JoeE13 Samba Member
nsracing Samba Member
Posted: Sun Mar 21, 2021 4:41 pm Post subject: Re: Custom Oil valve removal tool needed |
That is like saying you have a leak in your roof but don't want to go up there.
REmove the pan and have at it. Geezehus man.  |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11672 Location: Oregon
Posted: Sun Mar 21, 2021 4:42 pm Post subject: Re: Custom Oil valve removal tool needed |
use a tap that fits snuggly into the bottom of the piston.
Taps are rather short and the threads can grip the hollowed out bottom of the piston.
Unless someone has a better idea. You'll need to remove the sump to get good access to the piston. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Sun Mar 21, 2021 4:52 pm Post subject: Re: Custom Oil valve removal tool needed |
Heat that area of the case with a torch and wiggle it around with a magnet until it falls out.
Or if you actually need to fix it in a hurry just start up the engine and rev it and it will probably remove itself.
or both
When I make new oil plungers I do thread the bottom for easy removal.
Partly worried that making them a tighter fit could result in them sticking more often, but that has not been a problem at all. It seems the problem is dirt, and dirt comes in all sizes. And the groove in a grooved plunger just adds another place for dirt to be.
IMO it's not going to help anything by expanding the bottom of the piston with your tool and ripping it out. Use heat and/or hydraulic pressure then no additional damage will be done. Put cardboard under it and watch the pill pressure guage/light.
There is also a vent hole in the lower end of that bore. Make sure it is there and open. Without that it won't work. And I guess you already drained the oil because it sure is clean. I don't understand why it isn't dripping. |
JoeE13 Samba Member
modok Samba Member
Posted: Sun Mar 21, 2021 5:59 pm Post subject: Re: Custom Oil valve removal tool needed |
I was thinking the vent hole below the plunger should be dripping, but maybe it only does that if the oil is filled up to the top mark.
you can see it here highlighted in orange, it's higher up than I pictured at first
JoeE13 Samba Member
modok Samba Member
Posted: Sun Mar 21, 2021 6:42 pm Post subject: Re: Custom Oil valve removal tool needed |
OK I think I've got it now.
Most people would jack up the REAR, of a rear engined vw car, thus the oil would be higher towards the flywheel, so it comes out that hole.
In your case I have no idea  |
Posted: Sun Mar 21, 2021 7:00 pm Post subject: Re: Custom Oil valve removal tool needed |
Set the engine on fire is your idea Modok?
If you have taken the pan off, you would have been done by now. |
JoeE13 Samba Member
74 Thing Samba Member
Posted: Sun Mar 21, 2021 7:53 pm Post subject: Re: Custom Oil valve removal tool needed |
| Quick starter crank with a big oil pan underneath and the piston should shoot out. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4577 Location: viroqua wi.
Posted: Sun Mar 21, 2021 10:56 pm Post subject: Re: Custom Oil valve removal tool needed |
| Would a blast of air work? Not sure of your set up. |
modok Samba Member
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1663 Location: Marshallville Ohio
Posted: Mon Mar 22, 2021 4:49 am Post subject: Re: Custom Oil valve removal tool needed |
1/4" NPT tap fits real nice in a plunger.
Just get it started and it will grab it and rotate it. You can then pull it out.. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Mon Mar 22, 2021 8:41 am Post subject: Re: Custom Oil valve removal tool needed |
| rework the tool or remove the sump. |
Posted: Mon Mar 22, 2021 8:42 am Post subject: Re: Custom Oil valve removal tool needed |
| rework the tool/shorten or lenghten, or just a longer bolt for it. or remove the sump. |
JoeE13 Samba Member
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Mon Mar 22, 2021 9:58 am Post subject: Re: Custom Oil valve removal tool needed |
I drilled a hole in my stuck one and pulled it out with a slide hammer. Then I just got a new one... _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
JoeE13 Samba Member
