Posted: Thu Feb 14, 2019 2:42 pm Post subject: Re: Are all Ball Joints Created Equal? |
vwhammer wrote: |
ya might steer clear (no pun intended) of the generic 5 dollar tie rod ends and ball joints that you can find at Rockauto but, in my opinion, any of the mid priced units have worked fine for me and friends of mine.
We don't get too hung up on making sure all our crap is OEM, German made and all that.
Friend of mine has a MK4 Jetta with 340,000 miles that is practically a rolling Rockauto catalog and about the only time he has to replace a part ahead of a normal replacement time frame is when he crashes.
Its a commuter/autocross/track day/mountain twisty car.
He's pretty hard on it. |
A Vanagon ball joint is completely different in function than a Jetta/Golf ball joint. The Jetta/Golf ball joint you described sees very little vertical load whereas a Vanagon ball joint see a huge vertical load. In fact, a Vanagon ball joint has to carry the entire corner load of the van. Due to the strut design of the Jetta/Golf you described, the ball joint sees most of its vertical load from the anti-roll bar and never sees anything close to the entire corner load of the vehicle. It's apples to oranges...and there's a reason that Vanagon owners are concerned. When an owner has to pay a shop to replace a ball joint and that joint lasts less than a few thousand miles, which is exactly what happens with the lower quality lower ball joints mentioned in this thread, there's good reason to choose your ball joints wisely. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
?Waldo? Samba Member
Posted: Thu Feb 14, 2019 2:43 pm Post subject: Re: Are all Ball Joints Created Equal? |
YVwhammer, you'd better be knocking on wood as I believe your good luck is not the norm. I had one van on jack stands for a couple of months while doing a bunch of work on it. One of the first things I did was replace an upper ball joint. The boot cracked with zero miles on it before I even got it off the jack stands. |
Posted: Thu Feb 14, 2019 3:03 pm Post subject: Re: Are all Ball Joints Created Equal? |
Christopher Schimke wrote: |
vwhammer wrote: |
A Vanagon ball joint is completely different in function than a Jetta/Golf ball joint. The Jetta/Golf ball joint you described sees very little vertical load whereas a Vanagon ball joint see a huge vertical load. In fact, a Vanagon ball joint has to carry the entire corner load of the van. Due to the strut design of the Jetta/Golf you described, the ball joint sees most of its vertical load from the anti-roll bar and never sees anything close to the entire corner load of the vehicle. It's apples to oranges...and there's a reason that Vanagon owners are concerned. When an owner has to pay a shop to replace a ball joint and that joint lasts less than a few thousand miles, which is exactly what happens with the lower quality lower ball joints mentioned in this thread, there's good reason to choose your ball joints wisely. |
Thanks for that Chris. That's a very astute observation that I hadn't thought about before. Yup, with the vanagon, the spring pushes on the lower control arm so most of the weight of that corner of the vehicle is pushing on the ball joint all the time. In contrast, the jetta has the strut (with spring above) pinched into the steering knuckle so basically none of the weight of the vehicle pushes on the ball joint and the ball joint and lower control arm are just hanging out unless the sway bar is pushing on them. |
Franklinstower Samba Member
Posted: Wed Aug 14, 2019 10:20 pm Post subject: Re: Are all Ball Joints Created Equal? |
My upper joints were replaced with meyle or febi a few years ago, I just noticed I basically have no boots left, completely shredded. So I bought some lemforders.
What isn't made in China in a German box these days?
I just hope the boots last more than a few years. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6364 Location: Honolulu,Hawaii and France
Posted: Wed Aug 14, 2019 11:13 pm Post subject: Re: Are all Ball Joints Created Equal? |
I think I posted somewhere about thesea few months back.
They seem ok, the lower ones are still made in Germany, but for how long?
For the boots, keep dreaming
I bought a few urethane boots to try but didn`t fit well enough, from obscur cars.
I have urethane boots for the tie rod ends, I got a company willing to mix molds from other customers and we made a few of them kinda in stealth mode. They`re great, no failure so far nor signs of aging on all the vans I mounted them on. Only positive feedback from the few people who bouht them for themselves.
I`m saving cash to afford a mold for the cv boots, stock size, next is the ball joint boots... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu Aug 15, 2019 9:47 am Post subject: Re: Are all Ball Joints Created Equal? |
ALIKA T3 wrote: |
I`m saving cash to afford a mold for the cv boots, stock size, next is the ball joint boots... |
Sweet, Thanks Alex. Keep us informed!
At least the "Lemforders" I purchased were only $9 each on FCP Euro.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
Wellington Samba Member
Joined: September 21, 2004 Posts: 1892 Location: Montreal
Posted: Fri Feb 28, 2020 3:32 pm Post subject: Re: Are all Ball Joints Created Equal? |
We can now add MOOG lower ball joints to the pile of trash.
I ordered some and they arrived with a stamped steel end plate just like the rest of the garbage available.
I called Moog to inquire on the change, the gentleman informed me that Moog does not manufacture this model, and buy it from a third party and resell it. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9811 Location: Mt Lemmon, AZ
Posted: Fri Feb 28, 2020 5:11 pm Post subject: Re: Are all Ball Joints Created Equal? |
My lower ball joints were fine but the boots had failed. For all the reasons above I was reluctant to install new, possibly inferior, parts -- so I just replaced the boots using a 'universal' polyurethane boot:
https://www.amazon.com/gp/product/B000CN5F14/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I packed them full of grease and so far (not quite a year) all seems well, i.e. they keep the grease in and the dirt out:
Vanagon Nut Samba Member
Posted: Fri Feb 28, 2020 7:11 pm Post subject: Re: Are all Ball Joints Created Equal? |
Ahwahnee wrote: |
Nice. Awesome tip. _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri Feb 28, 2020 7:16 pm Post subject: Re: Are all Ball Joints Created Equal? |
Vanagon Nut wrote: |
Ahwahnee wrote: |
Nice. Awesome tip. |
Indeed, much appreciated. _________________ Jim Crowther
Vespa GTS 300 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22672 Location: NYC/Upstate/ROW
Posted: Sun Mar 01, 2020 5:52 am Post subject: Re: Are all Ball Joints Created Equal? |
Franklinstower wrote: |
ALIKA T3 wrote: |
Paul |
And replacements are almost free... _________________ .ssS! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Apr 14, 2021 12:49 pm Post subject: Re: Are all Ball Joints Created Equal? |
I just received a pair of the made in Germany Lower Ball Joints with the cast steel bottoms.
These are being sold on eBay through the Pep Boys Store and labeled MOOG "K9111"
I just compared it to the Lemfoerder and it is the same 48mm dia.
https://www.ebay.com/itm/MOOG-Suspension-Ball-Join...d=76620059
Moog Lower Ball Joint K9111
Unfortunately, they are $51.00.
There is another eBay store that is showing the right picture, but they ship out a steel pressed in bottom ball joint.
https://www.ebay.com/itm/Ball-Joint-Front-Lower-fo...06f6440a2d _________________ This free advice is worth exactly what you paid for it.
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4802 Location: Bemidji, MN
Posted: Wed Apr 14, 2021 1:27 pm Post subject: Re: Are all Ball Joints Created Equal? |
watch the shipping... $30!! _________________ -dan
www.thefixitworkshop.com |
Mac_Daddy_Westy Samba Member
Joined: October 27, 2011 Posts: 154 Location: San Antonio, Tx
Posted: Wed Apr 14, 2021 1:56 pm Post subject: Re: Are all Ball Joints Created Equal? |
actually, shipping is about $16.05 with discount
_________________ '87 Westy with 2.5 Subi (auto trans) |
Posted: Wed Apr 14, 2021 2:49 pm Post subject: Re: Are all Ball Joints Created Equal? |
The Pep Boys ebay store says "Free 4 Day Shipping"...they just charge you $52.00 to cover the shipping cost! _________________ This free advice is worth exactly what you paid for it.
smeeegheeead Samba Member
Joined: February 19, 2021 Posts: 48 Location: Portland, OR
Posted: Wed Apr 14, 2021 6:13 pm Post subject: Re: Are all Ball Joints Created Equal? |
Find out who chissync is who reviewed them! Maybe they're a Samba member!
I'm going to be pissed if they are that price! _________________ This free advice is worth exactly what you paid for it.
Joined: January 01, 2007 Posts: 16890 Location: sticksville, ct.
Posted: Wed Apr 14, 2021 6:18 pm Post subject: Re: Are all Ball Joints Created Equal? |
https://www.google.com/search?q=misofad+review&...nt=gws-wiz
looks like they are a scam site.
either way...i have paid 800+ for a control arm in the past. 80 bux for a GOOD part is a deal in my book _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Apr 14, 2021 8:35 pm Post subject: Re: Are all Ball Joints Created Equal? |
Yes, but you can get it for less. See my links above. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Apr 14, 2021 9:29 pm Post subject: Re: Are all Ball Joints Created Equal? |
i saw that.
i'm going to call NAPA and see what they can do for me. i have a new set in there now, but i don't have high hopes _________________
Jake Raby wrote: |
Brian wrote: |
