real craftsmen on it!"
Yes, Lance and Josh are excellent metal men and painters who are deeply interested in 356s.
They are now installing new rocker panels.
Posted: Fri Mar 26, 2021 12:27 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
This has got to be very exciting and rewarding. Nice shot of the dash, I love the early T5 with no clock. Did your car come with the Porsche script on the nose? The first few hundred T5 cars had the script and they are a different size from the A nose script and are not interchangeable. Just curious. _________________ Sebastian Gaeta
'63 Beetle Turkis
Posted: Mon May 03, 2021 6:18 pm Post subject: Re: T5 resto back on track; now I know where all that grease went |
I got tired of Lance Lighthall promising to do a certain amount of work for a certain price, but then demanding more money before doing the work he had promised to do for the money already paid while denying that ever entered into the prior agreement. He refused to put anything in writing, claimed he was working on a monthly "salary draw" and refused to specify an hourly labor rate. So I brought the car back home and now I'm looking for a different restoration shop. The quality of Lance's work is OK, but his business practices suck big time.
Then when you tell him you want to take your car home, in order to change your mind he tells you he's going to assert a big mechanic's lien against it before he will release it to you. But after you agree to pay his claimed lien under protest in order to obtain the return of your car, he backs down and doesn't assert a lien against it after all because he is not registered with the California Bureau of Automotive Repair, so he is precluded from filing a lien under Business and Professions Code Sec. 9884.16. Of course he is supposed to be registered with the BAR. |
Posted: Wed Apr 20, 2022 10:44 am Post subject: Re: T5 resto back on track; now I know where all that grease went |
When Mr. Lighthall at first refused to register with the California Bureau of Automobile Repair as an automobile repair facility, the BAR issued a citation and an abatement order requiring him to cease working on customers' cars until he did register but did not assess any monetary fine for his failure to register. Later, Mr. Lighthall did register with the agency. Had Mr. Lighthall dropped the matter at this point, it would have remained a private citation; however (and somewhat inexplicably since no fine was imposed) he appealed to an Administrative Law Judge in the California Office of Hearings and Appeals, arguing that he was not subject to the registration requirements of the California Automobile Repair Act. We had our hearing before the ALJ yesterday, and the ALJ's decision will now become part of the public record. When I receive a copy of the ALJ's decision, and since it will be in the public record, I will post it in this thread. |
