XMZJW5 Samba Member
Joined: October 10, 2021 Posts: 27 Location: Tulsa, Oklahoma
Posted: Wed May 11, 2022 2:17 pm Post subject: Re: Restoration build |
| Yep bad ground all good now |
slayer61 Samba Member
Posted: Wed May 11, 2022 2:22 pm Post subject: Re: Restoration build |
Cool. So your "parts" work... except maybe the switch. Maybe. In the pictures you had a yellow wire on the starter solenoid. I didn't see any yellow wire on the start switch.
I believe the center pin on the key switch should connect to the small terminal on the starter solenoid.
1). 12 volts at the "in" side of the switch?
2). 12 volts at the "out" side of the switch when start is called for?
It's literally connect the dots. _________________
| Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
| 67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header |
Posted: Wed May 11, 2022 2:23 pm Post subject: Re: Restoration build |
| XMZJW5 wrote: |
excellent. _________________
| Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
XMZJW5 Samba Member
Posted: Wed May 11, 2022 3:23 pm Post subject: Re: Restoration build |
| I had the cable off for the picture but it all back together and turns over strong now. Just have to put gas in and it should start, maybe |
XMZJW5 Samba Member
Posted: Sat May 14, 2022 8:17 am Post subject: Re: Restoration build |
Finally got most the electric figures out and done. Hopefully. Still have to put gas in and start it to know for sure. Also still waiting on the back order exhaust but I should be able to do a quick start without it.
Updated to all led lights. Next is the gauges and interior.
XMZJW5 Samba Member
Posted: Sat May 14, 2022 8:18 am Post subject: Re: Restoration build |
jorgegalindog Samba Member
Posted: Sun Aug 03, 2025 12:07 am Post subject: Re: Restoration build |
| XMZJW5 wrote: |
I'm not sure who did this... But this would be awesome to build. Be nice to find out the person behind it.
Did you find who it was that made that? im trying to recreate my own spring suspension.
finster Samba Member
Joined: May 26, 2012 Posts: 10574 Location: not far from the madding crowd
Posted: Sun Aug 03, 2025 2:39 am Post subject: Re: Restoration build |
looks a lot like a red 9 unit - https://red9design.co.uk/type1.htm but there are others available _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sun Aug 03, 2025 3:16 pm Post subject: Re: Restoration build |
| Im trying to design one from scratch but maybe it could share some components like the arms from a jetta or golf mk4, it would be nice to have it just bolt on like this one |
EVfun  Samba Member
Posted: Sun Aug 03, 2025 6:08 pm Post subject: Re: Restoration build |
| jorgegalindog wrote: |
Here is another option, Imohr from Brazil. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
