1961tbird Samba Member
Joined: July 21, 2018 Posts: 292 Location: Halifax, Nova Scotia
Posted: Sat Nov 20, 2021 9:05 pm Post subject: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
I understand that the stock charger in my 95 EVC charger doesn't have the proper charging profile for a lithium house battery.
To overcome this problem, while connected to shore power, could one use a lithium trickle charger to top it off? Is there a problem plugging in the van via shore power and also connecting and using a lithium trickle charger at the same time?
I am thinking of permanently hard wiring the lithium trickle charger to the house battery. Then plugging in the lithium trickle charger into the 110 outlet located in the rear. In that way, the lithium trickle charger is only activated when the shore power is used.
I am considering the CTEK:
https://www.amazon.ca/CTEK-56-926-LITHIUM-Automati...amp;sr=8-4 |
TheOneTrueQuux Samba Member
Posted: Mon Nov 22, 2021 8:38 am Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
For about the same money, why not replace the existing power converter entirely with this unit?
https://www.amazon.com/gp/product/B08TRRCZ75
That's what I did, it works great, and can be set to a lithium charge profile. |
Posted: Mon Nov 22, 2021 8:53 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
So you pulled and replaced the Magnetek? |
TFB777 Samba Member
Joined: February 12, 2021 Posts: 35 Location: Camas, Washington
Posted: Tue Nov 23, 2021 12:25 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
1961tbird wrote: |
Correct. |
Posted: Tue Nov 23, 2021 12:26 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
This is also a great option. I liked the Victron as it offers bluetooth, and works with their MPTT charger controllers, DC-DC converters and whatnot. |
Posted: Tue Nov 23, 2021 1:06 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
TheOneTrueQuux,
Your first posted link to Amazon references the Victron Energy Blue Smart IP22 12-Volt 20 amp 120V, Single Output Battery Charger NEMA 5-15, Bluetooth.
Excuse my lack of knowledge but does this Victron product replace the Magnetek? It appears to be just a battery charger or am I missing something? |
Posted: Tue Nov 23, 2021 4:27 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
1961tbird wrote: |
TheOneTrueQuux,
It replaces the Magnetek unit. It's smart enough to charge the battery while power is being drawn, hence it can be both a converter and a power supply. If you read their documentation they talk about this. You do have to combine two wires that go to the original magnetek and connect them both to the positive connection on the Victron, but this is NBD. David at 1705.net did something similar. He used a progressive dynamics unit, but those are similar in operation to the victron.
See this link:
https://1705.net/converter-upgrade/
You could use the same unit he did, or use the Victron like I did. Both will work fine. I like the victron for the bluetooth, and configurability. |
Posted: Wed Nov 24, 2021 1:29 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
Many thanks. I did not realize the Victron could act as a power source and a battery charger. I'll certainly research further. Again, thanks for the tip.
BTW, what size did you opt for? |
Posted: Sat Nov 27, 2021 1:52 pm Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
Lastly, does the Victron will automatically work as a power supply while charging? I thought those functions were separate. |
Posted: Tue Nov 30, 2021 10:05 am Post subject: Re: Charging a LiFePo4 Lithium Battery House Battery 95 EVC |
1961tbird wrote: |
You can set it to a pure power supply mode, but it should supply power just fine when in charging mode and a load is applied. |
