Question about thermostat gasket
JJfierce
JJfierce is offline
PostPosted: Fri Apr 16, 2021 5:46 pm    Post subject: Question about thermostat gasket Reply with quote
I suspect I have a bad thermostat in my ‘84 so I’m changing that out today. I opened up the housing and it appears the previous owner put some kind of blue gasket maker around the regular gasket - do I need to do that or will the black O-ring be sufficient?
DanHoug
DanHoug is offline
PostPosted: Fri Apr 16, 2021 6:04 pm    Post subject: Re: Question about thermostat gasket Reply with quote
the housing is pitted and corroded. prolly why the schmoo was added. can you source a new/better housing?
-dan
www.thefixitworkshop.com
JJfierce
JJfierce is offline
PostPosted: Fri Apr 16, 2021 6:14 pm    Post subject: Re: Question about thermostat gasket Reply with quote
This is actually my second housing...I ended up snapping two bolts off from the top of the other one and was unsuccessful in trying to drill them out. I picked this one up from a guy for $30
