UngaWunga Samba Member
Posted: Mon Apr 26, 2021 12:24 pm Post subject: Subagon / Vanaru engine intake airboxes/airfilters.... |
That should hit all the keywords...
Looking to see what y'all with Subaru powered Vanagons have done for your airboxes.
Have you made an airbox?
Using a cone/K&N type filter?
Adapted one from another car? Do you have issues with it supplying enough air to the engine?
Custom made spendy parts from NW located parts dealers?
I have a cone K&N filter on my van now, and I think its a horrible solution. Engine sucks up hot air from the engine bay, and all the dust from dirt roads ends up on the filter. I have to clean it quite often.
Was considering blocking off the driver's side C pillar to put the filter in there, but I have my engine ECU wiring running through there as well to the lower rear cabinets.
Whatcha using, what works? Thanks |
valvecovergasket Samba Member
Posted: Mon Apr 26, 2021 12:31 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
ill put a plug here for the RMW setup (and i dont even have it on a subaru!)
its a really nice piece, pricey, but worth it since it all fits like a glove |
Posted: Mon Apr 26, 2021 12:33 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
I saw what they're asking for them, and it'd be worth buying a bending brake and some sheet aluminum to make one myself...  |
Posted: Mon Apr 26, 2021 12:39 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
| UngaWunga wrote: |
its not a bad idea depending on how much time youre into spending on building it. its a nice fit to the subaru filter with rolled edges, slants the whole thing over at an angle and tucks in nicely to the pillar. |
Franklinstower Samba Member
Posted: Mon Apr 26, 2021 12:42 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Kennedy also has an airbox. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1788 Location: Victoria,B.C.Canada
Posted: Mon Apr 26, 2021 2:19 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
02 2.5L No MAF. Early Subaru intake at 45degrees + white 3 inch PVC drain pipe,+ abs blockoff + K&N RU-2820 canister style,open in corner box. Not loud, good response low and high speed.
Posted: Mon Apr 26, 2021 2:26 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
| wesitarz wrote: |
Nice setup. Where did you mount the ECU for your motor? I have a bunch of wires running through there. Could reroute, but like where it is in the cabinet. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Mon Apr 26, 2021 8:33 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
I used the OEM Subaru airbox kinda half tucked into the LR D pillar. Aluminium tube and an elbow to connect to the throttle body.
I figured if Subaru thought it was the right way to go... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Wolfram Samba Member
Joined: June 23, 2005 Posts: 184 Location: Waiheke Island/On The Road USA
Posted: Mon Apr 26, 2021 11:15 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
We have a Vanaru and it came with a K&N cone. It wasn't fit for purpose, and clogged easily. It was also very close to hot parts.
We replaced it with a intake box that North Westy uses for their conversions.
Uses a common air filter and the intake temp is lower.
Sorry, no pics.
Van stuck in SF and we are stuck in New Zealand. _________________ 88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage. |
space Samba Member
Posted: Tue Apr 27, 2021 4:18 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Jaguar xj6 box _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Posted: Tue Apr 27, 2021 8:03 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Early and late model Subaru airboxes have been used in the D pillar box. Also, a Ford Mustang airbox seems to fit nicely. Search the forum threads for a writeup on that.
I threw my original airbox out. I even had it mounted along side the engine inside the bay for a while. I'm limited on what I can do with the D pillar since I have the expansion tank in the original position and I don't want to change everything around. |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1037 Location: Redwood City
shagginwagon83 Samba Member
Posted: Tue Apr 27, 2021 9:54 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
Does anyone know where I can get a Kennedy Air filter? They never responded to my email.
_________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 196 Location: Bellingham, WA
Posted: Tue Apr 27, 2021 10:18 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
| I emailed with them yesterday about wiring diagrams and parts cost. They replied quickly and they also answer the phone. |
Posted: Tue Apr 27, 2021 12:53 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
| Intake looks pretty narrow on that Kennedy airbox. Not sure it'd flow enough for a Subaru 2.5l engine. |
Posted: Thu May 06, 2021 9:29 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
| I think I'm going to go with the airfilter mounted in the driver's side pilar. I have a sheet of aluminum I can use for the block off plate. Does anyone know of a 3" flange I can mount on a flat sheet to attach the air filter and intake hose to? |
tuanis Samba Member
Posted: Thu May 06, 2021 11:20 am Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
I just purchased a vanagon with a 2.5L subaru and am in the same boat, the cheap cone air filter is sitting in the engine bay and I want to come up with a better solution. As I'm a newbie, my question is if you extend the tubing and move the filter into the cubby by the D pillar, do you need to also move the AFM closer to the new filter location? _________________ 1989 Westfalia - 2.5L Subie
1988 VW Westfalia - Stolen  |
physast Samba Member
Posted: Thu May 06, 2021 4:42 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
The RMW air box is expensive, but nice. i purchased it 10000 miles ago and still no buyer remorse here. _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4647 Location: Now - ABQ NM USA...Base ABQ, NM USA
Posted: Thu May 06, 2021 5:28 pm Post subject: Re: Subagon / Vanaru engine intake airboxes/airfilters.... |
In my subaru conversion I did myself using a 1999 forrester 2.5 sohc - I used the Subaru airbox in the driver pillar. Needed a 18" 45deg hose (used pre made silicone) Ended up putting in a vanagon snorkel from box up to upper air intake to reduce high speed/rpm drone. 52k miles later still happy and it's nice to use a off the shelf airfilter. An happy with result _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
