2 tone rims 2 stage paint steps?
kylewadescott
kylewadescott is offline
PostPosted: Thu May 12, 2022 5:30 am    Post subject: 2 tone rims 2 stage paint steps? Reply with quote
Ok so I got my 67 wheels sandblasted and epoxy primered. I need to paint the wheels in the next couple days but I would like to know the proper way, or how you guys painted yours.
Im confused at the steps to take with 2 tone rims. Using 2 stage paint makes this a little tricky with 2 toned rims. I know you gotta put the clear on in a certain time to have it properly bond to the base, problem is, the base needs to be dry on the inner so I can tape it off and paint the outer part.
Info: The inner part of the rim is grey/black, the outer is cumulus white.
Do I paint the whole wheel black, clear coat it, let it cure for a couple days, then tape off the middle, scuff the outer rim, paint it white, then clear coat the outer?
Or do I paint the whole wheel black, let it dry for ???, tape off the inner, paint the outer white, then clear coat the whole thing together?
VWFIXER
Banned
VWFIXER is offline
PostPosted: Thu May 12, 2022 7:32 am    Post subject: Re: 2 tone rims 2 stage paint steps? Reply with quote
The window for putting paint on epoxy is pretty close to putting clear on base. Of course I don’t know what manufacturers you’re using so…
( ) Cheap
( ) Fast
( ) Reliable
Choose 2
Over a million air cooled miles driven and 15,000+ cars serviced.
kylewadescott
PostPosted: Thu May 12, 2022 7:36 am    Post subject: Re: 2 tone rims 2 stage paint steps? Reply with quote
Using PPG OMNI. Specs say 72 hours to put base on. But that doesn't really matter so much cause I am going to gently sand down the the epoxy and fix some curb scuffs anyways. I just want to make sure Ive got the base/clear steps with the 2 tone rims correct.
VWFIXER
Banned
VWFIXER is offline
PostPosted: Thu May 12, 2022 7:45 am    Post subject: Re: 2 tone rims 2 stage paint steps? Reply with quote
Put base on sanded epoxy and it highlights your sanding.
( ) Cheap
( ) Fast
( ) Reliable
Choose 2
kylewadescott
PostPosted: Thu May 12, 2022 8:02 am    Post subject: Re: 2 tone rims 2 stage paint steps? Reply with quote
I am tracking, I originally put down the epoxy to stop flash rust. I will sand/fix scuffs and then reapply epoxy when its time to paint. I need to gather the full steps to a successful rim paint job, before I start laying down color and screw myself with needing to start over from the beginning.
