63 Beetle speed stability
Chevy5150
Chevy5150 is offline
PostPosted: Tue Apr 20, 2021 6:54 pm    Post subject: 63 Beetle speed stability Reply with quote
What’s up guys? My first post. I have a 63 beetle. Needed a front end rebuild so I put new king pins in links and all new steering linkage. I chose new 2 inch drop spindles and also added a caster shim. It’s still super sketchy above about 45 miles an hour. I read a lot of you guys too alking about doing 60 and 70 miles an hour in your beetle and it scares me to death. Anybody have any pointers to smooth out my twitchy handling at highway speed ‘s?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Apr 20, 2021 7:01 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
Did you have it aligned?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Teeroy Premium Member
Teeroy is offline
PostPosted: Tue Apr 20, 2021 7:09 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
Correct tire pressure, alignment, good spring plate bushings, tires, shocks, tie rods and steering box. When I had the upright Type 4 in my 61, I could drive it one handed over 100 mph, very stable, but all the above was new or like new and I have wide tires both ends, sway bars on both ends and the car is evenly lowered (no rake to cause the wing lift affect)
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Chevy5150
PostPosted: Tue Apr 20, 2021 7:22 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
Yes it was aligned. I forgot that part.
mukluk
mukluk is offline
PostPosted: Tue Apr 20, 2021 10:36 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
What size tires are you running and what pressure do you have them set at?
When you had the car aligned, did you get a copy of all the alignment specs they set it to? If yes, please post them up.
Have you verified the link pins and front wheel bearings are properly tightened with no excessive play?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Apr 20, 2021 11:28 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
Tire/wheel balance can make a difference too. Years ago I bought my own bolt-on balance adapter because most tire shops didn't have machines that the VW wide-5 rim fits onto any more.
Andy T.
FL-Frank
FL-Frank is offline
PostPosted: Wed Apr 21, 2021 6:34 am    Post subject: Re: 63 Beetle speed stability Reply with quote
Same here
“Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Apr 21, 2021 7:07 am    Post subject: Re: 63 Beetle speed stability Reply with quote
Since you have new king pins, there is a possibility that they are too tight & do not allow the steering to self center, this will cause you to constantly correct the steering & then re-correct as you drive which becomes twitchier as you increase speed.
bigdog1962
bigdog1962 is offline
PostPosted: Wed Apr 21, 2021 8:55 am    Post subject: Re: 63 Beetle speed stability Reply with quote
Exactly the case with my new front end rebuild. The shop had to ream them out again and what a difference it made.
Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!!
Erik G
Erik G is offline
PostPosted: Wed Apr 21, 2021 8:58 am    Post subject: Re: 63 Beetle speed stability Reply with quote
what tire size and tire pressure?
toxicavenger70
toxicavenger70 is offline
PostPosted: Wed Apr 21, 2021 11:42 am    Post subject: Re: 63 Beetle speed stability Reply with quote
Air pressure, good steering damper are the two things I would check since you did the others.
viiking
viiking is online now
PostPosted: Wed Apr 21, 2021 2:21 pm    Post subject: Re: 63 Beetle speed stability Reply with quote
Yes what’s the air pressure of the tyres. If you aren’t running something like 18 psi up front and around 24 at the back then you’ll have problems. Find the correct pressure in the manual or Technical Archives here.
Unlike modern heavy behemoths you don’t need 36psi or more all round.
Too high a tyre pressure will make it handle like a pig.
