Restoration build
Page: Previous  1, 2, 3
XMZJW5
XMZJW5 is offline
PostPosted: Wed May 11, 2022 2:17 pm    Post subject: Re: Restoration build Reply with quote
Yep bad ground all good now
slayer61
slayer61 is offline
PostPosted: Wed May 11, 2022 2:22 pm    Post subject: Re: Restoration build Reply with quote
Cool. So your "parts" work... except maybe the switch. Maybe. In the pictures you had a yellow wire on the starter solenoid. I didn't see any yellow wire on the start switch.
I believe the center pin on the key switch should connect to the small terminal on the starter solenoid.
1). 12 volts at the "in" side of the switch?
2). 12 volts at the "out" side of the switch when start is called for?
It's literally connect the dots.
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
slayer61
slayer61 is offline
PostPosted: Wed May 11, 2022 2:23 pm    Post subject: Re: Restoration build Reply with quote
excellent.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
XMZJW5
XMZJW5 is offline
PostPosted: Wed May 11, 2022 3:23 pm    Post subject: Re: Restoration build Reply with quote
I had the cable off for the picture but it all back together and turns over strong now. Just have to put gas in and it should start, maybe
XMZJW5
XMZJW5 is offline
PostPosted: Sat May 14, 2022 8:17 am    Post subject: Re: Restoration build Reply with quote
Finally got most the electric figures out and done. Hopefully. Still have to put gas in and start it to know for sure. Also still waiting on the back order exhaust but I should be able to do a quick start without it.
Updated to all led lights. Next is the gauges and interior.
XMZJW5
XMZJW5 is offline
PostPosted: Sat May 14, 2022 8:18 am    Post subject: Re: Restoration build Reply with quote
jorgegalindog
jorgegalindog is offline
PostPosted: Sun Aug 03, 2025 12:07 am    Post subject: Re: Restoration build Reply with quote
XMZJW5 wrote:
I'm not sure who did this... But this would be awesome to build. Be nice to find out the person behind it.
Did you find who it was that made that? im trying to recreate my own spring suspension.
finster
finster is offline
PostPosted: Sun Aug 03, 2025 2:39 am    Post subject: Re: Restoration build Reply with quote
looks a lot like a red 9 unit - https://red9design.co.uk/type1.htm but there are others available
jorgegalindog
PostPosted: Sun Aug 03, 2025 3:16 pm    Post subject: Re: Restoration build Reply with quote
Im trying to design one from scratch but maybe it could share some components like the arms from a jetta or golf mk4, it would be nice to have it just bolt on like this one
EVfun Premium Member
EVfun is offline
PostPosted: Sun Aug 03, 2025 6:08 pm    Post subject: Re: Restoration build Reply with quote
Here is another option, Imohr from Brazil.
Page 3 of 3
