Highway revs? Possible or is my tach smoking crack?
Batan
Batan is offline
PostPosted: Mon Aug 08, 2005 9:14 pm    Post subject: Highway revs? Possible or is my tach smoking crack? Reply with quote
I have a cheap old aftermarket tach but I'm shifting using the speedo.
Kind of 15mph(shifit to 2nd), 25-30(shift to 3rd) and about 45mph to 4th.
Watching the revs, they make sense in first couple of gears but the tach shows about 2100rpm at 60mph on the highway...does ANY of VW trannies allow that low of revs on the highway? What should it be at 60mph?
The car is a 61 coupe and the tires are stock.
execk2
execk2 is offline
PostPosted: Tue Aug 09, 2005 4:37 am    Post subject: Reply with quote
Should be closer to 3000-3300 rpm. Does that make sense?
Mike
www.mikeandjosee.com
GhiaNut
GhiaNut is offline
PostPosted: Tue Aug 09, 2005 5:22 am    Post subject: Reply with quote
Any chance somebody slipped in a "freeway flyer"? They're aftermarket; geared lower in 4th.
Batan
Batan is offline
PostPosted: Tue Aug 09, 2005 8:25 am    Post subject: Reply with quote
I think there is. That would be awsome, wouldn't it? Shocked Laughing
Rome
Rome is offline
PostPosted: Tue Aug 09, 2005 2:41 pm    Post subject: Reply with quote
Does your tach have a small switch to use it on 4-6-8 cylinder engines??
Batan
Batan is offline
PostPosted: Tue Aug 09, 2005 7:02 pm    Post subject: Reply with quote
Yes it does...and it's on 4. However, I checked it today I think that switch might be bad since the tach bounces around if I jiggle the switch. At idle and slight throttle it seems to be correct though...
Banzai KG
Banzai KG is offline
PostPosted: Wed Aug 10, 2005 12:15 am    Post subject: Reply with quote
Actually it's not a lower 4th, you mean a higher 4th gear. But also to have a "freeway flyer", it's a conjunction of both a higher Ring & Pinion (3.88:1) and a higher 4th gear; 0.89 - stock 4th gear or 0.82 - Bus 4th gear.
A later model Beetle (I think of a '73 and later) started to come out with the 3.88 R/P and a 0.93 4th gear, changing the 4th to either a 0.89 or 0.82 will drop the RPMs lower.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
peterericb
peterericb is offline
PostPosted: Wed Aug 10, 2005 5:55 am    Post subject: Reply with quote
write down some mph and RPMs for all your gears, measure the diameter of your tires and use algebra to figure out your other gears, assuming that the tach is right...
Then look up your tranny number and see if the other gears make sense. If not, chances are the tach is wrong (or you have a 100% custom tranny)... if the other gears match then you definatly have a freeway flyer.
If you used This calculator, you would have to work backwards, but I bet you could find a formula or a calculator that would do what you wanted.
I would look up your tranny code to fill in that calculator, then see if the mph comes close for any of the gears. Pretty quick test...
I love it when a guy covered in tattoos tells me I should keep my Ghia "All Original"
Banzai KG
PostPosted: Wed Aug 10, 2005 8:12 am    Post subject: Reply with quote
This chart shows the gear ratios for the Type 1 Beetle (same as Karmann Ghia), use this to compare: http://sandlizrd.baja.com/gears.htm
You can also use this Gear Ratio Formula:
To calculate mph in any gear here is the formula:
RPM X 1/2 TIRE HEIGHT
-------------------------------------------------------- = MPH
GEAR RATIO X RING & PINION X 168
Jim Kikuchi
Batan
Batan is offline
PostPosted: Wed Aug 10, 2005 11:25 am    Post subject: Reply with quote
I'm definetly suspecting the tach. Seems to be a lot closer to what it should be if I switch it to 6 or 8 cylidner Rolling Eyes It shows high idle if I switch it to 6 or 8 but it definetly stretches the rev range. Set at 6, it will rev at about 3500 rpm at 60 mph.
Set at 4, it rarely goes over 2000rpm...2300 is about the highest.
anybody knows anything about tachs? I installed it, not rocket science so I'm wondering what could be wrong.
Banzai KG
PostPosted: Wed Aug 10, 2005 6:03 pm    Post subject: Reply with quote
What made or model is this so-called aftermarket tach? VDO, Autometer/Autoguage, Sun, Stewart & Warner, etc...?
It would help to narrow down the make/model of the product so we know what product you're dealing with.
Jim Kikuchi
guenther
Samba All-American
guenther is offline
PostPosted: Wed Aug 10, 2005 6:41 pm    Post subject: Reply with quote
My tach shows 2500 at 55mph and 3000 at 65 mph and it is a '72 stock tranny.
OG JHC
Low_Slow wrote:
I am a homo
Lee. wrote:
Whitey is always trying to keep the Tibetans down.
coad Premium Member
Samba Scapegoat
coad is offline
PostPosted: Wed Aug 10, 2005 7:01 pm    Post subject: Reply with quote
I can't see where it is your tach.
If the tach is accurate in the lower gears (as you swear it is), then the tach is accurate. The tach doesn't know what gear you're in-- 2500rpm is 2500rpm no matter what gear is engaged.
And there wouldn't be anything different happening at the engine that I can think of either. Same deal, the engine doesn't know what gear you're in either.
I think you almost have to have a weird 4th gear from a freeway flyer or something like was suggested earlier.
Batan
Batan is offline
PostPosted: Thu Aug 11, 2005 6:16 pm    Post subject: Reply with quote
OK, I think it's definetly the tach. I would not mind fixing it although it's a cheap one coz I kinda like the way it looks.
Anyways, it has not brandname anywhere on it but rather a logo that is a circle with 2 arrowheads pointing clockwise on the opposite sides of a circle(pointing out circular motion).
70 140
70 140 is offline
PostPosted: Sun Aug 14, 2005 7:33 am    Post subject: Reply with quote
Why don't you set it on 8 and then half the number and see what you get:).
I'm going to tend to agree with coad. if its working at lower RPMs then I doubt it is bad.
execk2
execk2 is offline
PostPosted: Sun Aug 14, 2005 8:19 am    Post subject: Reply with quote
I agree that it is probably incorrect but OK. But, I think it would be important to try and verify this. The car needs RPM for cooling. A freeway flyer in heat without an external cooler runs the engine WAY too hot. On the safe side make sure your oil is topped off and fresh at all times. But get this checked out. Maybe a garage can hook up a temp to verify!? Confused
Mike
Batan
Batan is offline
PostPosted: Sun Aug 14, 2005 10:22 am    Post subject: Reply with quote
Mike
The car runs very cool on the highway even when hot. I can very easily touch the hold the dipstick after a long drive in hot weather in the city and on the highway.
The tach seems to be extremely incorrect, I already checked the ground and it's good. Confused
