Brake parts, what am i looking for
Lonesome Rider
Lonesome Rider is offline
PostPosted: Thu Mar 18, 2021 4:41 am    Post subject: Brake parts, what am i looking for Reply with quote
I ordered an received a new pedal set with brakes and hydraulic clutch etc. My stock set up has 4 lines going to the master cylinder for the brakes. This new master only has one inlet. What am i looking for to tie the 4 lines together so i can connect the lines to the new master cylinder? I don't know what to search for on here with out the proper terms. Thanks for the help
oprn
oprn is offline
PostPosted: Thu Mar 18, 2021 5:56 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
Interesting! Unless I am mistaken the stock system had 3 lines, one for the rear brakes and one each for the fronts. You will need a couple of "tees" to get yours to work. I take it that your new master cylinder is not a dual circuit one. It is likely intended for a sand rail with no front brakes.
Dale M.
Dale M. is offline
PostPosted: Thu Mar 18, 2021 6:02 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
Agree with OPRN statement on three lines.... One from each front wheel (left & right) and one from both rear wheels (teed together at rear)...
Probably going to need something like these "T" fitting to manage all the lines down to one...
https://www.belmetric.com/bubble-flare-c-17_564_11...-1109.html
Be aware it comes in several different sizes (10m or 12 m etc.)
Dale
Lonesome Rider
PostPosted: Thu Mar 18, 2021 6:56 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
Awesome thank you! I didn't know if there was a specific part to accomplish this. It is not a separate curcuit master, just a single brand new shiny one. Thanks for the tip about the sizing. I plan on building as slotted area so the whole pedal assembly can be adjusted so i'll have to use a flexible line at the end before going into the master cyl.
halfassleatherworks
PostPosted: Thu Mar 18, 2021 9:46 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
you need 2 T fittings and lines to hook up your brakes only. 3 if you need brake lights. also you are reverting to a single circuit, so a broken/failed line/part at any point will result in total brake failure.
stevebaz
stevebaz is offline
PostPosted: Thu Mar 18, 2021 10:25 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
you will need a brake pressure switch so you can hook up brake lights. like above you will need Tee fittings. the ports are usually 10MM bulb Tube fittings or 1/4 pipe if aftermarket off road. from the master cylinder you need tubing and terminate on the frame by the wheels where you to do hose for flexible connections. you will probably need 10 lb residual pressure valve in the line coming out of the master if you are using drum brakes.
https://www.appletreeauto.com/VW-BRAKE-SYSTEMS/BRAKE-LINES-and-FITTINGS/
cbeck
cbeck is offline
PostPosted: Thu Mar 18, 2021 11:10 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
The t goes to the rear, and the block goes to the front with a port left for the switch.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
Lonesome Rider
PostPosted: Fri Mar 19, 2021 5:06 am    Post subject: Re: Brake parts, what am i looking for Reply with quote
Thanks cbeck! Nice work on your project by the way
cbeck
cbeck is offline
PostPosted: Fri Mar 19, 2021 6:06 pm    Post subject: Re: Brake parts, what am i looking for Reply with quote
It's now living the high life in a 4 car climate controled garage on a local golf course.
