Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Fri Jan 14, 2022 6:50 pm Post subject: Re: '59 Karmann Ghia fever |
Glenn wrote: |
Trylon wrote: |
In computer science we call it feature creep.
I’m sure you guys must have your own term for it. |
I call it an onion... every time you peel a layer you find another one. |
Ha! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
kingkarmann Samba Member
Posted: Sat Jan 15, 2022 9:08 am Post subject: Re: '59 Karmann Ghia fever |
Glenn wrote: |
Trylon wrote: |
I call it OCD of which I am a lifelong sufferer _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Trylon Samba Member
Posted: Sat Jan 15, 2022 12:29 pm Post subject: Re: '59 Karmann Ghia fever |
It’s crazy that one can still buy this:
How many need one? How many know what it is? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
c21darrel Samba Member
Trylon Samba Member
Posted: Sat Jan 15, 2022 12:40 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
its a rubber plug/bump stop.
VW used them for gas doors, glove boxes....throttle rings.... |
I see, more than just the use I had in mind. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
Trylon Samba Member
Posted: Sun Jan 16, 2022 2:17 pm Post subject: Re: '59 Karmann Ghia fever |
EverettB wrote: |
It looks like the stopper for the warm-up air control ring on the back of the shroud.
I think that's the only place with this particular size but would be interested to know if there are other duplicate uses |
That’s what I bought it for (and why I thought it was crazy that such a thing would still exist).
Oddly, though, it seems ours is thinner:
As in the ‘59 manual:
Now I’m torn between leaving it alone (and risking hitting the fan) or replacing it (and risking insufficient warm up).
Sigh. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Mon Jan 17, 2022 7:44 am Post subject: Re: '59 Karmann Ghia fever |
EverettB wrote: |
There's a thin and a thick one
Info from anothe thread:
EverettB wrote: |
Rubber plug change
Some discussion here
https://www.thesamba.com/vw/forum/viewtopic.php?t=443124
It's weird because I've had a ton of throttle rings with intact rubber pieces and ALL of them were thick. Or missing. Maybe the thinner ones disappeared easier when old. |
hazetguy theorized the thick one was a normal dealer replacement for the thin one though
The thin one is the same as the rubber plugs for a later Beetle rear apron and I believe it's also a common "license plate hole plug" they have at an Ace hardware store.
Thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=577549
Beetle close up:
Gotta say this dissertation on such a arcane tiny piece made me smile. Thanks for passing it along!
So the stop that is in there seems quite serviceable so let’s see what happens when I install it og. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Trylon Samba Member
Trylon Samba Member
Posted: Tue Jan 18, 2022 12:02 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
Is that going to fit our ghia? looks short. |
Well, hoping it’s just the right length for the engine-to-transmission ground but only time will tell. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Tue Jan 18, 2022 1:13 pm Post subject: Re: '59 Karmann Ghia fever |
Huh, NOS on left — repro on right.
As we were using the repro one, I think I see why our spring always looks wonky. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Jan 18, 2022 2:53 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
It's been out in the cold. |
Trylon Samba Member
Posted: Tue Jan 18, 2022 3:38 pm Post subject: Re: '59 Karmann Ghia fever |
iowegian wrote: |
c21darrel wrote: |
Man, has this thread deteriorated. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Trylon Samba Member
Posted: Wed Jan 19, 2022 1:43 pm Post subject: Re: '59 Karmann Ghia fever |
Pulled all four plugs:
Have they any tale to tell? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
