Batan Samba Member
Joined: March 10, 2003 Posts: 1637 Location: Vancouver, BC
Posted: Mon Aug 08, 2005 9:14 pm Post subject: Highway revs? Possible or is my tach smoking crack? |
I have a cheap old aftermarket tach but I'm shifting using the speedo.
Kind of 15mph(shifit to 2nd), 25-30(shift to 3rd) and about 45mph to 4th.
Watching the revs, they make sense in first couple of gears but the tach shows about 2100rpm at 60mph on the highway...does ANY of VW trannies allow that low of revs on the highway? What should it be at 60mph?
The car is a 61 coupe and the tires are stock. |
execk2 Samba Member
Joined: April 30, 2005 Posts: 1359 Location: Quebec City
Posted: Tue Aug 09, 2005 4:37 am Post subject: |
Should be closer to 3000-3300 rpm. Does that make sense?
Mike
www.mikeandjosee.com |
GhiaNut Samba Member
Joined: December 17, 2003 Posts: 606 Location: Gulf Coast of Florida
Posted: Tue Aug 09, 2005 5:22 am Post subject: |
| Any chance somebody slipped in a "freeway flyer"? They're aftermarket; geared lower in 4th. |
Batan Samba Member
Posted: Tue Aug 09, 2005 8:25 am Post subject: |
| GhiaNut wrote: |
I think there is. That would be awsome, wouldn't it?  |
Rome Samba Member
Joined: June 02, 2004 Posts: 10774 Location: Pearl River, NY
Posted: Tue Aug 09, 2005 2:41 pm Post subject: |
| Does your tach have a small switch to use it on 4-6-8 cylinder engines?? |
Batan Samba Member
Posted: Tue Aug 09, 2005 7:02 pm Post subject: |
| Rome wrote: |
Yes it does...and it's on 4. However, I checked it today I think that switch might be bad since the tach bounces around if I jiggle the switch. At idle and slight throttle it seems to be correct though... |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Wed Aug 10, 2005 12:15 am Post subject: |
| GhiaNut wrote: |
Actually it's not a lower 4th, you mean a higher 4th gear. But also to have a "freeway flyer", it's a conjunction of both a higher Ring & Pinion (3.88:1) and a higher 4th gear; 0.89 - stock 4th gear or 0.82 - Bus 4th gear.
A later model Beetle (I think of a '73 and later) started to come out with the 3.88 R/P and a 0.93 4th gear, changing the 4th to either a 0.89 or 0.82 will drop the RPMs lower. _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
peterericb Samba Member
Joined: January 11, 2005 Posts: 523 Location: Texas - North DFW
Posted: Wed Aug 10, 2005 5:55 am Post subject: |
write down some mph and RPMs for all your gears, measure the diameter of your tires and use algebra to figure out your other gears, assuming that the tach is right...
Then look up your tranny number and see if the other gears make sense. If not, chances are the tach is wrong (or you have a 100% custom tranny)... if the other gears match then you definatly have a freeway flyer.
If you used This calculator, you would have to work backwards, but I bet you could find a formula or a calculator that would do what you wanted.
I would look up your tranny code to fill in that calculator, then see if the mph comes close for any of the gears. Pretty quick test... _________________ I love it when a guy covered in tattoos tells me I should keep my Ghia "All Original" |
Posted: Wed Aug 10, 2005 8:12 am Post subject: |
This chart shows the gear ratios for the Type 1 Beetle (same as Karmann Ghia), use this to compare: http://sandlizrd.baja.com/gears.htm
You can also use this Gear Ratio Formula:
To calculate mph in any gear here is the formula:
RPM X 1/2 TIRE HEIGHT
-------------------------------------------------------- = MPH
GEAR RATIO X RING & PINION X 168 _________________ Jim Kikuchi
Batan Samba Member
Posted: Wed Aug 10, 2005 11:25 am Post subject: |
I'm definetly suspecting the tach. Seems to be a lot closer to what it should be if I switch it to 6 or 8 cylidner It shows high idle if I switch it to 6 or 8 but it definetly stretches the rev range. Set at 6, it will rev at about 3500 rpm at 60 mph.
Set at 4, it rarely goes over 2000rpm...2300 is about the highest.
anybody knows anything about tachs? I installed it, not rocket science so I'm wondering what could be wrong. |
Posted: Wed Aug 10, 2005 6:03 pm Post subject: |
| Batan wrote: |
What made or model is this so-called aftermarket tach? VDO, Autometer/Autoguage, Sun, Stewart & Warner, etc...?
It would help to narrow down the make/model of the product so we know what product you're dealing with. _________________ Jim Kikuchi
guenther Samba All-American
Joined: November 05, 2003 Posts: 125 Location: Between corn and bean fields
Posted: Wed Aug 10, 2005 6:41 pm Post subject: |
My tach shows 2500 at 55mph and 3000 at 65 mph and it is a '72 stock tranny. _________________ OG JHC
| Low_Slow wrote: |
| I am a homo |
| Lee. wrote: |
| Whitey is always trying to keep the Tibetans down. |
coad  Samba Scapegoat
Posted: Wed Aug 10, 2005 7:01 pm Post subject: |
I can't see where it is your tach.
If the tach is accurate in the lower gears (as you swear it is), then the tach is accurate. The tach doesn't know what gear you're in-- 2500rpm is 2500rpm no matter what gear is engaged.
And there wouldn't be anything different happening at the engine that I can think of either. Same deal, the engine doesn't know what gear you're in either.
I think you almost have to have a weird 4th gear from a freeway flyer or something like was suggested earlier. |
Batan Samba Member
Posted: Thu Aug 11, 2005 6:16 pm Post subject: |
| Banzai KG wrote: |
| Batan wrote: |
It would help to narrow down the make/model of the product so we know what product you're dealing with. |
OK, I think it's definetly the tach. I would not mind fixing it although it's a cheap one coz I kinda like the way it looks.
Anyways, it has not brandname anywhere on it but rather a logo that is a circle with 2 arrowheads pointing clockwise on the opposite sides of a circle(pointing out circular motion). |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sun Aug 14, 2005 7:33 am Post subject: |
Why don't you set it on 8 and then half the number and see what you get:).
I'm going to tend to agree with coad. if its working at lower RPMs then I doubt it is bad. |
execk2 Samba Member
Posted: Sun Aug 14, 2005 8:19 am Post subject: |
I agree that it is probably incorrect but OK. But, I think it would be important to try and verify this. The car needs RPM for cooling. A freeway flyer in heat without an external cooler runs the engine WAY too hot. On the safe side make sure your oil is topped off and fresh at all times. But get this checked out. Maybe a garage can hook up a temp to verify!?
Mike
Batan Samba Member
Posted: Sun Aug 14, 2005 10:22 am Post subject: |
| execk2 wrote: |
Mike
The car runs very cool on the highway even when hot. I can very easily touch the hold the dipstick after a long drive in hot weather in the city and on the highway.
The tach seems to be extremely incorrect, I already checked the ground and it's good.  |
