Ghia Remote Oil Filter Placement/Exhaust
carguytroy
carguytroy is offline
PostPosted: Fri May 14, 2021 7:58 pm    Post subject: Ghia Remote Oil Filter Placement/Exhaust Reply with quote
Where’s a good spot to put a remote oil filter in a Ghia? Pics would be awesome. The exhaust on the car now is causing a room issue under the drivers rear quarter. I have another exhaust it’s a bit smaller tubes. I’m running my heater boxes so I’m not sure that even matters performance wise. Here’s a couple of pics. Tried to get some help on the Ghia section but didn’t have much luck.
Engine with the narrower exhaust on it.
madmike
madmike is offline
PostPosted: Sun May 16, 2021 6:24 am    Post subject: Re: Ghia Remote Oil Filter Placement/Exhaust Reply with quote
Your gonna lose HP with that 4 tip ,, but an exhaust mount will work Wink
bottom left is the filter
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Cusser
Cusser is offline
PostPosted: Sun May 16, 2021 8:43 am    Post subject: Re: Ghia Remote Oil Filter Placement/Exhaust Reply with quote
I have CB Maxi2 on both my VWs, with heater boxes and aftermarket header. I did have to grind down the cover a tad on both so the tin wouldn't rub on the pulley.
Danwvw
Danwvw is offline
PostPosted: Mon Aug 23, 2021 8:25 pm    Post subject: Re: Ghia Remote Oil Filter Placement/Exhaust Reply with quote
Is there room for it in the engine compartment?
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
crocteau
crocteau is offline
PostPosted: Tue Aug 24, 2021 6:19 am    Post subject: Re: Ghia Remote Oil Filter Placement/Exhaust Reply with quote
Eyeballing your photos I wonder if that location might work with a 4 ¼" spin on filter (this is 6 ¼")
