OldSpice Samba Member
Joined: June 10, 2015 Posts: 178 Location: 87 syncro westfalia Subaru ez30
Posted: Tue Mar 09, 2021 9:22 am Post subject: Thinking of adding a speed control knob to sink pump. Thoughts? |
I don’t *think* I’ll run into any problems but thought I’d post here before I do in-case I’m missing something. I think I heard the sureflow faucet has adjustable flow or am I making that up?
I think my pump is on its way out anyways, I had to give it a vinegar bath and smack it to get it pumping again. can anyone recommend a good backup pump?
Current goal = 1. speed adjust knob to adjust water flow- + 2. foot button with separate on off switch to allow foot activation without accidental activation. 3. Maybe a new faucet for better articulation. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18743 Location: Retired South Florida
Posted: Tue Mar 09, 2021 9:29 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
Our Shure flow does regulate the flow on our 82. It has a submersible pump and I have deleted the city water connection. That was an accident waiting to happen. Plus it's one last thing to put away every morning when you hit the road. |
Posted: Tue Mar 09, 2021 10:00 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
Do you know if it regulates flow via physical construction or if it slows down the motor via voltage?
Yea I’m wanting to get rid of the water connections outside van but not sure what I should replace the boxes with- maybe a 12volt plug in for hooking up air compressors etc outside van. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2644 Location: Bay area CA
Posted: Tue Mar 09, 2021 10:03 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
It's purely a flow restriction. Works just fine. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Mar 09, 2021 10:04 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
Don't know that answer. Likely flow restriction vs lower voltage. It is light years ahead of the original. |
kourt Samba Member
Joined: August 13, 2013 Posts: 2314 Location: Austin, TX
Posted: Tue Mar 09, 2021 10:14 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
The Shurflo faucet commonly used to upgrade a Westfalia galley faucet has a binary switch attached to the valve for turning on/off the galley water pump. There is no rheostat to provide variable control voltage.
Any control of the water flow is done simply by the Shurflo's design as a valve; you can open the valve more to get more water (as much as the pump will deliver), or you can close the valve down to restrict flow and decrease the flow of water (but the pump is still working just as hard).
kourt |
fishgo Samba Member
Joined: June 21, 2018 Posts: 152 Location: Madison, WI
Posted: Tue Mar 09, 2021 10:15 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
OldSpice wrote: |
I had the original style on/off faucet with an aux foot switch which was a good combo. The faucet switch eventually failed (not the foot switch) and I replaced it with a ShurFlow. Wired in my foot switch too. Came to find out that the flow restriction is manual not electric, so the foot switch activates the pump but the faucet restricts flow. Oops. Disconnect the foot switch. |
kamzcab86 Samba Moderator
Posted: Tue Mar 09, 2021 10:34 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
kourt wrote: |
kourt |
This.👆🏼
If you want variable flow control, simply install a ShurFlo and call it good.🍺
_________________ ~Kamz
2016 Golf GTI S
Posted: Tue Mar 09, 2021 11:15 am Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
fishgo wrote: |
OldSpice wrote: |
Why disconnect the foot switch then? Seems like it wouldn’t have effected anything or am I missing how the faucet opens up? |
fishgo Samba Member
Posted: Tue Mar 09, 2021 12:20 pm Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
OldSpice wrote: |
fishgo wrote: |
OldSpice wrote: |
Foot switch activates the water pump, but the shurflow valve keeps the water from flowing (flow is blocked). You need to turn the knob on the shurflow to both activate and control flow. With the footswitch, a piece of luggage could bump against it and turn the pump on, but no water would flow. You might do some damage that way. |
Joined: January 01, 2007 Posts: 17833 Location: sticksville, ct.
Posted: Tue Mar 09, 2021 12:43 pm Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
MarkWard wrote: |
I have deleted the city water connection. That was an accident waiting to happen. |
can i ask why you say that? would the city connection blow the faucet to the moon? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Mar 09, 2021 12:46 pm Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
Water pressure varies from site to site, and if there was a leak during the night, the van would be full of water by morning. We have found the 12 volt pump and on board tank to be plenty for us. We fill it to the top of the yellow and we are good for a few days. Don't like to carry extra weight either. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Mar 09, 2021 1:01 pm Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
I will get to the question but first. We have the foot controlled switch arrangement sold by GoWe$ty and the Shurflo faucet, after adding a pressure bleed it has worked flawlessly.
But, a PWM controller coupled with a foot pressure controlled transducer would be the cats pajamas. Press lightly, low flow, press harder and more flow. All to replace 2 cents worth of copper strips.
Now to devise a 3 quart hot water heater that takes up zero space. _________________ Schau in das Buch |
Timwhy Samba Member
SCM Samba Member
Joined: January 26, 2011 Posts: 3366 Location: Bozeman MT
Posted: Tue Mar 09, 2021 1:37 pm Post subject: Re: Thinking of adding a speed control knob to sink pump. Thoughts? |
fxr wrote: |
It's purely a flow restriction. Works just fine. |
Unless the hose attached to the water pump isn't secured all that tightly in which case you can blow the hose off of the pump requiring an underwater repair in the middle of your camping trip at a time when you hands may or may not be very clean.
Just a heads up on that one.  _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
