dungeoncrawl Samba Member
Posted: Sun Sep 26, 2021 6:38 pm Post subject: UPDATE: Holes in my wheel wells into trunk? What are they? |
***Update: 12/19/21. I figured it out! I finally stumbled onto a condenser/evaporator in the front of the car attached to the torsion bar so the car had an AC unit installed at some point. No other evidence on the interior, in the engine, etc. With that bit of knowledge, I started Googling other Ghia's with AC units and many of them have these holes supporting the AC unit. My plan will be to remove this at some point. ***
Pulled the carpet out of my trunk to get a better look at wire issues and to start cleaning things up a bit. I noticed there is a perfect "quarter" sized hole into each wheel well. One is just under the fuel fill hose so I didn't initially see it. Anybody knows what these are and if there should be some type of grommet in there? Way it looks now, any rain is just going to get thrown up into the trunk directly from the wheel wells.
Last edited by dungeoncrawl on Sun Dec 19, 2021 9:07 pm; edited 2 times in total |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Mon Sep 27, 2021 2:30 am Post subject: Re: Holes in my wheel wells into trunk? What are they? |
what year is your KG? Photo of the holes?
I'm only familiar with the newer ones and there are no holes into the wheel well.
I'd just put blanking grommets in them and maybe be a smear of seam sealer on the wheel well side and call it done
I just remembered there is a hole for the speedo cable on the left side and there is a small hole for the top bolt of the mud seal plate on newer cars |
Posted: Mon Sep 27, 2021 7:01 am Post subject: Re: Holes in my wheel wells into trunk? What are they? |
Here's a pic of the one on the right. There is a duplicate one on the left but it's hard to get a picture of it because the fuel filler hose is blocking it.
1970 convertible KG.
kingkarmann Samba Member
Posted: Mon Sep 27, 2021 8:09 am Post subject: Re: Holes in my wheel wells into trunk? What are they? |
How strange
As suggested I would plug them with grommets. I can't hazard a guess as to why those non stock holes are there. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Sep 27, 2021 9:12 am Post subject: Re: Holes in my wheel wells into trunk? What are they? |
Don't have anything like that on my 71. Perhaps a previous owner was running some type hose for cooling or running wires. Never seen these holes in any Ghia's I've been around. The hole does look well cut and not just some punch job.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Mon Sep 27, 2021 10:36 am Post subject: Re: Holes in my wheel wells into trunk? What are they? |
rbsurfguy wrote: |
Jeff |
For sure. They're so well cut that they look like they came from the factory. Just not sure why somebody would want to get down into the wheel wells like that. First chance I need to do some body work and paint, I'll have them filled in. Until then, guess I'll try to find some type of grommet to go in there. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Mon Sep 27, 2021 12:17 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
dungeoncrawl wrote: |
That hole where you point (left side) looks like the one for the speedo cable and there is a special grommet for that. Do you need a photo of the speedo cable in place? I can provide that.
The one on the right (not shown by you) probably has something to do with the gas fumes venting system, I think. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Mon Sep 27, 2021 1:49 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
kiwighia68 wrote: |
The one on the right (not shown by you) probably has something to do with the gas fumes venting system, I think. |
I believe he is right!
I totally forgot the speedo cable😳 _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Mon Sep 27, 2021 2:28 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
kiwighia68 wrote: |
Yes please. A picture would be great. if you have a pic of what might be going under that fuel fill valve, that would be great too. Guess my speedo is connected through some non-standard way. |
Posted: Mon Sep 27, 2021 3:05 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
The speedo cable routing through the L side of the front trunk:
I see no similar or other hole on the R side.
I think you might want to investigate the gas fumes venting system for your Ghia's model year and area. You American friends will know better that I in that regard.
Good luck with your restoration.
Chris M _________________ Festina lente - hasten slowly
Posted: Mon Sep 27, 2021 3:48 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
I think you are correct Chris, I forgot about that grommet, but for some reason I thought the hole was smaller, that's why I got confused. As for a hole on the right side, I don't have one that big in that location, smaller holes, and like in the other topic discussion, most of the hoses are in the wheel well coming off the fuel filler neck. Good call on the speedo cable!
2012 Passat-Sold
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1683 Location: Raleigh, NC
Posted: Mon Sep 27, 2021 4:07 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
kiwighia68 wrote: |
That hole where you point (left side) looks like the one for the speedo cable and there is a special grommet for that. |
That hole isn't where the speedo cable goes. His speedo cable is going through the fender well at the same place as in your pic, kiwighia68, which is in that corner between the trunk floor and first vertical section. Not on the curved vertical section. You can see his speedo cable, about 3 or 4 finger widths to the left of the hole where it passes under the wiring harness. I bet if he moves the wiring harness he'll see the speedo cable grommet.
I would venture a guess that this car may have had dealer-installed AC at some point, and that's where those holes came from. The 67 I used to own had dealer installed AC and I seem to recall holes in a similar location. Let me see if I can find some pics... _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
LVGhia72 Samba Member
Joined: April 22, 2020 Posts: 282 Location: Lost Wages
Posted: Mon Sep 27, 2021 4:33 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
My guess is that it was for an EVAP system. Pollution control device to prevent gasoline fumes from the gas tank entering the atmosphere. I'll check my Ghia (1972) and see if there maybe a similar hole. |
Posted: Mon Sep 27, 2021 4:44 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
kiwighia68 wrote: |
Chris M |
thanks for the pic but I have one of those also, Its just below the ridge. You can barely see my speedo cable and a grommet like yours at about 10:00 off of the larger hole that is on TOP of the ridge. It's definitely for something else. |
Posted: Mon Sep 27, 2021 4:47 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
Era Vulgaris wrote: |
kiwighia68 wrote: |
I would venture a guess that this car may have had dealer-installed AC at some point, and that's where those holes came from. The 67 I used to own had dealer installed AC and I seem to recall holes in a similar location. Let me see if I can find some pics... |
Good eye man. It's definitely not the speedo cable hole. Would appreciate any pics you might have of something similar. A dealer installed AC might be the answer. While I'd love to know what they are, I think we're all in agreement I can seal them up and they aren't useful. Hope I can find some temp grommets that fit prior to any body work i might need. |
Posted: Mon Sep 27, 2021 4:58 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
I just checked my Ghia. I have several holes, but not the same as yours. Mine are on a 90 degree angle to the fender wall. One hole is for the speedometer cable, another hole has a bunch of wires going through it. I have no idea what the wires are or what they do. Their tied up under fender well.
Bunch of wires going to no where land. |
Posted: Mon Sep 27, 2021 5:03 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
LVGhia72 wrote: |
Thanks for the pic man. We both have the speedo hole and grommet but you've got an even different hole in your Ghia than mine Now we have 2 mysteries. |
74 Thing Samba Member
Posted: Mon Sep 27, 2021 5:18 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
Maybe a gas heater?
If so there needs to be a hole for the exhaust and a hole for the intake of the combustion chamber then 2 holes into the interior usually under the dash for the fan intake and the fan blowing the hot air. |
rrock Samba Member
Joined: November 12, 2009 Posts: 42 Location: Ontario, CA
Posted: Mon Sep 27, 2021 6:00 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
The AC in my car has been removed and there's a hole in the same area where one of the lines ran into the trunk. |
Posted: Mon Sep 27, 2021 8:20 pm Post subject: Re: Holes in my wheel wells into trunk? What are they? |
rrock wrote: |
Is there a matching one hidden on the other side under the fuel fill valve? You gotta look close. This could be the answer! |
