58b headlight grey-red wiring
Page: 1, 2, 3  Next
RBurn
RBurn is offline
PostPosted: Tue Mar 15, 2022 1:48 pm    Post subject: 58b headlight grey-red wiring Reply with quote
Hello all. Trying to sort out the electrical on my recently acquired 62 Single Cab.
When I got it the lighting condition was as follows.
Running lights
Left rear tail only.
Brake lights
None
Directional, left turn clicked as expected and nothing on right turn. No front bulbs in fried eggs.
Emergency switch. Makes a steady clicking sound
Headlights
High beams only.
So working on the tail lights the right taillight had the ground wire connected to the brake light post and the brake light post connected to the ground. It’s all pretty loose. Begin to read the forum and after using a cheap spade female connector I’m planning to order the correct Open Barrel Non-Insulated German Connectors and crimping tool as I have a few items to fix.
After sorting the taillight wires and looking at the fuse box which had one red fuse in number 5 and the rest white… and obviously looking ok I removed the taillight fuses as they crumbled in my fingers. Ok, new fuses across and the last two red ones.
Driving lights rear OK. Rear brake lights OK.
Moving to the front I noticed a melted wire(s) one connected to headlight switch. After some picts (dang it’s tight in there) I find grey-red connected to 58b and 3” away connects to speedo light right and it appears it travels over to the Speedo light left and then it’s in a larger sleeve with the wire that runs to rear cab interior light and it was hanging down about under fuel gauge and its melted wire. I do not have a clock so the single grey-red comes off the 58b and heads to light up the gauges (2 speedo light and 1 for fuel gauge). I’m thinking someone dropped the fuel grey-red and it shorted between there and 58b.
The speedo light is still illuminating. I made sure the wire is not touching any ground.
So I believe it’s a wire with 4 female connectors. One at 58b and three at the gauge lights?.Can anyone verify this.
I plan to disconnect the battery and drop the headlight switch and remove the grey-red and fish it across and unhook other speedo light and I guess cut the end off and use a fishing line to feed it through the black larger sleeve so I can restore a new wire in the same path.
Is there a way to find similar wire or the same color coated .. source? I found connectors at goodspeed and price seems fair.
I removed head lights and running light wires were broke or cut.. no female connectors and no connector on running light, just gone. Running light wires test good for power with switch on first pull. OK.
Headlights I checked power at high beam switch and it powered white and yellow ok so I checked headlights and one high worked and no low and the other light both high and low worked so the plug was not on well as I rechecked and low and high worked fine. I’ll need to get new connectors on running light bulb and add new brown wire in for a ground to the running light from the existing high low ground screw on the bucket.
So I guess I need to pickup one Wagner H024 headlight and a couple small running lights.
Front fried eggs turn lights have missing bulbs but it’s odd as on on 1st headlight switch I believe one side is constant 12v…. I need to put in some bulbs and I’ll continue on and post back on turn signal issue.
The electrical diagram is great to figure this stuff out. I did see one error I think as the gray-red from 58b goes to first speedo light (in and out are grey-red) and then on entering the second speedo light it says grey in and out and on the last fuel light it’s marked grey-red again?
Back of headlight switch shows 58b to 1st speedo light , no that’s not two wires it’s the wire and separated rubber insulation after shorted and melted.
Other side 2nd speedo light and loose wire suppose to go to fuel gauge light, both melted
Headlight bucket. Bare wire for running light , no ground wire for running light.
Headlight, is this original or?
70 Karmann Ghia Vert
67 Beetle deluxe
62 Single Cab
70 T2 Model 221 *CARR FIRE Victim
70 T2 Model 231 *CARR FIRE Victim
Erik G
Erik G is offline
PostPosted: Tue Mar 15, 2022 2:29 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
62's didn't have hazard (4 way) flasher so if someone added it, you need to look at how. the factory did it with the 9 prong box you probably don't have, there were a couple other ways to wire it. There is a good description on the type2.com site
headlights never had ground wires, a previous owner did that as well. I've done it in a pinch but it's not hard to do it correctly
RBurn
RBurn is offline
PostPosted: Tue Mar 15, 2022 2:48 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Thanks Erik, Dang, I hate it when people change the damn wiring. So the two prongs on the running light in headlight is for looks? Wondering if the headlight housing looks right? I can see where it should be grounded but when I saw the extra tabs I assumed lol.
Here are some shots under the dash, yes I see the 4 way flasher, whoever installed it seems they took it out of another split and wiring seems to be oem and as old as the other wires. Obviously when some switched to 12v
Looking at the electrical diagrams I do not see a number so I can get the gauge wire. The taillights look like 16g and front running lights are 18g? Need to know so I can order the right connectors.
67 Beetle deluxe
62 Single Cab
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Mar 15, 2022 3:26 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
What is the chassi number??
E-Flasher was stock in mid DEC62 for the 1963 model year and did not use a nine terminal relay that 66-67 did.
In Stereo, Where Available!
RBurn
RBurn is offline
PostPosted: Tue Mar 15, 2022 8:10 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Hello Eric, Is this what your asking?
Production
Dec 29, 1961
Type 1 - 1493cc, 31 kW (42 bph DIN)
Manual 4-speed gearbox
Type 2 (T1) mod. 261 :
- Single-cabin pick-up
- Luggage compartment right
- LHD
Vin 882723
26882723
M codes
071, 195, 362
67 Beetle deluxe
62 Single Cab
Eric&Barb
PostPosted: Tue Mar 15, 2022 9:00 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Production
Dec 29, 1961
- LHD
Vin 882723
26882723
M codes
071, 195, 362
Yup, the VIN. That info must be a Wolfsburg birth certificate. Really doubt that your bus would have the 1500cc engine from the factory since it does not have either the 215 or 216 M-codes. On the other hand the VW 311 941 583 A relay is part of the E-Flasher system and the relay mounting bracket looks like it was welded in by the factory. How early did VW install that bracket as a stock item??? Doubt it would be nearly a year early for VW to have started to install that bracket as a norm. On the other hand it could be your bus had it installed as a prototype test bed.
adriano
adriano is offline
PostPosted: Wed Mar 16, 2022 12:39 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Maybe I'm wrong, but your fuse box is a late type.
Could you post more pics of your bus to see the right year, please?
Eric&Barb
PostPosted: Wed Mar 16, 2022 8:24 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Hmm, maybe the nose was replaced??
Eric&Barb
PostPosted: Wed Mar 16, 2022 8:26 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Did you double check the birth certificate VIN to the one stamped in the engine compartment?
ToolBox
ToolBox is offline
PostPosted: Wed Mar 16, 2022 9:06 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
The way the headlight ground worked form the factory(at least on my 59) was the wire cam off the headlight connector, into the harness sleeve, folded over and came back out and was connected to the park light ground. The ground was pulled from the bucket fasteners and to the body through the mounting screw.
I added real grounds to a known mounting point in the cab. Headlight performance inproved greatly after this. Adding real ground wires to your rear lighting will also help.
I collect old harnesses to pull wires from for repairs. VW wires and colorings did not change much over the years so you could harvest out of most wreck you can find or find someone parting a car that might be willing to get you what you need.
Use this diagram and key for your wiring.
https://www.thesamba.com/vw/archives/info/wiring/bus_63_USA_with_emergency.jpg
https://www.thesamba.com/vw/archives/info/wiring/bus_63_USA_with_emergency_key.jpg
RBurn
RBurn is offline
PostPosted: Wed Mar 16, 2022 10:45 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
These are the two plates.
The paint when po took it back all the panels look original (white) I’d say it’s had no major body work on the front.
67 Beetle deluxe
62 Single Cab
Eric&Barb
PostPosted: Wed Mar 16, 2022 10:56 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Those plates can be removed via the screws in them. Look for the stamped numbers in the body sheet metal on the right hand side of the engine about eight inches (200mm) forward of the the engine lid.
The below from the 1960-64 replacement owner's manual:
RBurn
RBurn is offline
PostPosted: Wed Mar 16, 2022 10:59 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Great, yes the grounding is lacking. My headlight ground goes from the screw in the bucket directly into one of the 3 prong in the light plug. I plan to run a new run to the same bucket screw for the running light. Sounds like I should run another new one from there to inside the cab to a good known ground. The rear lights have a ground on the light housing to the triangle body brace and they are nice a bright running and really light up for the brake light.
My problem I’m not in the know and have many wrecks around me to get wiring, I’m beginning to watch the ads and my local area. I know similar year Mercedes has similar wiring so I’m looking around for that. I think at this time though my needs are few (melted wire under dash) and I’ll do a wtb for it once I drop it out of there.
Thanks for the electrical diagrams….. that’s what I needed! Wire sizs!
67 Beetle deluxe
62 Single Cab
RBurn
RBurn is offline
PostPosted: Wed Mar 16, 2022 11:13 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Ok, found it.
67 Beetle deluxe
62 Single Cab
Eric&Barb
PostPosted: Wed Mar 16, 2022 11:25 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
VIN looks original. If you see no signs of it being cut and welded in from underneath, then it probably is original to your truck.
62DoKaGuy
62DoKaGuy is offline
PostPosted: Wed Mar 16, 2022 11:26 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
'62 model did have four-way/hazard/emergency flashers! The only difference from '63 and later is that, with it being the first year, the '62 flasher knob was black on commercial vehicles like all other knobs. '63 onwards, it was the reddish brown with writing.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
62DoKaGuy
PostPosted: Wed Mar 16, 2022 11:29 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Fuse box and mount are correct for his '62 model.
4/62 Double Cab
5/61 Panel (sold)
PostPosted: Wed Mar 16, 2022 11:46 am    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Some clarification - 62s have the emergency light system, just no light.
The dash light was added in late 1962
Previous post I made in another thread:
Her's the dash light addition:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=482333
I couldn't find the actual full emergency system date/VIN.
62-63 have normal dash knobs. 64-up are the red knobs or lighted knob (1967)
RBurn
RBurn is offline
PostPosted: Wed Mar 16, 2022 12:08 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
No signs of anything like that. The rear apron is later style I believe.
67 Beetle deluxe
62 Single Cab
RBurn
RBurn is offline
PostPosted: Wed Mar 16, 2022 12:11 pm    Post subject: Re: 58b headlight grey-red wiring Reply with quote
Thanks Everett, the white knob on mine has some black tape around the base, not sure if was used to keep it on.?
Based on what you wrote it’s not the right color knob, I’ll look for a black one.
Thanks again.
67 Beetle deluxe
62 Single Cab
Page: 1, 2, 3  Next
