Gas tachometer to diesel conversion
Page: Previous  1, 2, 3, 4
VanTransylvania
VanTransylvania is offline
PostPosted: Wed Mar 16, 2022 1:33 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
sorry Waldo, just saw your questions after posting the details of accelerating ~500 rpm and the needle jumped more then that...
?Waldo?
?Waldo? is offline
PostPosted: Wed Mar 16, 2022 1:43 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
What is the value and part # for the yellow rectangular capacitor?
When you say "As far as I know it worked well," tell me more. Do you have any firsthand evidence that it worked well prior to the conversion? Did you see it working properly on a gas engine?
alexgb
alexgb is offline
PostPosted: Sat Mar 19, 2022 6:11 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
I found these stickers, I just ordered one for my tachometer conversion
http://www.foreignautosupply.com/parts-accessories/114-diesel-tachometer-decal/#.YjP95JrMLFp
pvfahrer
pvfahrer is offline
PostPosted: Sun Apr 03, 2022 4:10 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
Looking into doing a Tachometer conversion for my diesel van, I scored a gold mk2 instrument cluster with a tachometer to 7k. If I replace the components of this Tacho with the ones on the list, will this change the rpm range to the diesel range?
?Waldo? wrote:
Red = Keep
White = Remove
Green = Replace/Add
3.3uF cap: 445-8294-ND
10K ohm res: MFR5-10KFI
0.047uF cap: 399-C410C473K5R5TA-ND
71.5 ohm res: MFR-25FBF52-71R5
0.01uF cap: CS14-F2GA103MYGKA
15K ohm res: MBA02040C1502FRP00
?Waldo?
?Waldo? is offline
PostPosted: Sun Apr 03, 2022 4:47 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
Probably. The similar era VW tachometers all followed the same general schematic and parts list. The image is specifically regarding the Vanagon tachometer, though. You'll have to map out your board to identify which components to change.
There might be a schematic to your specific tach here: http://vwdiesel.net/forum/index.php/topic,3741.0.html
pvfahrer
pvfahrer is offline
PostPosted: Sun Apr 03, 2022 5:15 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
great! thanks for the link, i'll have a look and see if i can find a comparable one.
chrismsnt
chrismsnt is offline
PostPosted: Mon Apr 04, 2022 7:53 am    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
From what I've found.... the HARDEST part is finding an alternator with a W terminal anymore! Sad
Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Apr 04, 2022 8:07 am    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
I've tried this mod on two different WBX tachs, but I couldn't get either to function correctly. I'll strike that up to user error. I just finished up converting an AHU alternator to send a W signal to a Speedhut tach and it works excellent.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
RolandD
RolandD is offline
PostPosted: Tue Apr 05, 2022 4:57 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
Is it not common knowledge to put an industrial proximity sensor on the injection pump pulley?
Roland
?Waldo?
?Waldo? is offline
PostPosted: Wed Apr 06, 2022 8:26 am    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
It is commonly known as a possibility, but not actually on-topic for this thread.
RolandD
RolandD is offline
PostPosted: Wed Apr 06, 2022 3:46 pm    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
Waldo, would it be on topic if no modifications where needed for it to drive a gas tach?
Roland
pvfahrer
pvfahrer is offline
PostPosted: Mon Apr 18, 2022 6:19 am    Post subject: Re: Gas tachometer to diesel conversion Reply with quote
Quick follow up, i indeed found the schematics at the vwdiesel forum, my 7k tachomter has an almost identical circuit to the first posted one, although the physical appearance is different, the circuit is the same. I have ordered the parts as per list in the post at vwdiesel.net. Waiting for them to come in. Once i have them in place, i'd like to test and calibrate the tachometer using a function generator and was wondering what the input wave form looks like. I am assuming the signal is a 0-12V square wave or pulse with a frequency related to the rpm? Does anybody know the alternator rpm to engine rpm ratio?
Also since i have a golf tachometer, the rear plate is different to the one needed to fit the Vanagon instrument cluster. In case somebody has some left-over parts please let me know, this woudl make the project a lot easier.
edit thesamba for the rescue, i found the information on calibration using a wave from generator in https://www.thesamba.com/vw/forum/viewtopic.php?t=430888 an older topic
It is in german, the part on the calibration translates to:
"Calibration; if you own a wave form generator: Use sine wave with 10-15V amplitude, at a frequency of 1320hz the tachometer should show 6000rpm. This is for Diesel engines with a V-belt between alternator and water pump."
(Abgleich, wenn man einen Frequenzgenerator hat: Mit einem Sinussignal mit einer Amplitude von etwa 10-15 V wird der DZM so eingestellt, dass er bei einer f=1320 Hz 6000 1/min anzeigt. Dieser Wert gilt für alle Dieselmotoren mit einem Keilriemen für Lichtmaschine und Wasserpumpe.)
Page 4 of 4
