james309 Samba Member
Joined: October 09, 2016 Posts: 24 Location: Gloucestershire, England
Posted: Tue Jun 28, 2022 7:50 am Post subject: - 5.00 / 5.25 x 16 Tyres |
Looking for a pair of tyres for my split beetle. Currently no new stock in the UK.... that I can find !
Any used ones about ?
Or something I can borrow ?
Thanks
James |
finster Samba Member
Joined: May 26, 2012 Posts: 7961 Location: north o' the border
Posted: Tue Jun 28, 2022 8:51 am Post subject: Re: Wanted - 5.00 / 5.25 x 16 Tyres |
Yes,
Longstone
Vintage Tyres
All out of stock, most showing stock online but don't have any |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Wed Jun 29, 2022 2:09 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
Thanks for the link, but no stock |
mikeandkirsti Samba Member
Posted: Thu Jun 30, 2022 4:29 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
500/5.25 are too large, original size is 5.00X16, available from Heidenau through numerous German retailers |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jun 30, 2022 5:23 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
mikeandkirsti wrote: |
not questioning your recommendation, but i doubt you would see the difference between a 5inch tire and a 5 and quarter inch tire if they were mounted next to each other. _________________ regards
Uli
52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Thu Jun 30, 2022 9:06 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
i would like to know who sells this size in Canada or the USA. thanks |
sled Samba Member
Posted: Fri Jul 01, 2022 8:10 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
mandraks wrote: |
not questioning your recommendation, but i doubt you would see the difference between a 5inch tire and a 5 and quarter inch tire if they were mounted next to each other. |
visually, no you wouldn't. But the correct sized tire would result in a speedo that was a bit more accurate, as well as bringing the RPM's of the engine up more appropriately. Split beetles are already geared too tall in fourth gear, and the smaller tire helps get the rpms up. _________________ drive your split. |
Posted: Sat Jul 02, 2022 1:06 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
52 split wrote: |
This retailer sells P29 Series but not this size, you might want to ask them
https://www.mototireusa.com/searchresults.asp?cat=65 |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1298 Location: south san francisco
Posted: Sat Jul 02, 2022 7:43 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
motorcycle tires ? bad idea . not load rated for a car
for starters. wear out super fast. small contact patch. ect..
seems dangerous to me. scary enough on 500/5.25 bias ply's. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
sled Samba Member
Posted: Sat Jul 02, 2022 8:36 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
sgmalt46 wrote: |
seems dangerous to me. scary enough on 500/5.25 bias ply's. |
the P29 is not a motorcycle tire...
and 5.00/5.25's aren't scary unless you have some issues with your car, I've put thousands of miles on my car with them.
https://www.heidenautires.com/product/p29/
Posted: Sat Jul 02, 2022 9:41 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
ok i stand corrected the other website showed them for motorcycle side cars.
scary was an overstatement . should of said sketchy compared to a modern Radial. more accurate. especially on crappy California roads and drivers . _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Posted: Sat Jul 02, 2022 2:23 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
the bigger the bumps and potholes the more the bias plies shine. they don't last long, and they do not corner like a radial, but they sure smooth out the ride. _________________ regards
Uli
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Jul 07, 2022 12:19 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
... just bought a set of 4, 5.25x16, from in thesamba classifieds = Firestone - probably won't use the white wall side, out - for our 1950 11A - tall, skinnies look great on a split - we rarely drive oner 40 MPH - over that speed, we find that the rear-end hops when turning severely - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Thu Jul 07, 2022 1:13 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
sgmalt46 wrote: |
If you are running correct pressures and drive sensibly in an old car cross plys are just fine. Try to corner at 50 mph like a modern car & you will regret it !
I cant find a stockist of these in the UK, and no stock in Germany so far 😕 |
Posted: Thu Jul 07, 2022 5:53 pm Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
ZENVWDRIVER wrote: |
... just bought a set of 4, 5.25x16, from in thesamba classifieds = Firestone - probably won't use the white wall side, out - for our 1950 11A - tall, skinnies look great on a split - we rarely drive oner 40 MPH - over that speed, we find that the rear-end hops when turning severely - z |
are you cheating on Craigslist? I thought you buy'em used for 20 bucks? _________________ regards
Uli
Posted: Sun Jul 17, 2022 9:07 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
mandraks wrote: |
are you cheating on Craigslist? I thought you buy'em used for 20 bucks? |
You thought correctly - times have changed and i have changed - bought this set for $365, shipped = a deal and a half, from Stock Steve in the Nutmeg state - rarely look on CL anymore -z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Sun Jul 17, 2022 9:15 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
james309 wrote: |
sgmalt46 wrote: |
i miss cornering at 50 in our MR2 - z
1960 single cab
'87 Toyota MR2
sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Tue Jul 19, 2022 9:02 am Post subject: Re: - 5.00 / 5.25 x 16 Tyres |
I have a used set of 4 if you still need some. |
