How would u fix this?
AZ Landshaper
AZ Landshaper is offline
PostPosted: Fri Apr 16, 2021 1:43 pm    Post subject: How would u fix this? Reply with quote
My employee swiped the legs out from below a clients yard art. She wants it fixed. Isnt real picky about how but wants it back in the yard by jobs end. It’s some cheap ass brass alloy from China. Local welder said no luck. Another guy quoted me $600. I’m considering some repair involving jb weld. Not even sure that’s gonna work. Whadayathink?
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
Letterman7
Letterman7 is offline
PostPosted: Fri Apr 16, 2021 1:50 pm    Post subject: Re: How would u fix this? Reply with quote
2 part putty epoxy and mix some paint to blend the joint. Reinforce the tube with wood dowels going all the way from the legs to the body.
hitest
hitest is offline
PostPosted: Fri Apr 16, 2021 2:07 pm    Post subject: Re: How would u fix this? Reply with quote
Step one- take 100 pics of that thing because your client is the type to say, "You know that bill looks a little more closed than it did before..."
FU#5
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Apr 16, 2021 2:19 pm    Post subject: Re: How would u fix this? Reply with quote
I like the wooden pegs idea, but what happens if they fail from a hit and that thing lands on Fido! you will have even more problems!
It looks like the leg cavity opening is about a 1/2 inch. I would measure it, then buy a brass rod from a metal supplier or Amazon ($10 a piece). Insert each rod into the body and braze it in place. or epoxy them with a high end one. Then set the new rods into the legs using the same "adhesive" method or brazing. if brazing or adhesives are a no go. You can always drill a hole through the structure and the rod at the stubs and pin it with a 1/8" stainless steel rod. Like a mortised and pined wood joint!
Employees suck some times! Sorry man!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
busdaddy
busdaddy is offline
PostPosted: Fri Apr 16, 2021 2:43 pm    Post subject: Re: How would u fix this? Reply with quote
To explore Jim's idea a little more.....
If the leg openings as well as the holes on it's belly are somewhat round and have thick enough walls tap them for pipe thread and screw the legs on with a close pipe nipple.
Слава Україні!
Erik G
Erik G is offline
PostPosted: Fri Apr 16, 2021 3:04 pm    Post subject: Re: How would u fix this? Reply with quote
how about that fake weld stuff? I repaired a rear view mirror arm with it, the kind you use a torch with.
Erik G
Erik G is offline
PostPosted: Fri Apr 16, 2021 3:14 pm    Post subject: Re: How would u fix this? Reply with quote
this type stuff
https://www.harborfreight.com/8-piece-low-temperature-aluminum-welding-rods-44810.html
AZ Landshaper
PostPosted: Fri Apr 16, 2021 4:02 pm    Post subject: Re: How would u fix this? Reply with quote
I had a similar idea using rebar. Jb weld some rebar in the bottom piece. Let it dry. Fill 8” deep end sections of top piece with jb weld and mate the two before the top section is dried. Prepare to do some aesthetics work once it’s solid.
Sounds similar but w wood dowels. Rebar is plentiful in my work so scrapping up 2x6” long pieces of no 4 is not a problem.
I appreciate y’all validating my initial approach. I’ll post w my success/ failure.
Previously
and a 67 bug.
AirHead1966
AirHead1966 is offline
PostPosted: Fri Apr 16, 2021 4:17 pm    Post subject: Re: How would u fix this? Reply with quote
Here is what I would do:
1. Mark where the legs would attach to the underside on the bird.
2. Drill the underside on the marks and install to rivet nuts (nutserts, blind threaded nuts, whatever it’s called in your neck of the woods).
3. Plug the holes in the legs by hammering in some pressure treated wood. Go a couple of inches deep in the hollow leg. Cut the wood insert flush with the top of the legs.
4. Take a bolt that would fit the rivet nut, a couple inches long and cut its head off. Now you have a threaded nut that fits the rivet nut.
5. Drill a hole in the wood plug in the leg and thread in on end of the threaded rod you made by cutting the bolt head.
6. Now you have a leg with a bolt sticking out of it. Thread it in the rivet nut attached to the underside of the body. Done.
Chickensoup
Chickensoup is offline
PostPosted: Fri Apr 16, 2021 5:55 pm    Post subject: Re: How would u fix this? Reply with quote
Maybe stuff whatever size brass(if that's even the material), down the legs, and then braise the outside to the inner?
How expensive is an entire replacement bird?
Just an idea. I haven't any experience in that sort of thing.
Good luck
'65 Tourist Delivery Build
'66 RIP
Pez Premium Member
Pez is offline
PostPosted: Fri Apr 16, 2021 7:49 pm    Post subject: Re: How would u fix this? Reply with quote
I cant see a picture but need to know what this giant bird is.
But maybe give the bird a wheel chair if it aint got no legs
Chasing Squirrel's.
1971 Bay Window
1966 Baja
calvinater
calvinater is offline
PostPosted: Sat Apr 17, 2021 5:37 am    Post subject: Re: How would u fix this? Reply with quote
Cannot see picture either, why did your employee steal the legs from the art?
"Albatross"!
PostPosted: Sat Apr 17, 2021 10:57 am    Post subject: Re: How would u fix this? Reply with quote
Non-VW photo was removed from the gallery so it went dead
Post it on imgur.com or somewhere
VW_Jimbo is offline
PostPosted: Sat Apr 17, 2021 12:36 pm    Post subject: Re: How would u fix this? Reply with quote
I guess we will never know.
Jimbo
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sat Apr 17, 2021 5:41 pm    Post subject: Re: How would u fix this? Reply with quote
Never seen a bronze flamingo, I’d go ahead and shoot it pink.
Pez Premium Member
Pez is offline
PostPosted: Sat Apr 17, 2021 7:21 pm    Post subject: Re: How would u fix this? Reply with quote
Curiosity got the better of me... Apparently a bronze (sadly not pink) can be had for a measley $1300.
https://www.houzz.com/pvp/flamingo-looking-back-br...koQAvD_BwE
Chasing Squirrel's.
1971 Bay Window
1966 Baja
PostPosted: Sat Apr 17, 2021 9:33 pm    Post subject: Re: How would u fix this? Reply with quote
Is this samba or Facebook ?
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sun Apr 18, 2021 4:12 am    Post subject: Re: How would u fix this? Reply with quote
Erik G, excellent video, thanks for posting this and the link for the rods. I'm impressed this was done with low temp rods without damaging the project. I've never tried it and she sure made it look easy. I guess I'll keep what I break now. Erik G, can you post your work.
Erik G wrote:
this type stuff
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
Abscate
Abscate is offline
PostPosted: Sun Apr 18, 2021 5:18 am    Post subject: Re: How would u fix this? Reply with quote
Have client fix it to her satisfaction and send you bill. That’s ends the cycle of dis( re) pair.
Sit down with employee and discuss who is paying what share to mutual satisfaction.
AZ Landshaper
PostPosted: Sun Apr 18, 2021 7:35 am    Post subject: Re: How would u fix this? Reply with quote
Is it legal to expect my employee to pay for a share of this? Id be more than happy to see this happen. This guy has been on a tare lately. He should be feeling some of this in his wallet. Maybe feeling the pain would end his carelessness.
Previously
and a 67 bug.
