Can you cut a M8x1,25 to M6x1,0?
Adriel Rowley
Adriel Rowley is offline
PostPosted: Wed Oct 05, 2022 1:49 pm    Post subject: Can you cut a M8x1,25 to M6x1,0? Reply with quote
The length of thread being reduced is 6mm, then cutting further for a length of 10mm total.
Thanks in advance! Very Happy
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 05, 2022 1:55 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Huh?
Are you asking if you can make a M8 bolt with a 1.25 pitch a M6 with a 1.0 pitch?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
UK Luke 72
UK Luke 72 is offline
PostPosted: Wed Oct 05, 2022 2:37 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Yes you can, you'd need to turn the m8 thread down to 6mm though before you cut the m6 thread.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Brian_e Premium Member
Brian_e is offline
PostPosted: Wed Oct 05, 2022 2:47 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
What are you trying to build/modify/fix?
Step studs are pretty common and available. Especially m8 down to m6. I have a few in a pile on the bench. They send them with new aluminum cases to use with old non-doghouse oil coolers.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
Mr. 010
Glenn is offline
PostPosted: Wed Oct 05, 2022 2:48 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
ACE Hardware has a nice selection of metric bolts and step studs.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
modok
modok is offline
PostPosted: Wed Oct 05, 2022 4:36 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Yes, you can
bsairhead
bsairhead is offline
PostPosted: Wed Oct 05, 2022 5:34 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
I can, doesn't mean you can.
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:31 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Glenn wrote:
Huh?
Oops, sorry I was not clear. Yes, that is correct, except a stud.
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:32 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Thank you. I don't have a lathe, hmmm.
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:38 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Brian
Brian, thank you for the help and asking.
I am adding a Maxi spin on filter to Ruby's 1200cc engine. Being the engine is in fantastic shape (about 125psi of compression despite over 250,000 miles) I am nervous about drilling and tapping the case.
The length of the stud needs to be at least 40mm, 9mm longer than the oil cooler step studs (10mm case depth, 25mm thickness of the oil pump and oil filter casting, plus enough to get nuts on).
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:42 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Oh? Okay, thank you for letting me know!
I will see if can bum a ride over there (why buy most everything online). My friend says he is enabling me to get transportation from others, then gets upset when I buy a water pump pick online when he take me to Harbor Fright, then when ask when can we go, says not transporting me because that be enabling. Rolling Eyes Laughing Wish knew why neurotypicals are so confusing.
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:43 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
modok wrote:
Yes, you can
Thank you.
Adriel Rowley
Laughing
You have ice handy? Laughing
Thanks for the chuckle, needed it.
Dale M.
Dale M. is offline
PostPosted: Wed Oct 05, 2022 6:46 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Brian
https://belmetric.com/?gclid=Cj0KCQjw1vSZBhDuARIsA...YsEALw_wcB
Adriel Rowley
PostPosted: Wed Oct 05, 2022 6:53 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Brian
Thank you.
Weird, now only have the 25mm and 31mm lengths:https://belmetric.com/m6-to-m8-stepped-stud-class-8-8-steel/?.
RCP Phx
RCP Phx is offline
PostPosted: Wed Oct 05, 2022 8:11 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
You would be better off to just tap the oil pump holes to 8mm. You can minimize the aluminum cuttings and your adding a filter so it would trap anything left and there is probably worse stuff in the sump already since you didn't have a filter!
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Wed Oct 05, 2022 9:43 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
You cannot just drill and install 8mm studs where there 6mm studs go. The 8mm oil pump holes are offset from the 6mm Stud holes.
I built a jig many years ago out of a 8mm steel pump cover and welding tubing pieces to so drill would go straight when drilling offset holes.
It is really is best to do this in a mill.
If it was mine and did want to take engine apart, I would just use longer 6mm bolts.
It does work and has been done before. Pump is not going to rotate.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
modok
modok is offline
PostPosted: Wed Oct 05, 2022 10:03 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
I agree, maybe some thick washers.
RCP Phx
RCP Phx is offline
PostPosted: Wed Oct 05, 2022 10:26 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
I just use a old 8mm pump body so it gets perfectly centered!
Adriel Rowley
PostPosted: Thu Oct 06, 2022 9:40 pm    Post subject: Re: Can you cut a M8x1,25 to M6x1,0? Reply with quote
Why I am going to put some 1990s vintage oil in and run for a while. I was going to do this previously, had to move in a hurry, didn't have time to button up the valve train and put the cover on, thought the engine was level, however, it was not, filled the floor of Ruby with oil, now don't have to worry about the pan rusting further. Laughing
