sgellis Samba Member
Joined: July 06, 2016 Posts: 2016 Location: SW Nova Scotia, Canada
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Sep 20, 2021 9:15 am Post subject: Re: Plug wire conduit changes |
Ha, ha - there was once a thread on this and I knew the answer, but forgot, by now - my guess is the open one is for a type one, through ( at least) 1958 as that metal-conduit was not used on later shrouds, but instead the ignition wires fed through rubber eyelets, mounted on the shroud - someone will know, eventually - I'll keep looking - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Sep 20, 2021 4:30 pm Post subject: Re: Plug wire conduit changes |
… and I asked Eric, at Bughaus, where I buy my parts and he also, was not quite positive, but said it goes by end-flange size and he thought the one with the smaller flange, was correct for a '54- I looked in my VW, 1958 parts book and no mention of flange size, but did indicate , the same part was used in a type 2...
… i'll bet, it was a running change - not mentioned anywhere - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Sep 20, 2021 8:35 pm Post subject: Re: Plug wire conduit changes |
Nothing on this part mentioned in Progressive Refinements. What I recall is that there also was a difference in the clamps for the conduit. If the front facing piece had a nut on the end it was later design. I doubt there would have been a difference between a Beetle vs Bus conduit. Why would that have been purposeful? _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue Sep 21, 2021 9:20 am Post subject: Re: Plug wire conduit changes |
tasb wrote: |
Nothing on this part mentioned in Progressive Refinements. What I recall is that there also was a difference in the clamps for the conduit. If the front facing piece had a nut on the end it was later design. I doubt there would have been a difference between a Beetle vs Bus conduit. Why would that have been purposeful? |
… like I said, that conduit musta' been a running change in production and not worth noting any where in PR or better yet, by Garwood, in Car of the Century - the smaller flange appears to be the older one - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
EverettB Administrator
Joined: April 11, 2000 Posts: 69838 Location: Phoenix Metro
Posted: Tue Sep 21, 2021 12:46 pm Post subject: Re: Plug wire conduit changes |
sgellis wrote: |
EverettB wrote: |
Just to confirm even though it's in the thread above:
'54 would be the clamps with the machine screw/nut
All of the tin would have the welded-on nuts too. |
I read through those threads got the impression the clamp change was between 25hp and 36hp. If the nut continued into 54 on the 36hp then I wonder when the change happened. Progressive refinements does not mention anything to do with tins. |
It's definitely early 36hp too but not sure exactly when it changed.
I believe sometime in 1955 but I haven't tried to research it fully.
It may be talked about in the 54-55 engine thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=179439 _________________ How to Post Photos
janerick3 Samba Member
Posted: Tue Sep 21, 2021 4:08 pm Post subject: Re: Plug wire conduit changes |
Open vs. closed seams and whether weld nuts are on the tube clamps have been covered previously.
Also, the length of the wire entry slot and width of the flared ends vary by year.
For the record, both Feb '54 and Dec '54 tubes are identical, with open seams. _________________ Thanks,
Jan K. |
Posted: Tue Sep 21, 2021 5:38 pm Post subject: Re: Plug wire conduit changes |
ZENVWDRIVER wrote: |
tasb wrote: |
… like I said, that conduit musta' been a running change in production and not worth noting any where in PR or better yet, by Garwood, in Car of the Century - the smaller flange appears to be the older one - z |
Sorry, wasn't ignoring your contribution, I was actually trying to back you up. _________________ Roads Scholar &
Posted: Thu Sep 23, 2021 10:42 am Post subject: Re: Plug wire conduit changes |
tasb wrote: |
tasb wrote: |
Sorry, wasn't ignoring your contribution, I was actually trying to back you up. |
thank you tasb - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
