GArBa Samba Member
Joined: January 27, 2014 Posts: 2129 Location: Milano, Italy
Posted: Mon May 03, 2021 10:43 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| nagerjaeger wrote: |
Sunz out. Bugz out. 1998 City Car. 24K kilometers. Not a great photo but I'm loving the bug life today.
tornado red rocks!
_________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
nagerjaeger Samba Member
Posted: Tue May 04, 2021 9:26 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I like the gray hubcaps and the black stripe on the bumper.
| GArBa wrote: |
tornado red rocks!
thedishking Samba Member
Posted: Tue May 04, 2021 2:15 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I am having issues with my '98 Vocho.
A few days ago, I noticed a "stall", or hesitation when leaving a stop light.
It does it at every stop light now.
The car starts perfectly, but it smells rich (gassy). There is also smoke when the car is initially started.
When the car first starts, the accelerator seems fine. However, after running for a brief time, the car will stall if you accelerate quickly.
I can slowly rev the car (very slowly) and get the RPM higher, and then begin to drive.
However, as I am driving, I am unable to really accelerate quickly.
I did check fuel pressure at the rail, and found 35 PSI. I've seen specification is 43 PSI. I don't know if this is an issue or not.
I pulled the codes on VCDS-Lite (new version of Vag Com) and found:
3 Faults Found:
00532 - Supply Voltage B+
07-00 - Signal too Low
Supply voltage out of range
Should be 10 to 16 V
00519
Intake Manifold Pressure Sensor G71 - no signal
-Defective sensor, tubing to manifold
00518
Throttle Valve Position Pot G88, Open circuit or short circuit
-Wiring or defective part
I have tested sensor G71 & G88 with ohm meter, and they look identical to spare units I have.
I did clear the codes and they have not come back yet.
I have also re-soldered the pads on ECU Relay (#30).
I have noticed this unit is warm (not hot) after the car has been running for several minutes.
http://www.1600i.de/1600i-elektronik/relais-steuergeraet/CheckingandrepairingtheECUrelay.htm
The gas tank is clean and fuel lines should be good.
I replaced the fuel pump in January of this year when I cleaned the gas tank.
I also installed new fuel filter at that time.
I have about 11,800 miles on my spark plugs.
Would anyone have any ideas? Could this be a defective #30 relay? Or timing be off?
Thanks for your help!!! |
GArBa Samba Member
Posted: Tue May 04, 2021 11:19 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
to me it sounds vacuum related. have you double checked the green hose from the manifold to the pressure sensor inside the ECU? _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Wed May 05, 2021 9:24 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I have only checked that it is physically connected. I see there is a test that can be done by disconnecting it - and hopefully observing a change.
I will do that.
Also, I have read that fuel pressure regulator may have issues, but I can't seem to find much info on testing / troubleshooting.
Thanks for your help! |
GArBa Samba Member
Posted: Wed May 05, 2021 10:10 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| thedishking wrote: |
I will do that.
IIRC there is a piece of vacuum hose also inside the ECU itself. as for the fuel pressure, was the pump you replaced an original spare or aftermarket? Chinese pumps may be hit and miss. A way to test the regulator would be to check if you have fuel coming back to the swirl pot. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Thu May 06, 2021 7:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thank you Garba!!!
It was a cracked hose inside ECU. You called it on vacuum!
It was odd. I pulled the green line off of ECU yesterday, and saw the motor performance suffer instantly.
However, since the issue persisted, I swapped ECU units and problem is gone.
After tearing down old ECU - I found a cracked hose. Hopefully this ECU is still good - just need to get a replacement piece of hose.
To answer your other question - the fuel pump is OEM VW. The aftermarket stuff tends to scare me.
Thank you again for your help!!!!
Pegasín Samba Member
Joined: March 11, 2009 Posts: 129 Location: Asturias (Spain)
Posted: Thu May 06, 2021 9:42 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
My VAG-COM 311.2n with OBD2 cable only runs with Windows95/XP and didn´t works with modern softwares
So now I'm looking for an scan tool for diagnostic and fault codes. Which is recommended?
I found this model but I don´t know if it works with mexi Digifant '95
Ancel VD500 and Ancel VD700
Better options?
https://www.amazon.com/-/es/funciones-especiales-v...image_auto
Posted: Thu May 06, 2021 10:26 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
That's my OBD II cable, also with "adapter"
GArBa Samba Member
Posted: Fri May 07, 2021 1:56 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| I'm using an XTOOL V401. |
same here. it is glitchy sometimes but it works. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Fri May 07, 2021 6:05 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
The windshield washer pump on my 1998 City Car has never worked. I was able to find a knock off pump on Amazon, an ACI 177113. The only problem is that it is slightly taller than the original. So it is cocked just a bit. I used the original grommet.
This photo shows that it is taller.
Installed. A bit cocked. But it doesn't leak so far. Putting in only a little fluid in case there is a leak. As time goes on if it doesn't leak I'll put in more.
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
Posted: Sat May 08, 2021 10:28 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
How does that pump work? Maybe I should get one for my (US-spec) '73 Super Beetle, which has never had a working windshield washer system. _________________ 1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member |
hopkin  Samba Member
Joined: June 25, 2012 Posts: 2560 Location: Ottawa, Ontario
Posted: Sat May 08, 2021 7:41 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| Beetlebaum wrote: |
How does that pump work? Maybe I should get one for my (US-spec) '73 Super Beetle, which has never had a working windshield washer system. |
Conceptually it is very simple. Just a positive and negative spade connector with a volume of fluid and a discharge to the washer hose. Here is a kit that will fit your Super Beetle.
https://www.mamotorworks.com/vw/product/vw-1968-1974-universal-12v-windshield-washer-tank-kit-111111 |
Gerrelt Samba Member
Joined: December 22, 2004 Posts: 698 Location: The Netherlands
Posted: Sun May 09, 2021 3:02 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| Beetlebaum wrote: |
I've replied to this message in the thread about super beetle windows washing:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9633826#9633826 _________________ homepage
_________________ |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 563 Location: Anaheim, CA
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 283 Location: Orlando, FL United States
Posted: Wed May 26, 2021 2:46 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Everyones super Quiet...must be out Driving their Bugs..... _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
aquavette Samba Member
Joined: May 30, 2007 Posts: 185 Location: Argyle, TX.
Posted: Sun May 30, 2021 5:16 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
| Would a '95-'96 mexican beetle have the mounts to add pop out windows under the headliner? |
