rustbus Samba Member
Posted: Tue Jun 29, 2021 9:19 am Post subject: mystery mechanical failure |
Hi Guys,
After almost 10 years of no major maintenance, i had a break down yesterday.
Particulars:
camper special engine 2012, 34,000km.
new starter 2012
rebuilt stock high output alternator 2012
-pretty sure i installed everything meticulously.
*battery is also from 2012....
symptoms:
-Super hot outdoor temperatures. like over 35*C
- previous day replaced the ignition lock cylinder with a NOS one
- did not change the ignition switch, it *Seemed* fine...
- up to now, ive had to jumper the bus to start it, most times when hot. no hot start relay. i have a cable running from the starter that i contact to the positive battery terminal to do this.
so yesterday after a drive and few stops, upon trying to start it, the starter just would grind, not engage. and do other funny things like groan a bit. but it did start eventually and i started to drive home. on the ride home, it lost power and bucked a couple times, then ran fine for another 10 mins. a few blocks from home, it started bucking even worse and funny whirring noise was heard by my passenger on his side of the bus. we pulled over and shut down. upon trying to restart, power would cut out. i went to the engine, everything looked ok. check the key again, no power, no dash lights, again back to the engine compartment, the ground cable was smoking and too hot to yank off by hand, so i quickly wrenched it off, and that's it. we towed it home later
It too hot out, up to 39*c for the next 3 days, so im not gonna crawl around under it yet... anyone care to speculate what went wrong? is it a basic starter failure? did my ignition lock cylinder replacement contribute to this?
thanks for thoughts _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Joined: August 31, 2013 Posts: 13333 Location: North Carolina
Posted: Tue Jun 29, 2021 9:52 am Post subject: Re: mystery mechanical failure |
Sounds like either the ignition switch or the solenoid hung up & kept the starter engaged & more than likely cooked the starter. (This will also cause the starter to short internally.) _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24178 Location: NYC/Upstate/ROW
Posted: Tue Jun 29, 2021 12:39 pm Post subject: Re: mystery mechanical failure |
Battery is about 5 years past end of life.
Honestly, with nothing done for 12 years the entire cranking circuit probably has multiple marginal operating parts. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Wed Jun 30, 2021 12:23 pm Post subject: Re: mystery mechanical failure |
had the battery and starter tested, battery is definitely too old for a load, and the starter solenoid is fused.
i'll replace the ignition switch too.
the starter only had some 34000km of use on it, but i suppose with the weak battery and fiddling with the ignition may have caused it some grief, or the starter these days are just remanufactured to shit standards. it was a "bosch". paid extra for the name too if i remember correctly. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
timvw7476 Samba Member
Posted: Wed Jun 30, 2021 1:15 pm Post subject: Re: mystery mechanical failure |
rustbus wrote: |
the starter only had some 34000km of use on it, but i suppose with the weak battery and fiddling with the ignition may have caused it some grief, or the starter these days are just remanufactured to shit standards. it was a "bosch". paid extra for the name too if i remember correctly. |
Typical outcome with Bosch Approved rebuilts, starter OR alternator.
Some of their stuff signs off inside two years, others go a decade plus.
Then there's the starter-mounted solenoid, which costs so much you might as
well treat the entire unit as a single assembly. My last starter was Pure Energy rebuild, from Rockauto, 1 year warranty, it's decent, two+ years in. $40-ishUSD & core return. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42808 Location: at the beach
Posted: Wed Jun 30, 2021 4:34 pm Post subject: Re: mystery mechanical failure |
if you or the PO added a hot start relay look at it too. If it goes bad in the on position it will destroy everything down stream from it. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3438 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jul 01, 2021 11:35 am Post subject: Re: mystery mechanical failure |
rustbus wrote: |
If it's a Bosch reman it should have a "lifetime" warrenty. |
airkooledchris Samba Member
Posted: Thu Jul 01, 2021 1:45 pm Post subject: Re: mystery mechanical failure |
rustbus wrote: |
keep the old one. the new ones had been such garbage for a while I finally went pushbutton. |
Posted: Sun Jul 04, 2021 5:47 pm Post subject: Re: mystery mechanical failure |
SGKent wrote: |
if you or the PO added a hot start relay look at it too. If it goes bad in the on position it will destroy everything down stream from it. |
No hot start relay, I thought about it but never did it _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Jul 04, 2021 5:48 pm Post subject: Re: mystery mechanical failure |
ToolBox wrote: |
rustbus wrote: |
Ahh, it was, but alas, I already traded in as a core for a "Wilson" brand unit. I'm sure they would have wanted proof of purchase anyway I wouldn't have had a that anymore _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
airkooledchris wrote: |
rustbus wrote: |
I did keep it, but i had, on hand, what I think was a vw brand new replacement switch for a few years now _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Jul 04, 2021 5:50 pm Post subject: Re: mystery mechanical failure |
So yeah, I replaced the ignition key cylinder, the Ignition switch, the starter and the battery and its better than ever. Now I have 2 keys to deal with but that's ok _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Mon Jul 05, 2021 3:38 am Post subject: Re: mystery mechanical failure |
rustbus wrote: |
So yeah, I replaced the ignition key cylinder, the Ignition switch, the starter and the battery and its better than ever. Now I have 2 keys to deal with but that's ok |
Gabe can re-key that to one key if you get annoyed with that. Heβs got a lock on that business. You can find him here on the Samba or on his Tumbler account _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
