pemz0r Samba Member
Joined: August 26, 2010 Posts: 149 Location: Huntington Beach
Posted: Thu Jun 03, 2021 8:22 am Post subject: Front Locker Blinking Light |
I am looking to purchase this setup so I can have the front locker light blink while it's engaging. It looks like a vacuum pump, wire loom and a PCB board. If anyone has one or a source for one that would be awesome. Thank you.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12314 Location: Santa Cruz, CA
Posted: Thu Jun 03, 2021 8:32 am Post subject: Re: Front Locker Blinking Light |
Place a WTB ad in the classifieds |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18768 Location: Retired South Florida
Posted: Thu Jun 03, 2021 12:08 pm Post subject: Re: Front Locker Blinking Light |
I wonder if a turn signal relay could be adapted. Instead of turning the light on, the locker switch would ground the flasher relay and would be wired to the indicator light to flash it vs being on full time. You could even add a buzzer if you needed something audible. |
pemz0r Samba Member
Posted: Thu Jun 03, 2021 12:19 pm Post subject: Re: Front Locker Blinking Light |
Something to think about, but I will still need the vacuum pump sensor |
Posted: Thu Jun 03, 2021 12:24 pm Post subject: Re: Front Locker Blinking Light |
pemz0r wrote: |
I was thinking you wouldn't need vacuum to activate it. The relay would have power key on and get a ground from the switch on the case. The indicator light would be wired to the relay. The relay is programmed to flash. Seems simple to me. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10377 Location: Orbiting San Diego
Posted: Thu Jun 03, 2021 12:43 pm Post subject: Re: Front Locker Blinking Light |
The intent of the flashing indicator for the front locker is to warn the driver that front locker engagement is imminent but has not happened yet. This is a safety feature, a flashing warning BEFORE it locks the steering.
The metal item above with a hose and some wires looks more like a vacuum switch than a pump. That switch would be what tells the circuit board that the front locker control has been set to LOCK.
Mark |
Posted: Thu Jun 03, 2021 1:50 pm Post subject: Re: Front Locker Blinking Light |
That wouldn't be much warning. My front locker is pretty instantaneous. It may react quicker than the rear locker. I thought it was more of a "look at me" somebody accidentally engaged me vs a glowing indicator light.
I suppose it would depend what you wanted the indicator light to do. Then go from there. I have to believe the factory version is pretty rare and would be expensive. |
pemz0r Samba Member
Posted: Thu Jun 03, 2021 7:34 pm Post subject: Re: Front Locker Blinking Light |
Either way, quick or not, I still would like to see it work like a factory issue option.
I purchased the twist style mechanism, need to source the spring, so that way the knob has to be twisted before pulling the knob. |
