Kiper Samba Member
Joined: August 17, 2019 Posts: 30 Location: San Jacinto CA
Posted: Wed Aug 21, 2019 12:28 pm Post subject: Re: Bodywork How To's |
| Dwighia wrote: |
Just a shout out to Matt K, aka Kipper.
Really enjoyed this thread and wanted you to know there are lots of people still reading it and benefiting from your post and others' comments.
I'm working on my 68 Ghia and have learned "muchly" from this thread.
Was going to pay someone to do my body work, but now I'm excited to do it myself. (just stared the work yesterday).
Would love to see you post some more of your great work Kipper.
Thanks again,
Dwight |
Thank you. I am happy people can use it. I hope to show more soon. _________________ I am Matt K. |
Kiper Samba Member
Posted: Sun Aug 25, 2019 4:08 pm Post subject: Re: Bodywork How To's |
It took me the better part of six months to get this 69 convertible nice. It needed so much work but the fit and finish is really nice. Notice how the bottom of the fenders fit the rear apron. Those are the details that most people miss. Even the underside of the decklid was color sanded and buffed.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Tue May 05, 2020 6:24 am Post subject: Re: Bodywork How To's |
Hello, i will be working on my front quarter panel on my 65 beetle and was wondering if anyone has any pictures of them fixing theirs? Here’s what mine looks like,
I tried using the glue body puller but i could get enough grip. So, here’s what I’m thinking,
1. Use a stud gun or weld nails the pull out any of the big dents should around the fender mounting surface.
2. Then remove the quarter panel start hammering away.
3. Use a shrinking disk to remove and dramatically large high spots.
4. Use a good fender to double check my work and make sure everything lines up well.
5. Go over any imperfections with the hammer and dolly and shrinking disc again.
6. Re-weld quarter panel to car.
7. Done _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
viiking Samba Member
Joined: May 10, 2013 Posts: 3430 Location: Sydney Australia
Posted: Tue May 04, 2021 4:33 am Post subject: Re: Bodywork How To's |
I did a similar repair to you but alas don't have before or after photos. As you know it is impossible to get a dolly down low inside that quarter panel. I followed a similar process to what you are suggesting.
Using your numbering.
Yes. I used a cheap slide hammer which you actually screw into the dented area. It leaves a hole, but a zap with the MIG resolves that. It quickly gets you back into shape and preferably a crowned area that you can tap down from the outside.
No. Don't do it. You will actually find in my opinion more problems with distortion and shrinkage when you weld the piece back on. Then you are back in the same position as you are now. I tried to cut out a bad section of my quarter panel only to find when I welded it in, even though I took my time and allowed everything to cool properly that I had a big divot which I found difficult to remove. Buy yourself a body spoon. It lets you get down almost to the bottom of the quarter panel near the door. The heavier the spoon the more easy is it for you to tap down the high spots created by the stud puller or slide hammer. I bought one like this and was able to use it to lever out the dents low down and I could use the hammer to get it pretty straight. One like this is what I bought.
https://www.google.com/imgres?imgurl=https%3A%2F%2...egUIARDHAQ
3. Use a shrinking disk to remove any dramatically large high spots.
Yes. Plenty of passes, followed by hammer and dolly. Repeat until flat
Buy yourself a contour gauge and use this to check the opposite fender and quarter panel. If you are clever enough you can use the contour gauge to make yourself a complete template of the area using strong cardboard or some thin ply.
Yes
Again, don't do it.
7. Done _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
