76 Lost power on highway
revkevinhale
revkevinhale is offline
PostPosted: Sat Jan 22, 2022 3:00 pm    Post subject: 76 Lost power on highway Reply with quote
I was driving down the highway and my bus started acting like it was running out of gas, but it did this for a mile or more, slowly losing power as a I went. Eventually it just died. Sat for a while and it started up and drove sluggishly for a quarter of a mile. Died again. If I sit for 10-15 minutes, it will start and run for a minute, and I can get it to move maybe 25 yards. Then it dies again.
d___dles
d___dles is offline
PostPosted: Sat Jan 22, 2022 3:05 pm    Post subject: Re: 76 Lost power on highway Reply with quote
Any chance your points pitted?
1967 Riveria Camper
Wildthings
Wildthings is offline
PostPosted: Sat Jan 22, 2022 3:12 pm    Post subject: Re: 76 Lost power on highway Reply with quote
Definitely check your points as the wear blocks of the newer Bosch points will snap off without warning, leaving you with little or no gap.
With the tranny in neutral turn the crank for two complete revolutions by hand. Does the compression feel the same on all four cylinders.
The more info you can give us the better. For starters are you still running fuel injection?
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 22, 2022 3:26 pm    Post subject: Re: 76 Lost power on highway Reply with quote
VW gas gauges lie. Be sure it isn't tricking you.
George Carlin:
Skills@EuroCarsPlus:
revkevinhale
PostPosted: Sat Jan 22, 2022 4:11 pm    Post subject: Re: 76 Lost power on highway Reply with quote
Well. Somewhat sheepishly, Ι offer the following update.
Gas seems to have solved the problem.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Jan 22, 2022 4:36 pm    Post subject: Re: 76 Lost power on highway Reply with quote
Don't sweat it, you have plenty of company!
aeromech
aeromech is offline
PostPosted: Sat Jan 22, 2022 8:47 pm    Post subject: Re: 76 Lost power on highway Reply with quote
My wife has gas occasionally. Solved quickly after a few belches
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Abscate
Abscate is offline
PostPosted: Sun Jan 23, 2022 2:10 am    Post subject: Re: 76 Lost power on highway Reply with quote
That cheap gas from China never lasts. I only use OGas shipped from Germsny on German flagged tankers , Labelled Benzin
