1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA
valvecovergasket
valvecovergasket is offline
PostPosted: Fri Feb 11, 2022 9:16 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
djkeev wrote:
Go back to gears and chains.
no kidding! keep it simple!
Razz
actually, forget those lousy chains. go back to straight gear drive!
?Waldo?
?Waldo? is offline
PostPosted: Fri Feb 11, 2022 9:30 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Dude, stop! I just threw up in my mouth!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Feb 11, 2022 10:20 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
fucking VAG junk
they had like no joke 5-7 revisions of those timing components. imagine finding that out after you did it, that you only had the first or second revision.
i'll take a timing belt any day of the week
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
damagd
damagd is offline
PostPosted: Fri Feb 11, 2022 10:24 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
?Waldo? wrote:
To the OP, damagd, did you have all timing covers properly in place and in undamaged condition?
Yes, and I think I discovered the problem. The injection pump was totally loose. The two on the bottom bracketing to the engine are gone. The one I assumed came loose was the one mounting it to the alternator bracket. I guess it could have come loose out of one of the bottom holes, but I cannot pull the IP far enough to get the holes lined up because the long plate attached to the IP is hitting the rear of the engine.
damagd
damagd is offline
PostPosted: Fri Feb 11, 2022 10:28 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Got the head pulled.
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Fri Feb 11, 2022 11:11 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
So, will I need to cut any holes in my engine lid to fit that in my Vanagon?
Laughing Laughing Laughing
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
?Waldo?
?Waldo? is offline
PostPosted: Fri Feb 11, 2022 12:00 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
damagd wrote:
Got the head pulled...
It looks like all 8 or maybe 7 out of 8 valves hit pistons. Yipes. The lighter intake marks make me think that the valve timing was not correct even before the timing incident. The fact that all four exhaust valves got hit also indicates that the timing was slipping before the belt broke. Anyway, if it is JX code then it is solid lifter. I recently got solid lifter 1.6 valves from Spareto.
Inlet valves are part #: 068109601D
Exhaust valves are part #: 068109611C
Inspect the head for cracks first! Small cracks between the valves are normal and are not typically a concern. Cracks on the combustion fact from pre-combustion chamber to exhaust valves are no good. Cracks in pre-combustion chamber inserts are also dangerous.
If using oil, then rings would be a good idea at this time, however, often the bores are worn out of spec and boring oversize with new pistons is required. By the time you add up the valves, pistons, machine work, etc... it can be quite expensive.
old_man
old_man is offline
PostPosted: Fri Feb 11, 2022 12:03 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
?Waldo? wrote:
Timing gears aren't really a feasibility on a DOHC engine,
Leave it to the Soviets to somehow make it work. The Kharkiv model V2. A V12 diesel that powered the T34 tank. A rather interesting use of both bevel and straight gears to drive the cam shafts. But I agree, I wouldn't call this arrangement 'feasible' in any modern sense.
?Waldo?
?Waldo? is offline
PostPosted: Fri Feb 11, 2022 12:38 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Thanks for the pic! Very cool engine. I know there are ways it can be done but the added complication is just worse than a timing belt, IMO.
damagd
damagd is offline
PostPosted: Fri Feb 11, 2022 7:37 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
So it's pretty easy to see that the head is cracked the whole way to the c-cup. Guess I'll be looking for a new head. I'm not even positive that this is the correct head for a turbo engine. The engine came from Europe and has a CY engine code. Not JX. Might have come out of an 81/82 Rabbit or Jetta. The head has 068 103 373 D stamped on it. The machine shop has a completely rebuilt head but it is stamped 068 103 373 witn no "D" or any other letters. My local VW garage has two heads laying around. One is stamped with the "D" like mine and the other is the same numbers but Stamped with a "T". Visually I can see that the one at the machine shop without a letter does not have an extra (oil?) chamber protruding next to one of the injectors. I'm understanding that heads with that bump out have hydraulic lifters. Also, I understand that some differences may be in the head bolt that it uses. I know that a turbo diesel head uses special valves filled with something. Not sure how to proceed. Can I mix and match anything?
?Waldo?
?Waldo? is offline
PostPosted: Sat Feb 12, 2022 9:07 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Hydro lifter head will not work on a solid lifter block.
There are better exhaust valves now than the sodium filled originals. I already posted part numbers above.
Considering your oil usage, you're also going to be into it at least for rings and very likely new pistons and having the block bored oversize. The cost if you do it right yourself will likely be over $1500 in parts and machine work. The labor is also significant. I'd probably fix that engine if it was in a rabbit/golf/jetta, but there are better options for a Vanagon, IMO, thus my first post in this thread.
old_man
old_man is offline
PostPosted: Sat Feb 12, 2022 10:02 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
If you're in a bind I think I still have a used JX head. Shipping would probably be murder though.
damagd
damagd is offline
PostPosted: Mon Feb 14, 2022 9:55 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
It is CY code and from everything I can find, the specs are the same as JX code. But it def had a hydraulic lifter head on it and you're saying that a hydro head won't work with a solid lifter block. So maybe CY and JX engines are different? I titled the post CY-JX because I assumed they were the same. But maybe I should change it to avoid confusion. There just doesn't seem to be any forum out there talking about CY coded engines. It is an import from Europe that was removed from an 81-88 Golf, Jetta, or Passat. Not sure which. Anyway, for now, I would like to just replace the head and get it running. I'm not sure that it is so much using oil as it is leaking oil. There are constant drips underneath, so it may be burning some oil, but it is def leaking as well. I would like to get it put back together and get the whole thing (which is filthy) washed off so that I can find the source of the leak. I'm choosing this route because (1) I like doing the work and want to learn about the engine. (2) I don't want to and am not prepared to be forced into a replacement engine right now if I can get this one running half decent. I would like to replace it in the future and am probably going to go with an Mk3 TDI engine, but it also needs extensive body work as well and I will probably get both projects done at the same time. My main thing is that I just want to make sure I'm putting the right head on. I just didn't know if it was the right head in the first place. If it is, I will just use the one that my mechanic has lying around that matches mine, "068 103 373 D".
damagd
damagd is offline
PostPosted: Mon Feb 14, 2022 10:34 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Depending how much my mechanic wants for the used head that he has with 150k miles on it and considering that I will probably have to take it to the machine shop to at least get checked out and maybe worked on, this might be a better option for $625 + tax. https://www.ebay.com/itm/114461605173
The used one that he has does look like it is in pretty decent shape. Doesn't even have any cracks between any of the valves.
ndorian
ndorian is offline
PostPosted: Mon Feb 14, 2022 3:08 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
The oil leak could be from the oil pan gasket. I have a 1.6 and after I changed mine I have not leaked a drop.
Jeffrey Lee
PostPosted: Mon Feb 14, 2022 3:25 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
If replacing the oil pan gasket, I highly recommend upgrading to the baffle/windage tray type with integrated gasket.
Besides the obvious advantage of preventing aeration of the sump oil, the thick rubber gasket provides a significantly better seal against the block than the fiber or cork gaskets.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9455531
Camp Westfalia
damagd
damagd is offline
PostPosted: Tue Feb 15, 2022 12:37 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
So the head that my local VW mechanic has with the "068 103 373 D", same as mine, came out of an 85 Golf without a turbo. So the only thing that could be different I guess is that the one from the 85 Golf might not have sodium filled valves. But I wonder if mine even has sodium filled valves? Same head number, but mine came from Europe. The head that my mechanic has came from a solid running engine. The body was totaled. So it wouldn't need any machine work except for a resurfacing and replacing the seals. He wants $200 for it. So my question is, is there any chance that it does have sodium filled valves, and if not, would it be ok to use it with the turbo? My mechanic says that the valve could burn up sooner, but seems to think that it would be ok to run it without the sodium valves. Looks like I can get a Reman turbo head from Parts Place for $550, and after purchasing the old head and resurfacing, I would be into it for about $300. I would rather spend less now to get it running since I plan on replacing the engine within a couple of years if you guys think it's ok to run it without sodium filled valves.
?Waldo?
?Waldo? is offline
PostPosted: Tue Feb 15, 2022 5:37 pm    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
IMO the IDI diesel heads should not be resurfaced with a typical milling operation. It loosens the pre-combustion chamber inserts which can then cause catastrophic issues later on. I have had excellent results using flat polished granite and 120 grit sandpaper to hand-lap the head gasket surface which does not place the same stress on the pre-chamber inserts.
IMO, tiny cracks in the pre-chamber inserts are more of an issue than the small cracks between the valves. You often cannot see the cracks until you polish the insert to a shine.
Although the head casting number/suffix can be helpful, VW was decidedly inconsistent. I have seen the same suffix used on both solid lifter and hydraulic lifter heads and they are not at all interchangeable!
You can tell if a VW 1.6 head was originally TD spec by the diameter of the face of the pre-combustion chamber inserts. The non-turbo heads had 32mm pre-combustion chamber inserts. The TD heads had 30mm inserts.
Replacement valves have not been sodium filled for quite some time. The later VW turbo-diesels/TDI engines do not use sodium filled valves. I don't think that is of particular concern.
damagd
damagd is offline
PostPosted: Sun Mar 06, 2022 8:37 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Question about this plate that is attached to the injection pump behind the sprocket. Is it supposed to attach to the block through that bottom hole? Or maybe somewhere else? It doesn't look like there was ever a bolt there, but it could have disappeared a long time ago and grease/dirt could have covered any evidence of it's previous existence. My entire injection pump is loose. And I mean totally free. There is nothing holding it down. Looks like two bolts came out of the bracket under the injection pump. Too hard to get a picture of, but I was having a difficult time getting the whole thing pulled forward enough to get the holes to totally line up. The black plate circled wasn't allowing it. Another bolt that came out, I circled, attaches the injection pump bracket to the alternator bracket. That one I can just barely get lined up enough to get a bolt through. I got a used head all ready to go, but I want to get this thing secured first.
?Waldo?
?Waldo? is offline
PostPosted: Sun Mar 06, 2022 9:02 am    Post subject: Re: 1.6 td CY-JX timing belt snapped. Questions/advice Syncro DOKA Reply with quote
Yes, the plate should mount to the block with several M8 (13mm head) fasteners. Considering they are all gone might explain what broke the timing belt. Likely one of them came loose and fell into the belt, jammed between belt and one of the sprockets, and snapped the belt. I would use blue loctite on the new bolts. Be aware that the position of that plate affects timing belt tracking and there is enough slop in the holes to make a big difference in the tracking. There are also bolts behind the injection pump that mount a second part of the pump bracket to the side of the block. If the pump is loose, then those are likely gone also. As a workflow, after getting the head on, I would recommend focusing on doing the items necessary to check tracking before items that are not needed for checking tracking because in order to adjust the tracking, it is likely that you will need to remove the injection pump. It sometimes needs to be removed more than once.
Page 2 of 5
