Distributor 022 905 205S restoration questions
Page: Previous  1, 2
Jason0115
Jason0115 is offline
PostPosted: Thu Aug 25, 2022 9:19 pm    Post subject: Re: Distributor 022 905 205S restoration questions Reply with quote
furgo wrote:
How do you install the tiny circlip that is under the felt puck under the rotor? Mine was also sitting on top of two little washers loose, giving my distributor way to much vertical freeplay. Thanks
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Aug 26, 2022 6:35 am    Post subject: Re: Distributor 022 905 205S restoration questions Reply with quote
I use a metal tube just a tad larger than the distributor clip shaft. A dab of grease holds the clip in place while a bop if a rubber mallet usually seats the clip nicely.
Large sheet magnets available at craft stores are handy as a work mat for small jobs like those clips and steering box bearings.
Robbie
www.airschooled.com
Road trip reports and tech blog:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Aug 26, 2022 6:38 am    Post subject: Re: Distributor 022 905 205S restoration questions Reply with quote
1/4 drive M6 deep socket
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
heimlich Premium Member
VWNOS.com
heimlich is offline
Some people use a socket that is the right size to fit over the inner shaft and inside the outer one. I use a few small tools to snap it on. It's not easy when it's your first time. Do a few hundred and they just seem to snap on.
Jason0115
PostPosted: Fri Aug 26, 2022 7:53 am    Post subject: Re: Distributor 022 905 205S restoration questions Reply with quote
This worked like a charm, I hit the top of the socket with a hammer and the clip is in. Thanks
Mr. 010
Glenn is offline
PostPosted: Fri Aug 26, 2022 8:00 am    Post subject: Re: Distributor 022 905 205S restoration questions Reply with quote
Thumbs Up Thumbs Up
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Page: Previous  1, 2
Page 2 of 2
