J Wray Samba Member
Posted: Sun Oct 02, 2022 4:45 pm Post subject: 73 convertible - voltage keeps increasing with RPM |
Just bought a 73 convertible The voltage keeps increasing with RPM to 16.5 volts. The generator tested good. I have a new voltage regulator. I installed a new voltage regulator Saturday; everything checked out good. Went on a short drive today and noticed the GEN light was coming on at low RMPs. So I got out the voltmeter and found the high voltage problem. Any suggestions on what the problem may be? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52781 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Oct 02, 2022 4:57 pm Post subject: Re: 73 convertible - voltage keeps increasing with RPM |
Welcome!
I'd start with a continuity test on all the wires between the generator and regulator, often a weak ground causes something similar to your issues, if the reg can't sense voltage how does it know when to stop charging? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
J Wray Samba Member
Posted: Tue Oct 04, 2022 5:10 pm Post subject: Re: 73 convertible - voltage keeps increasing with RPM |
The voltage regulator has a good ground, Looks like the gen is grounded by the gen strap. Should the be a ground wire between the voltage regulator smd gen? |
Posted: Tue Oct 04, 2022 5:23 pm Post subject: Re: 73 convertible - voltage keeps increasing with RPM |
There should be a brown wire in the regulator harness, check it for good continuity to ground. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
