Texcallooker Samba Member
Posted: Tue May 18, 2021 11:18 am Post subject: Texas Cal Looker 64 Sunroof build. |
So I thought I would start a build thread on my 64 sunroof car. I picked it up from a buddy of mine as a project. It is surprisingly rust free, just a little in the pans but the body is solid. It was taken apart to be media blasted and body worked prior to me getting it. Other than some blocking the body is ready to go.
Last edited by Texcallooker on Tue May 18, 2021 11:43 am; edited 1 time in total |
Posted: Tue May 18, 2021 11:35 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
I pulled the body off the pan and started looking at the floors and decided on only patches as the rest is pretty solid. It’s nice to have a lift in your home shop. Sure makes things easy.
Posted: Tue May 18, 2021 11:41 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Next up since this car will be used from drag racing a street use it will have RLR cutch in it so I figured I’d better check the clutch tube and yep it’s broke loose at the front and back. A little surgery and we’re back in business.
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2009 Location: Texas
Posted: Tue May 18, 2021 1:25 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Looks like a decent starting point. Good luck on the build! I'll be following. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
RUNKLE Samba Member
Posted: Tue May 18, 2021 1:45 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Looks like you neighbor is a little jealous... all he got was a lawnmower. _________________ Type 1
Type 3
1968 Squareback |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Tue May 18, 2021 2:07 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Thanks. The cars been media blasted and its rock solid.
matthew henricks wrote: |
Looks like a solid starting place. Being a sunroof bug check the lower A-pillars. Common rust hiding place.
Good luck. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue May 18, 2021 7:12 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
wow that car is solid AF! i wish all my projects looked that good lol. looking forward to seeing the end result! although the journey is decently important too _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Thu May 20, 2021 3:59 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Chickensoup wrote: |
wow that car is solid AF! i wish all my projects looked that good lol. looking forward to seeing the end result! although the journey is decently important too |
I generally don’t get this lucky but I did on this one. |
Posted: Thu May 20, 2021 4:00 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
RUNKLE wrote: |
Looks like you neighbor is a little jealous... all he got was a lawnmower. |
Haha yep!! |
Posted: Thu May 20, 2021 4:11 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
So I’ll try and add some kind of update daily but for now it’ll be just random stuff as I go.
Spent the day removing the last of the old tar board. Can out pretty easy.
I removed the old fuel like from the tunnel, by far no easy task. I did it to make room for the new fuel line going in. Big motor w dual IDA’s is the plan.
Got a pile of goodies from summit for the brakes a fuel system. Plan is to get everything fitted up and then take out to prep and powder coat or paint the pan. This will help lessen the chance of skinning up the finish or run into snags along the way.
Practicing my engine turning skills for the plates where the fuel line will exit the pan for a little clean finish.
Posted: Thu May 27, 2021 9:31 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
Update 5/27/21
Built a dolly to roll the pan around and to be able to get it outside to blow all the blast grit out of the tunnel.
Last of the fuel/brake lines and fitting showed up.
Decided to do something cool at least. Made and engine turned a bulkhead cover for the fuel line where it comes through the pan.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6623 Location: Houston, Texas
Posted: Fri May 28, 2021 3:59 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
I've got that same car. Are you in Houston? _________________ www.vwnos.com [email protected]
Posted: Sat May 29, 2021 10:18 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
heimlich wrote: |
I've got that same car. Are you in Houston? |
close, Beaumont |
aaronr25 Samba Member
Joined: September 06, 2009 Posts: 267 Location: NW Arkansas
Posted: Sat May 29, 2021 11:45 am Post subject: Re: Texas Cal Looker 64 Sunroof build. |
I dig the dolly that you built to roll the pan around. That's a great Idea. _________________ 65 Bug
66 Landcruiser FJ40
Life's too short to drive a stock VW |
turboedbug Samba Member
Joined: April 14, 2006 Posts: 260 Location: washington
Posted: Sun May 30, 2021 3:16 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
turboedbug wrote: |
Nice build! Keep us rolling with phots! |
Did you mean,
thots
farts
or shots _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Sun Jun 06, 2021 6:28 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
New update of sorts.
Picked up some néw tools. I found a turret style flaring tool that comes with both 37 and 45 deg flare dies as well as bubble and double flares. Included was 25 feet of stainless 3/-16” brake line all for the same price as the Eastwood tool.
I also made a a tubing straightener since I’m cheap and didn’t want to spend the $100-200 for the same tool.
And finally was able to get the last of the undercoat chipped ground and burnt off the pan. Not a great time but it’s done.
Posted: Sun Jun 06, 2021 7:19 pm Post subject: Re: Texas Cal Looker 64 Sunroof build. |
dang your making quick pace! _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
