wpicotte Samba Member
Posted: Tue Oct 19, 2021 9:25 am Post subject: Replace Window Lift Channel Seal |
My 87 Vanagon has new exterior paint, and in the process I'm replacing all seals.
I have new window lift channel seals for the rollups, but cannot figure out how to remove the metal sleeve holding window.
I'm reluctant to pry at it for fear of damaging the window, but maybe it's just held by clamp force and a little stuck after all these years? |
khughes Samba Member
Joined: July 13, 2013 Posts: 878 Location: Phoenix AZ
Posted: Tue Oct 19, 2021 1:18 pm Post subject: Re: Replace Window Lift Channel Seal |
wpicotte wrote: |
BTDT - couldn't get the glass out of the lift channel either. Maybe someone has had success, but I just gave up and left the old rubber in - annoyed me when I was replacing everything else, but...it looked in good shape and doesn't seem to be causing any issues. Good luck! _________________ '86 Westy FAS GenV Turbo (Marvin) |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4231 Location: Redwood City, California
Posted: Tue Oct 19, 2021 6:24 pm Post subject: Re: Replace Window Lift Channel Seal |
Why would you want to change that? There is no reason to change it. You can get the sash channel off by floating it with WD 40 and then using a thin screwdriver down between the rail and the rubber or pound it off with a wooden block.
In the past when installing a new door glass I have always just re-used that piece.
I think you're opening Pandoras box here, but forge on soldier.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
DuncanS Samba Member
Posted: Tue Oct 19, 2021 8:12 pm Post subject: Re: Replace Window Lift Channel Seal |
Lift channel? What part are you referring to? The regulator guide which raises the window, or the metal at the forward edge which is part of the vent window? With the window down the rubber along the top and back edge just pulls out and the scrapers, inside and out pull up and out easily as well. Some of the scraper clips may come off and need to be replaced in the door which requires removing the glass.
Just don't understand what you are trying to do. Sorry.
Duncan |
campism Samba Member
Joined: September 07, 2007 Posts: 4673 Location: Richmond VA
Posted: Wed Oct 20, 2021 4:10 am Post subject: Re: Replace Window Lift Channel Seal |
What Duncan said. With the window down the upper portion's seam is along the back edge just above the glass. You work a pick into the seam and just peel out the whole piece pulling from back to front. The scrapers can be (carefully) pried up and out with the glass in place. I did this years ago and will need to do so again for an upcoming window winding repair. Good luck! _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
therastavan Samba Member
Joined: July 30, 2020 Posts: 113 Location: California
Posted: Fri Dec 27, 2024 10:28 am Post subject: Re: Replace Window Lift Channel Seal |
wpicotte wrote: |
Did you figure this out yet? |
