Maine Samba Member
Joined: September 21, 2010 Posts: 153 Location: Maine
Posted: Tue Apr 13, 2021 2:02 pm Post subject: Propane Gas Detector |
| I recently installed a Propex heater. So I've also added a propane gas detector. I have a house battery under the sink. Where is the best place for the detector? |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
DanHoug Samba Member
Joined: December 05, 2016 Posts: 6022 Location: Bemidji, MN
Posted: Tue Apr 13, 2021 2:54 pm Post subject: Re: Propane Gas Detector |
please please please also install a CO detector with a digital readout. most of us own one of the best propane detectors... our nose, but CO kills time and time again and there are really good battery operated CO detectors for around $65 or less.
i've got one in my Westy and the using the stove will spike CO readings. interestingly, using the Buddy heater does not. _________________ -dan
www.thefixitworkshop.com |
jimf909 Samba Member
Posted: Tue Apr 13, 2021 7:00 pm Post subject: Re: Propane Gas Detector |
Agreed on the CO detector. You can't read the numbers in this photo but they're more informative than a binary detector.
Lighting the stove can definitely prompt a reading some times.
[img][/img] _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
erste Samba Member
Posted: Tue Apr 13, 2021 7:40 pm Post subject: Re: Propane Gas Detector |
| DanHoug wrote: |
| please please please also install a CO detector with a digital readout. |
You made a point in another thread that the dual CO/LP alarms aren’t ideal. What’s your reasoning there?
| jimf909 wrote: |
| Agreed on the CO detector. You can't read the numbers in this photo but they're more informative than a binary detector. |
And to both of you, how often are you really checking the digital readout?
I’m not knockin it in any way, just trying to understand how practical it is to use and pay attention too.
After Maine’s earlier thread I ordered a surface mount MTI alarm to replace the one I have that’s up near the driver’s B pillar, and installed it yesterday under the rear bench as suggested by Timwhy in that other thread.
Posted: Tue Apr 13, 2021 10:00 pm Post subject: Re: Propane Gas Detector |
| erste wrote: |
| jimf909 wrote: |
Despite what follows, I'd say a CO monitor is a great of device to monitor lightly until the alarm sounds at which point it deserves some attention. The indoor/outdoor thermometer and battery volt meters get more attention. Certainly, any drivetrain monitors get much more attention.
I'm 100% certain that my experience this past year is unusual. I installed the CO detector maybe 18 months ago. I made the van my wfh office at the start of COVID and I've spent at least 250 8-10 hour days in the van since then (days, not nights). Every day I light the stove a few times to boil water to warm my coffee cup or make tea so I probably have 500 - 750 or more stove lightings while sitting in the rear bench while on a MS Teams meeting (think zoom if you don't know Teams) while I stare at the CO detector.
I've experimented with lighting one burner, two burners, waiting 10 seconds, 20 seconds, etc. before lighting the burners. Sitting in a closed van I notice it when the the CO detector reads 75 but opening the slider for 30 - 60 seconds drops the reading pretty quickly.
In short, nowadays I check it way too frequently but it's for science. When camping, I might notice it occasionally and have it provide peace of mind before turning-in (it's also a smoke alarm).
TMI: Over this past year I've parked my wfh van office in a few states, mostly WA and ID. Most days it's been plugged into shore power near a house that I commute home to at the end of the day. As a recovering workaholic I prefer to keep work outside of my home to keep me from working 18/7. The van has been an ideal solution for me and the 40' commute is the best ever. _________________ - Jim
| Butcher wrote: |
Guilty as charged.
Abscate Samba Member
Joined: October 05, 2014 Posts: 24521 Location: NYC/Upstate/ROW
Posted: Wed Apr 14, 2021 3:56 am Post subject: Re: Propane Gas Detector |
Double check that those monitors are suitable fir use in your temperature range. If the device is only specified for household use, it may be being stored out of its range for those in real climates. For safety equipment,, you want to stay in specs or have some method of testing it, like running your stove with the windows closed. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Wed Apr 14, 2021 7:42 am Post subject: Re: Propane Gas Detector |
| erste wrote: |
| DanHoug wrote: |
You made a point in another thread that the dual CO/LP alarms aren’t ideal. What’s your reasoning there? |
LP is heavier than air an sinks so an LP alarm should be mounted in a low spot in living areas and even in a crawl space or basement. As an example, I'm looking at an underground propane line right now that enters a house about 18" above grade, code calls for the crawlspace vent about a foot away to be sealed off (it is) so if the propane leaks it won't flow into the crawl space. Nevertheless, a propane detector in the crawlspace of this house would be nice.
I've seen a wider variety of recommendations for mounting CO detectors but the most common one I found was to mount them 5' high because propane is lighter than air.
The different qualities of LP and Co suggest different installation points.
https://www.epa.gov/indoor-air-quality-iaq/where-s...appliance.
I'll let DanHoug chime in with facts. _________________ - Jim
| Butcher wrote: |
Guilty as charged.
Posted: Wed Apr 14, 2021 7:46 am Post subject: Re: Propane Gas Detector |
| Abscate wrote: |
| Double check that those monitors are suitable fir use in your temperature range. If the device is only specified for household use, it may be being stored out of its range for those in real climates. For safety equipment,, you want to stay in specs or have some method of testing it, like running your stove with the windows closed. |
Oy, can't I just watch the pretty blue display or go back to the days when we sat in cars w/out seat belts?
These safety devices are fairly remarkable. Now only if we can get them into houses where bbqs are used for heat. _________________ - Jim
| Butcher wrote: |
Guilty as charged.
